10th May 2020, 08:13 | #101 | Link |
How well does NVENC do .?
Deleted as used wrong source - was quite surprised how high my y ssim score was - I might try again some other time these were my settings anyway NVEncC64.exe --vbrhq 1000 --codec h265 --preset quality --profile main10 --tier high --level 4.1 --output-depth 10 --max-bitrate 4000 --vbv-bufsize 12000 --aq-strength 1 --aq --aq-temporal --bref-mode each --bframes 4 --ref 5 --gop-len 120 --lookahead 32 --slices 1 --multiref-l0 4 --multiref-l1 2 --nonrefp --weightp --ssim --mv-precision q-pel --cabac -i Last edited by Joekiwi; 10th May 2020 at 09:21. Reason: mistake and now irrelevant |
10th May 2020, 09:10 | #102 | Link |
Ok maybe disregard my last post - I'm using the wrong source - so probably it's probably a much easier to encode .
I just watched Bens' placebo encode and there was much more detail . I just watched my source for the encode and it also lacked the detail. I did download the 14 gb file - But when I unzipped it I got nothing - wasn't sure why - so downloaded another file mentioned later on that I think was only 579mbs ( from memory-I'm on a different PC ) . So NVENC will be worst than my scores - still I can untick copy audio and get another 90 odd kbps to use . Ben did I need all those 4 files in your link to get the Source? Last edited by Joekiwi; 10th May 2020 at 09:11. Reason: easier to read |
10th May 2020, 10:21 | #103 | Link | ||
Testeur de codecs
Be carefull, Placebo Benwagonner encoding is really old encoding. And I suspect Rate Control problem (really bad quality in start scene). Ma's encoding produce really better overall quality. Bearm 4.5 encoding is really good too (be carefull it's zone encoding like real compressionnist encoding). Quote:
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 Last edited by Sagittaire; 10th May 2020 at 10:40. |
10th May 2020, 15:59 | #104 | Link | |||||||||||||||
Testeur de codecs
Well after many and many tests to find best x265 setting for this ToS source, here my result for only 1000 kbps at this moment. I will use he-aac 5.1 audio at 128 kbps for 1000 kbps, he-aac 5.1 audio at 160 kbps for 1500 kbps and lc-aac 5.1 audio at 192 kbps for 2000 kbps encoding:
WARNING: google drive make AVC transcoding for streaming. if you want to see real HEVC encoding, download the file. 1) crf 1 passe mode: highest possible metric score in all mode Preset "veryslow" for 1000 kbps and "optimized slower" for 1500 and 2000 kbps ToS-1000-crf.mkv ToS-1500-crf.mkv ToS-2000-crf.mkv Quote:
2) ABR with 3 passes: highest possible metric in NPass mode Preset "veryslow" for 1000 kbps and "optimized slower" for 1500 and 2000 kbps ToS-1000-abr.mkv ToS-1500-abr.mkv ToS-2000-abr.mkv Quote:
3) ABR with 3 passes with default setting: default setting for rate control, adaptative quantisation and psy-rdo setting at same level research for me, cu, tu ... than crf (1) and abr (2) encoding. Preset "veryslow" for 1000 kbps and "optimized slower" for 1500 and 2000 kbps. ToS-1000-psy.mkv ToS-1500-psy.mkv ToS-2000-psy.mkv Quote:
4) Reuse ABR with 3 passes : transcoding from ABR 3 passes encoding veryslow at 1000 kbps (2) with analysis reuse statistique at really high speed (by factor ~100x) ToS-1000-hs.mkv ToS-1500-hs.mkv ToS-2000-hs.mkv Quote:
5) Reuse ABR with 3 passes, refine and psy optimisation : transcoding from ABR 3 passes encoding veryslow at 1000 kbps (2) with analysis reuse statistique, highest possible refine level (higher speed by factor ~3x) and my best psy optimisation. Best result for my eyes. ToS-1000-jfl.mkv ToS-1500-jfl.mkv ToS-2000-jfl.mkv Quote:
Conclusion at 1000 kbps: - For my eyes, my best encoding (5) produce better quality than default psy x265 setting (4) or previous ultraplacebo Benwagonner encoding, and by far. It's really good quality for only 1000 kbps encoding at 1080p. For me it's a really reasonable quality for streaming on a small screen ... or for reduced internet bandwidth due to COVID19 crisis. For comparison it's by far better quality level than Netflix "premium" quality for same bitrate. - crf encoding (1) produce best metric and by far but not best visual quality for my eyes. crf encoding has really agressive quantizer for bframe and that mean lower relative quality for low complexity part. Anyway it's higher relative quality for high complexity part too. But this compromise is not good for my eyes at 1000 kbps. At this really low bitrate level (1000 kbps for 1080p source), I prefer high compression for rate control curve (more "cbr like" and less "vbr like"). - Encoding with default x265 setting (3) don't produce good quality for my eyes. There are many problems, particulary on the edge. Perhaps that these defaults psy setting are not good for really low bitrate. - The most interessing encoding is certainely reuse ABR transcoding (4). I make ABR at "veryslow quality preset" but at stratospheric speed (40.87 fps for 1080p source with little i5 3550 CPU), in 3 passes to have best possible constant quality rate control curve. And the result is impressive. Really better result for my eyes than crf (1) or default setting (4). Conclusion at 2000 kbps: - All encoding produce really good quality. Quality difference between profil encoding are not really high like for 1000 kbps encoding. I make these encoding with optimized "slower" x265 profil for (1), (2) and (3), and I obtain equivalent quality than old previous benwagonner encoding with "ultra placebo" x265 profil. - Default setting for x265 at 2000 kbps (3) produce really better relative subjective quality than for 1000 kbps encoding. At this quality level, default setting are really good. - You can produce really good quality at high speed with reuse encoding without refine (4). - My prefered setting for my eyes are always reuse encoding with refine and my psy optimisation (5). For my eyes this profil have better temporal stability, noise retention, and overall quality but this time, by a really small margin.
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 Last edited by Sagittaire; 21st May 2020 at 16:48. |
11th May 2020, 10:50 | #106 | Link |
Pig on the wing
Regarding comparisons of CRF vs. multipass: what's the verdict on doing the first pass with CRF and then running a second pass using the average bitrate that resulted from the CRF run? It won't work with this fixed bitrate level challenge, I was thinking more on the lines of squeezing some extra quality out of x265 if the 2-pass rate control seems to be better. Maybe there are also some options that could be left out of the CRF pass and activated only in the second pass to speed things up a bit (or use those reuse options)?
11th May 2020, 11:33 | #107 | Link | |
Thanks Sagittaire, Will try again maybe later in week . I know NVENC will get absolutely slaughtered by yours and other encodes . - However I am curious . I use to use paid software that promised superfast encoding speed ( ie via GPU ) . There are probably a lot of people out there like me - that used or still uses such software . - Since installing staxrip as a front end I feel I'm get much better results and that I'm in control. I should really get to learn the x265 on CPU as well - easy on handbrake as only a few options - easy just to set CRF & preset - but will try to learn it on staxrip with it's myriad of options - or maybe just easier to grab someones command line and use the encoder directly-my Ryzen 3700x can handle it & still do NVENC coding at same time for no cost . Without Bens' constraints GOP , max bit rate, vbv -I imagine your metrics would be quite better. Maybe someone else can see good they can achieve by setting minimum 3fps encoding which is a good metric for encoding a movie while you sleep |
11th May 2020, 13:06 | #108 | Link | ||
Testeur de codecs
You have major problem in your encoding: - Mosquito noise (it's not detail or noise retention but only encoding artefact) - Ringing arround all the edge - temporal blocking instability on flat part like the sky (certainely sao off) - detail retention in low motion scene I can make captures that will be terrible for your encoding. There is a simple test to do: see if the flies(?) flying above the actress' head between frame 877 and 907 (37s to 38s) are visible. In your encoding it's not visible (or only on Pframe) simply because you have terrible ringing around the actress' head. Certainely because you have really high difference quality between inter and intra block (or between Pframe and bframe). You have major temporal blocking and bluring on the rocket (18s to 25s) ... in fact it's the same problem for all the edge everywhere. I think that if you use really higher bitrate (with your setting), all your "detail" or "texture" will no longer be there ...
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 Last edited by Sagittaire; 11th May 2020 at 18:42. |
11th May 2020, 13:38 | #109 | Link | |
Testeur de codecs
2) the right way would be to control the quantizer ratio between differents frames types but these command (--ip-ratio and -ib-ratio) seem doesen't work in the crf mode. (work in multipass mode)
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 Last edited by Sagittaire; 11th May 2020 at 14:57. |
11th May 2020, 14:44 | #110 | Link | |
Pig on the wing
The ratios should definitely work, they are for example a part of --tune grain so in case they don't, it should be reported as an issue in the tracker.
11th May 2020, 15:25 | #111 | Link | ||
Testeur de codecs
Like I say, I make many and many test ... ;-)
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 Last edited by Sagittaire; 11th May 2020 at 15:40. |
11th May 2020, 16:43 | #112 | Link |
The higher RD modes allow for more psychovisual optimizations, and those often reduce PSNR while they improve psychovisual quality. <0.5 PSNR shift isn't something that can be assumed to be better/worse without visual inspection.
11th May 2020, 18:36 | #113 | Link | ||
11th May 2020, 19:37 | #114 | Link | |
Testeur de codecs
Anyway I confirm that I use highest possible curve rate compression (qcomp at 0.50) to have better quality in low motion and less in high motion. For this reason I prefer my ABR encoding to equivalent crf encoding. Eyes are generaly more sensitive at detail and texture preservation in low motion part and less in high motion. It's for this reason that I prefer the Bearm encoding (HEVC encoder). But your eyes are perhaps more sensible at high motion scene (really short scene in this source). In this case, you can try encoding with higher qcomp default value (0.6 by default, 1.0 will be real VBR). However I maintain that the quality for your encoding in the low motion scene is terrible. Temporal stability is catastrophic too in low motion. The rendering of moving objects in static scenes (like head movements for exemple) has really visible and have annoying temporal artifacts too. I prefer, and by far, my compromise for overall quality. Anyway HVS is like taste and colors. Some prefer chocolate and others vanilla. Some users prefer x265 with sao and other not. But for my eyes your encoding is really bad, and particulary in scene introduction. If Boulder or Benwagoner have an opinion ... ;-)
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 Last edited by Sagittaire; 11th May 2020 at 21:01. |
13th May 2020, 15:32 | #115 | Link | |
Pig on the wing
P/B ratio 1.3 Code:
in:0 out:0 type:I q:21.94 q-aq:19.57 q-noVbv:21.94 q-Rceq:0.99 tex:582913 mv:9220 misc:2973 icu:3600.00 pcu:0.00 scu:0.00 ; in:4 out:1 type:P q:21.94 q-aq:19.24 q-noVbv:21.94 q-Rceq:0.99 tex:614212 mv:13405 misc:3414 icu:3297.50 pcu:301.25 scu:1.25 ; in:2 out:2 type:B q:23.08 q-aq:21.04 q-noVbv:23.08 q-Rceq:0.99 tex:386297 mv:23848 misc:6130 icu:959.50 pcu:2405.25 scu:235.25 ; in:1 out:3 type:b q:24.21 q-aq:22.84 q-noVbv:24.21 q-Rceq:0.99 tex:221768 mv:22069 misc:7085 icu:288.50 pcu:2764.00 scu:547.50 ; in:3 out:4 type:b q:24.21 q-aq:22.85 q-noVbv:24.21 q-Rceq:0.99 tex:234317 mv:23280 misc:6718 icu:393.75 pcu:2778.00 scu:428.25 ; in:9 out:5 type:P q:21.94 q-aq:19.38 q-noVbv:21.94 q-Rceq:0.99 tex:589089 mv:11898 misc:3306 icu:3406.25 pcu:191.75 scu:2.00 ; in:7 out:6 type:B q:23.08 q-aq:21.66 q-noVbv:23.08 q-Rceq:0.99 tex:346593 mv:21229 misc:5560 icu:1007.25 pcu:2402.25 scu:190.50 ; in:5 out:7 type:b q:24.21 q-aq:22.80 q-noVbv:24.21 q-Rceq:0.99 tex:227102 mv:26712 misc:7243 icu:451.00 pcu:2715.25 scu:433.75 ; in:6 out:8 type:b q:24.21 q-aq:22.80 q-noVbv:24.21 q-Rceq:0.99 tex:258433 mv:22466 misc:6381 icu:337.75 pcu:2954.25 scu:308.00 ; in:8 out:9 type:b q:24.21 q-aq:22.78 q-noVbv:24.21 q-Rceq:0.99 tex:212971 mv:24199 misc:6965 icu:322.75 pcu:2758.50 scu:518.75 ; Code:
in:0 out:0 type:I q:21.94 q-aq:19.57 q-noVbv:21.94 q-Rceq:0.99 tex:582913 mv:9220 misc:2973 icu:3600.00 pcu:0.00 scu:0.00 ; in:4 out:1 type:P q:21.94 q-aq:19.24 q-noVbv:21.94 q-Rceq:0.99 tex:614212 mv:13405 misc:3414 icu:3297.50 pcu:301.25 scu:1.25 ; in:2 out:2 type:B q:22.73 q-aq:20.71 q-noVbv:22.73 q-Rceq:0.99 tex:414031 mv:24937 misc:6025 icu:972.75 pcu:2444.75 scu:182.50 ; in:1 out:3 type:b q:23.52 q-aq:22.14 q-noVbv:23.52 q-Rceq:0.99 tex:271359 mv:22093 misc:6977 icu:381.75 pcu:2752.25 scu:466.00 ; in:3 out:4 type:b q:23.52 q-aq:22.18 q-noVbv:23.52 q-Rceq:0.99 tex:284787 mv:22011 misc:6353 icu:424.25 pcu:2814.50 scu:361.25 ; in:9 out:5 type:P q:21.94 q-aq:19.37 q-noVbv:21.94 q-Rceq:0.99 tex:589521 mv:12838 misc:3399 icu:3394.25 pcu:204.00 scu:1.75 ; in:7 out:6 type:B q:22.73 q-aq:21.31 q-noVbv:22.73 q-Rceq:0.99 tex:376395 mv:20908 misc:5391 icu:1138.75 pcu:2305.75 scu:155.50 ; in:5 out:7 type:b q:23.52 q-aq:22.15 q-noVbv:23.52 q-Rceq:0.99 tex:267303 mv:26748 misc:7184 icu:527.00 pcu:2682.50 scu:390.50 ; in:6 out:8 type:b q:23.52 q-aq:22.11 q-noVbv:23.52 q-Rceq:0.99 tex:305806 mv:22149 misc:6090 icu:502.00 pcu:2792.75 scu:305.25 ; in:8 out:9 type:b q:23.52 q-aq:22.21 q-noVbv:23.52 q-Rceq:0.99 tex:244590 mv:26586 misc:7529 icu:324.00 pcu:2809.75 scu:466.25 ;
14th May 2020, 02:41 | #116 | Link | ||
15th May 2020, 16:20 | #117 | Link | |||
Testeur de codecs
yes, my bad. I recheck my test and you are right. However I understood my error. For me, --pbratio 1.00 mean the same average quantizer for pframes and bframes. And it's the case for Npass mode but not for crf mode: - In crf mode Quote:
- In NPass mode Quote:
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 Last edited by Sagittaire; 15th May 2020 at 16:39. |
17th May 2020, 16:42 | #118 | Link | |
I guess the huge problem here is now that even the good denoisers can't be made to not remove any details if you use the strengths that are required to remove all the noise content. |
17th May 2020, 20:33 | #119 | Link |
Testeur de codecs
Well retain grain/noise is bitrate problem. All the codec can retain noise if you use suffisant bitrate for that. Retain grain is problem at low bitrate and at low bitrate, the codec itself remove detail/grain/noise. And soft denoising is not problem in this case simply because codec will make strong denoising by itself. For me FGM is really usefull in "low bitrate" situation exactly like for this "1000 kbps / 1080p" challenge encoding.
Le Sagittaire ... ;-) 1- Ateme AVC or x264 2- VP7 or RV10 only for anime 3- XviD, DivX or WMV9 Last edited by Sagittaire; 18th May 2020 at 11:26. |
21st May 2020, 22:42 | #120 | Link | |
