Old 21st October 2019, 09:30   #501  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Originally Posted by ChaosKing View Post
And if it helps. The problem is produced somewhere in contrahsrapening and not smdegrain: https://github.com/HomeOfVapourSynth...sfunc.py#L5406
It's a short script and the pink border still happens if you remove miniblur.
When I remove the only Expr line, the stripes disappear but the pink border is still there. Border could be Repair or MakeDiff. Will test later more.
EDIT
should this produce a pink image?
clip = core.std.BlankClip(width=200,height=100, format=vs.YUV420P8)
matrix1 = [1, 2, 1, 2, 4, 2, 1, 2, 1]
con = core.std.Convolution(clip, matrix=matrix1)
clip=core.std.MakeDiff(clip, con)
I've narrowed down the green lines. They happen with expr and 16 bit formats in the sse2 code path.
The script you posted definitely shouldn't be pink. For some odd reason it's not pink on my computer which should use exactly the same code path (threadripper 1950x).
Myrsloik is offline
Old 21st October 2019, 12:36   #502  |  Link
Are_
AMD Ryzen 7 1700 here and no pink image, only the green strips bug.
Are_ is offline
Old 21st October 2019, 13:02   #503  |  Link
ChaosKing
I tested now with the portable version and it only shows the green stripes. It seems I had still 48-test2 installed,.. I was sure it was the RC edition, sry
Installing the RC removed the pink border
At least my incompetence has found another bug
ChaosKing is offline
Old 22nd October 2019, 21:37   #504  |  Link
ChaosKing
Is it possible to port also FineDehalo_contrasharp? It returns a nice sharp image.
avs+ version
# level == 1.0 : normal contrasharp
Function FineDehalo_contrasharp (clip dehaloed, clip src, float level)
	bb  = dehaloed.RemoveGrain (11, -1)
	bb2 = bb.Repair (bb.Repair (bb.Medianblur (2, -256, -256), 1), 1)
	xd  = mt_makediff (bb, bb2)
	xd  = VersionNumber() < 2.6 ? xd.mt_lut ("x 128 - 2.49 * "+String(level)+" * 128 +")
              \                     : xd.mt_lut ("x range_half - 2.49 * "+String(level)+" * range_half +")
	xdd = mt_lutxy (
\		xd,
\		mt_makediff (src, dehaloed),
\		VersionNumber() < 2.6 ? "x 128 - y 128 - * 0 < 128 x 128 - abs y 128 - abs < x y ? ?"
\		                      : "x range_half - y range_half - * 0 < range_half x range_half - abs y range_half - abs < x y ? ?"
	dehaloed.mt_adddiff (xdd, y=3, u=2, v=2)
	xd  = xd.mt_lut ("x 128 - 2.49 * "+String(level)+" * 128 +")
	xdd = mt_lutxy (
\		xd,
\		"x 128 - y 128 - * 0 < 128 x 128 - abs y 128 - abs < x y ? ?"
Old 23rd October 2019, 03:40   #505  |  Link
HolyWu
Doesn't FineDehalo already have a contra parameter for contrasharpening?
HolyWu is offline
Old 23rd October 2019, 09:28   #506  |  Link
ChaosKing
lol I never noticed xD
But an external "dehalo contrasharp" is still usefull. It can be used with other dehalo functions.
Old 23rd October 2019, 09:45   #507  |  Link
HolyWu
I'd like to know how is the result compared to Didée's ContraSharpening function. Is it only suitable for denoising but not the others?
HolyWu is offline
Old 23rd October 2019, 10:08   #508  |  Link
ChaosKing
ContraSharpening adds halos back. It seems it is only usefull for denoised clips.
Old 6th March 2020, 03:10   #509  |  Link
poisondeathray
Does the overlay function work for RGBS ? It seems values are incorrect, but correct with maskedmerge
a = core.std.BlankClip(format=vs.RGBS, color=[1, 1, 1])
b = core.std.BlankClip(format=vs.RGBS, color=[2, 2, 2])
c = core.std.BlankClip(format=vs.RGBS, color=[0.5, 0.5, 0.5])
opacity = 0.5
msk = core.std.BlankClip(a, color=[opacity, opacity, opacity])
ov = haf.Overlay(a,b,opacity=0.5)
mm = core.std.MaskedMerge(a,b,mask=msk)
ov.set_output()
#mm.set_output()
For example, a,b with opacity 0.5 correctly gives RGB [1.5,1.5,1.5] with maskedmerge, but some error value for overlay
poisondeathray is offline
Old 6th March 2020, 04:38   #510  |  Link
HolyWu
Fixed.
HolyWu is offline
Old 6th March 2020, 21:50   #511  |  Link
poisondeathray
Fixed.
Thanks!
Would it be possible to add overlay blend modes? Such as "add", "multiply", "screen", etc..
Old 12th March 2020, 13:41   #512  |  Link
HolyWu
Added. But I don't see "screen" as one of the modes in http://avisynth.nl/index.php/Overlay
HolyWu is offline
Old 12th March 2020, 15:50   #513  |  Link
poisondeathray
Thanks!
"screen" is not in the overlay avs version, but it's one of the more common compositing/photoshop blend modes used
rr42 translated some here for uu_mt_blend based on maskttools, and there are some links to the math behind them in the 1st post. I don't think that version supports different bit depths
https://forum.doom9.org/showthread.php?t=170490
https://photoblogstop.com/photoshop/...odes-explained
Screen
1−(1−A)×(1−B)
A inverted multiplied by B inverted, and the product is inverted
Old 25th March 2020, 05:50   #514  |  Link
poisondeathray
YUV overlay mask transparency issue
YUV overlay mask transparency issue. Partial transparency issue on 100% white areas
-affects YUV overlay operations in 10bit, different subsamplings.
-RGB overlay operations seem ok
-does not matter if you mark YUV versions as "limited" range or "full"
-Works ok if you use Gray8 for the mask, and base clip / overlay clip are matching 8bit YUV ; or Gray16 and base/overlay are matching 16bit YUV . But there is no Gray10 format, so 10bit YUV overlay with mask is out of luck, or 12bit YUV
-works as expected if you go back to older havsfunc version a few months ago, with matching pixel format YUVxxxPx mask instead of using GRAYx mask. Not sure where the exact commit altered it, possibly the recent ones
eg.
import vapoursynth as vs
import havsfunc as haf
core = vs.get_core()
orig = core.imwri.Read(r'testchart.png')
logo = core.imwri.Read(r'logo.png', alpha=True)
orig2 = core.resize.Bicubic(orig, format=vs.YUV420P10, matrix_s="709")
logobase2 = core.resize.Bicubic(logo[0], format=vs.YUV420P10, matrix_s="709", range_s="full")
logoalpha2 = core.resize.Bicubic(logo[1], format=vs.YUV420P10, matrix_s="709", range_s="full")
#logoalpha2 = core.std.SetFrameProp(logoalpha2, prop="_ColorRange", intval=1)  #    Mark video as limited range.
#logoalpha2 = core.resize.Bicubic(logo[1], format=vs.GRAY8, matrix_s="709", range_s="full")
#RGB24, RGB30, RGB48 work ok
#orig2 = core.resize.Bicubic(orig, format=vs.RGB30)
#logobase2 = core.resize.Bicubic(logo[0], format=vs.RGB30)
#logoalpha2 = core.resize.Bicubic(logo[1], format=vs.RGB30)
overl = haf.Overlay(orig2, logobase2, mask=logoalpha2)
overl.set_output()
Test images
https://www.mediafire.com/file/vy6k8...mages.zip/file
Old 25th March 2020, 08:06   #515  |  Link
HolyWu
Thanks. Should be fixed now (rebased into the last commit).
You can use core.register_format for formats without constants predefined.
logoalpha2 = core.resize.Bicubic(logo[1], format=core.register_format(vs.GRAY, vs.INTEGER, 10, 0, 0).id, matrix_s="709", range_s="full")
HolyWu is offline
Old 25th March 2020, 16:46   #516  |  Link
poisondeathray
Thanks for the fix and the info HolyWu . Didn't know about core.register_format
Old 25th March 2020, 17:11   #517  |  Link
poisondeathray
Sorry, it doesn't seem "fixed" . Same script as above
Or are you saying you should always use GRAY, and with core.register_format if it's not a predefined format ?
Old 25th March 2020, 18:08   #518  |  Link
HolyWu
These are my results.
logobase2 = core.resize.Bicubic(logo[0], format=vs.YUV420P10, matrix_s="709")
overl.set_output()
overl.set_output()
HolyWu is offline
Old 25th March 2020, 18:22   #519  |  Link
poisondeathray
It's correct. Sorry for false alarm
It turns out wrong havsfunc.py version was loading
Thanks again
Old 25th March 2020, 21:30   #520  |  Link
sl1pkn07
Pajas Mentales...
offtopic
dat logo. where?
greetings
EDIT: done! http://forum.doom9.net/showthread.ph...72#post1847472
[AUR] Vapoursynth Stuff
[AUR] Avisynth Stuff
sl1pkn07 is offline
