Old 13th September 2010, 21:07   #61  |  Link
MyCometG3
Originally Posted by shroomM View Post
Is there any way to set the nal hrd parameter, withour activating BD tunings?
Currently, if you specify two vbv parameters, --nal_hrd vbv is applied implicitly.
Here is patch snippet, implicit setting part for libx264.c.
+    /* Modify non-gui-supported parameters */
+    if (x4->params.rc.i_vbv_buffer_size && x4->params.rc.i_vbv_max_bitrate) {
+        x4->params.i_nal_hrd = X264_NAL_HRD_VBR;
+    if (x4->params.b_interlaced) {
+        x4->params.b_pic_struct = 1;
+    if (p && p->BD_TUNE) {
+        x4->params.i_bframe_pyramid  = X264_B_PYRAMID_STRICT;
+        x4->params.i_slice_count = 4;
+        x4->params.i_open_gop = x4->params.i_open_gop ? X264_OPEN_GOP_BLURAY : X264_OPEN_GOP_NONE;
MyCometG3 is offline   Reply With Quote
Old 14th December 2011, 21:50   #62  |  Link
BigPines
Great plugin! Thank you so much for all your hard work.
I am planning to use this for exporting from CS5 Premier on 10.7.2. However, I am a bit confused by some of the setting descriptions in the advanced section and the interaction between settings.
What I would like to do is replicate the following settings for Blu-ray encoding:
--bitrate 35000 --preset veryslow --tune film --bluray-compat --vbv-maxrate 40000 --vbv-bufsize 30000 --level 4.1 --keyint 24 --open-gop --slices 4 --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1 --pass 1 (or --pass 2) -o out.264 input.file
Would it be possible to add a text box that would override all the GUI settings and simply pass the parameters (like those above) directly to x264? This would be an extremely flexible option.
Mike
BigPines is offline   Reply With Quote
mac os x, quicktime, x264encoder
