#41 | Link | |
AMD Launches Ryzen 7000 Series Desktop Processors
#42 | Link | |
When I hit pause in Kodi the grain still "moves" lol I use Kodi 19 dev btw.
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository Last edited by ChaosKing; 6th September 2022 at 20:27. |
#43 | Link | |
LG C2 OLED | GitHub Projects |
#45 | Link |
![]() Join Date: Jan 2006
Sounds like the FGS filter keeps running even when the video stops. Since it's an out-of-loop postprocessor, that sort of thing isn't unprecedented. In the implementations I'm aware of, the FGS filter isn't even part of the codec itself, and can be triggered by the same SEI metadata in other codecs as well.
#46 | Link | |
(It's true that encoders like aomenc don't choose a specific seed based on reconstruction characteristics, they just randomly generate a number. But in theory, an encoder could select a seed expecting a particular reconstruction, and that's what I'd expect to see in the decoder as well then.) |
#47 | Link | |
Not sure who to blame here. The fire stick decoder or Kodi.
AVSRepoGUI // VSRepoGUI - Package Manager for AviSynth // VapourSynth VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository |
#48 | Link | |
#49 | Link |
FWIW sometimes pausing has dancing grain, sometimes it doesn't.
#51 | Link | |
Sometimes there's also a frame skip after pause. I use Kodi but it makes use of MediaCodec. This is the 4K Max, OS is 7.2.9.2 (PS7292/2984). I'm not sure what other model number there is, other than the serial number.
LG C2 OLED | GitHub Projects Last edited by quietvoid; 20th September 2022 at 18:34. |
#52 | Link | |
#53 | Link |
The build I have installed is from 2022-09-10 git, which was after the last tagged alpha.
So unless it was fixed in git in the last 10 days, it still happens even if rarely.
#55 | Link |
a new 'chromecast with google tv' has been released which uses the S805X2 chipset which can hardware decode av1. The chipset can only output 1080p not 4k, for all codecs not just AV1. Google's cast codec support page (https://developers.google.com/cast/docs/media) doesn't show this new model so not sure if AV1 decoding is enabled or not but the hardware should be capable of it.
#56 | Link |
Nvidia 4000 RTX series supports AV1 hardware encoding up to 8k60p: https://www.neowin.net/news/nvidia-r...google-chrome/
#57 | Link | ||
8k60 is not perfect but they might improve it with newer drivers. Quote:
#58 | Link | |
Live sports is much more interested in high frame rates, so I expect 4Kp120 to be a much bigger deal than 8Kp60 over the next 5+ years. |
#59 | Link |
I would take "dual engines" more like "can work on two streams at the same time without performance loss", not necessarily "twice as fast on one stream", so I wouldn't automatically say its a clear bug, unless NVIDIA has specifically stated otherwise.
Also while of course relevant because its used on eg. YouTube, in my experience browsers are not the best choice to fully explore hardware capabilities. Not sure if thats the test methodolgy (like not excluding the first second of startup glitches), but not even able to produce fully fluid 4K 60 fps is either a software or a testing failure, because a dedicated video player certainly can render 4k 60 fps without any frame drops.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 1st November 2022 at 09:44. |
#60 | Link | |
Exactly, on my Arc A380 and also my Iris Xe only one of the two decoder is working in this video. The second decoder won't give extra performance on a single video, obviously same for RTX 4090. ![]() |
av1, av1 hardware decode, hardware decoders |
