10th December 2008, 21:08 | #21 | Link | |
@Dark Shikari: one of the comments I got this from was:
don't remember where I got the other part from, but if you say p4x4 will cause no problem at all, I'll happily remove the restriction. Cu Selur |
10th December 2008, 21:20 | #22 | Link | |
x264 developer
In practice, not even the reference encoder abides by that rule. It is meaningless, and, quite literally, nobody cares. |
10th December 2008, 21:27 | #23 | Link |
Okay, just wanted to make sure that it wouldn't cause any incompatibilities.
-> I'll lift the restriction. --- Update: *changed* - allowing p4x4 at all levels see: http://forum.doom9.org/showthread.php?p=1222781 and following; in short: it's not standard conform, but nobody cares -> updated 1st post Last edited by Selur; 10th December 2008 at 22:09. |
10th December 2008, 22:33 | #24 | Link |
Mr. Sandman
megui still enforces the standard.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! |
10th December 2008, 23:11 | #25 | Link |
-> started a small poll to see what the community prefers, see: http://forum.doom9.org/showthread.php?t=143419
isn't much of a change to me anyway, so I'll go with the community there Cu Selur |
11th December 2008, 00:22 | #26 | Link |
ffx264/ffhevc author
@ Selur
Why fight about/discuss p4x4 so much? If my memory serves me correctly, pengvado (akupenguin here on doom9) once said that out of all partitions, p4x4 is the one that gives the least compression and basically has little to no benefit at all on a lot of content. Do you really think you will see noticeable effects both in compression and quality if you turn on p4x4 or disable it? My guess is you won't |
11th December 2008, 00:34 | #27 | Link |
The question is not if it helps with compression, it's whether one should care about standard conformity.
Since (I think) most people assume when they select a specific profile@level in a gui the output will meet the restrictions of this selection, I think it's a good idea to ask what people want if you don't deliver what they suspect. Cu Selur |
11th December 2008, 01:12 | #28 | Link |
you want standard conformity? then go find another encoder as x264 won't deliver full standard conformity no matter how much you tweak its options. It may come (very?) close to the standard but full conformity is out of the question at the moment. As Dark said, you will probably have to stop using cabac and probably a few other things
11th December 2008, 01:14 | #29 | Link | |
x264 developer
I doubt any other encoders care about such things either. |
11th December 2008, 01:26 | #30 | Link |
I prefer to stay close to standard, and not break it if I must not. I also like x264 and will use it further even when it might not be full standard conform. If you don't like that I see not how I could help.
I totally got Dark Shikaris point about p4x4 that if nobody cares about p4x4 restrictions it might be valid to use it. I just think it's a valid question to ask others that might want to use the gui I what they prefer. Seems like you don't care about any compatibility that's fine with me. Cu Selur |
11th December 2008, 05:24 | #31 | Link | |
thx for trying to help me. But its not working. Your 64bit bin 413 crashing on my 64er Etch. Seems to be there is a conflict with the libraries between kubuntu and Debian. I have also tried to compile the rev.413 with the same error. Code:
nwidget/NListWidget.cpp:8: error: ‘class NListWidget’ has no member named ‘removeItemWidget’ Pitti |
11th December 2008, 08:11 | #33 | Link |
This might cause a problem with zone and chapter option, since this might stop sx264 from clearing the chapters and zones.
Checking QT Documentation: "This function was introduced in Qt 4.3." -> I agree with Merlin7777, it might help of you update your qt version. iirc qt 4.3 was released around june 2007, 4.4 was released around may 2008, I don't think that I used any options that were introduced with 4.4 but 4.3 seems to be mandatory to run sx264. Cu Selur |
12th December 2008, 02:39 | #36 | Link | ||
Practising Schemer
audio mp2
I have tried all analysers but none will seem to accept mp2 input. FFmpeg appears to analyse all data and then errors no audio input.
12th December 2008, 09:12 | #37 | Link |
@Henrik: You might want to adjust your dpi to your monitor, seems like the font size hints are off.
@flebber: found the problem there's a small copy&paste error, will fix it and upload a new version later. Cu Selur Last edited by Selur; 12th December 2008 at 09:31. |
12th December 2008, 11:00 | #39 | Link |
rev415
*fixed* - some minor bugs with seperate audio stream handling *changed* - limit p4x4 usage again on default *added* - option to allow p4x4 for all levels *updated* - Windows package: new mplayer, ffmpeg, mediainfo, x264 -> updated 1st post Cu Selur |
12th December 2008, 15:57 | #40 | Link |
HDConvertToX author
please use another service provider for download like mediafire
here is locked your speedshare BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
