8th April 2008, 03:36 | #201 | Link |
Sleepy overworked fellow
I'm using FixblendIVTC on a VHS capture and it works very well to detect the blends and make the clip ready for decimation, but I'm having problems with the postprocessing... I tried the suggested deen, but couldn't get satisfying results. Does anyone know a good plugin/script that could help?
15th May 2008, 17:41 | #202 | Link |
I'm trying FixBlendIVTC on an old film, and I'm having problems encoding it. The first time I encoded, each scene change would be erratic. Say I had abcde. The encode would show abdce. I went back and framestepped through, and it was fine. Any ideas what's causing this? I'm just using a regular script.
fixblendivtc() decimate() |
16th May 2008, 04:00 | #203 | Link |
Could you upload a short sequence that gets messed up after fixblendivtc? I'd be easier for us to reproduce your issue.
AnimeIVTC() - v2.00 -http://boinc.berkeley.edu/- Let all geeks use their incredibly powerful comps for the greater good (no, no, it won't slow your filtering/encoding :p) |
16th May 2008, 18:36 | #204 | Link |
@anonova
You can put RequestLinear(8, 5, 5, false, false) between FixBlendIVTC and decimate. If this doesnīt work doing a lossless first (extra) pass and encode the lossless file. Hope this works. @thetoof Without a sample I canīt give you a better advice for the postprocessing. |
15th June 2008, 13:21 | #205 | Link |
Hi, I have source which I anlyze with VDM and I see some 2 interlace frame and 3 prograsive frame, when I see the 2 interlace frame they are also dublacate, hopefully I'm right?
sample is this a TELECINE source with field blended? and how should I deal with this type of source? |
15th June 2008, 17:56 | #207 | Link |
Yes, and I'd add that if you have aliasing as there was in this thread, you could use the even more precise (but slower) field matching in post #11.
15th June 2008, 20:01 | #208 | Link |
Immersion & thetoof Thanks alot guys for the replay. Immersion when i analyzed my source with MeGUI, that automaticly suggest tfm()
tdecimate(). Which I don't want to use it, coz I want to learn the better way for dealing with this type of source. @ thetoof I will give it try when I get home. O. Can we use Cdeblend for this purpose? if not then, for which purpose we can use it? Thanks in Advance Thanks. Last edited by Vesi; 16th June 2008 at 02:25. |
16th June 2008, 04:59 | #209 | Link | |
16th June 2008, 13:49 | #210 | Link | |
ffdshow/AviSynth wrangler
Since there's no blending in the fields of the VOB you posted it simply doesn't make sense to use something like CDeblend...
now playing: [artist] - [track] ([album]) |
22nd June 2008, 21:13 | #211 | Link |
I'm trying to encode an anime which has many blends among other problems. I tried AnimeIVTC and MRestore for fighting the blends. I am happy with MRestore but I get some frames with these errors:
Vob sample: http://www.mediafire.com/?hddyclbhy32 Script reduced just to the MRestore part. I get an error like in the screenshot above just using this: Code:
Import("D:\AviSynth 2.5\plugins\MRestore.avs") DGDecode_mpeg2source("I:\sample.d2v",info=3) interp=nnedi(-2) yadifmod(mode=1, edeint=interp) Mrestore(mode=0, numr=2002, denm=5005, chroma=true, dup=1) Last edited by elguaxo; 22nd June 2008 at 23:39. |
23rd June 2008, 20:56 | #212 | Link |
I updated mrestore to version 2.3d and bob_repair to version 0.4.
Download link in my first post. @elguaxo Thanks for the report. I fixed the bug. Using a faster bobbing for dclip will speed-up your script. Last edited by MOmonster; 23rd June 2008 at 21:09. |
9th July 2008, 19:14 | #215 | Link |
Fighting spam with a fish
I added Cdeblend to the wiki. I will try and get to Mrestore some time today.
FAQs:Bond's AVC/H.264 FAQ Site:Adubvideo Zsmooth - Cross-platform smoothing for Vapoursynth |
3rd August 2008, 10:44 | #217 | Link |
When I try to use mrestore() in my script (trying to convert 60i to 25p) I get this error:
ChangeFPS: Ratio must be less than 10 for linear access. Set LINEAR=False. Naturally I tried setting linear=false but then the script became useless as it crashed every time. My script: import("C:\Program Files\AviSynth 2.5\plugins\mrestore.avs") DirectShowSource("E:\TDL-Folder\bdg\BDMV\STREAM\g1.grf",audio=false) mrestore() |
3rd August 2008, 17:52 | #218 | Link |
Angel of Night
Are you sure that it's actually coming in as 60i? Replacing mrestore with info() should give you 30 fps for the framerate, if not then you need to specify that in directshowsource. And don't forget to specify the final framerate in mrestore.
18th August 2008, 18:36 | #220 | Link | |
I thought the latest version (mrestore v2.3e?) no longer supported final framerate specification? It there some place to download the prior versions - sometimes I would like to go back to that, but I didn't keep a local copy smekoslav FYI - I got this error when I had a typo in the numerator - doesn't seem to apply to your case, but thought I would mention it |
mrestore, srestore |
