Old 16th August 2019, 21:44   #481  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I'll have to try updating all the plugins and stuff, maybe there is something causing it.
Boulder is offline
Old 17th August 2019, 02:25   #482  |  Link
lansing
I can reproduce it with earlier vs version, it is okay with newest version.
lansing is offline
Old 17th August 2019, 10:35   #483  |  Link
Boulder
Pig on the wing
Boulder's Avatar
That's true. I just upgraded from R47 to R47.2 and it's gone
Boulder is offline
Old 17th August 2019, 20:48   #484  |  Link
Mystery Keeper
Beyond Kawaii
Mystery Keeper's Avatar
Same issue I had with mxNet. Yes, VS 47.2 fixes it.
...desu!
Mystery Keeper is offline
Old 1st September 2019, 21:29   #485  |  Link
fAy01
Thanks for filling my previous requests. Would you consider porting InpaintDelogo https://forum.doom9.org/showthread.php?t=176860 ? Furthermore, I'm interested to see how it'd perform against logoNR.
Also, please port SmoothD2 to as well. http://avisynth.nl/index.php/SmoothD2 <-- SmoothD2 performs better than other deblocking plugin and scripts (DeblockPP7, deblock_qed, and AutoDeblock).
fAy01 is offline
Old 2nd October 2019, 05:02   #486  |  Link
poisondeathray
overlay bug ?
Overlay bug? havsfunc r32
A foreground clip smaller in dimensions than the background clip, cuts out with black to fill the height
avisynth
https://i.postimg.cc/6pNPV4nf/overlay-avs.png
vapoursynth
https://i.postimg.cc/zX3DmMcc/overlay-vpy.png
avs
fg=blankclip(1,1024,640,"RGB24",color=color_darkred)
bg=blankclip(1,1280,720,"RGB24",color=color_gray)
overlay(bg,fg)
vpy
fg = core.std.BlankClip(width=1024, height=640, format=vs.RGB24, fpsnum=24, fpsden=1, length=1, color=[139, 1, 0])
bg = core.std.BlankClip(width=1280, height=720, format=vs.RGB24, fpsnum=24, fpsden=1, length=1, color=[128, 128, 128])
overl = haf.Overlay(bg, fg)
overl.set_output()
EDIT: also, x=, y= positioning do not seem to work in vpy overlay (e.g. x=20, y=20) - it just returns the bg clip; but works ok in avisynth
poisondeathray is offline
Old 2nd October 2019, 08:16   #487  |  Link
HolyWu
It likely is a MaskedMerge bug introduced in VS R47. Try again with VS R46.
HolyWu is offline
Old 2nd October 2019, 15:32   #488  |  Link
poisondeathray
Works with R46.
Old 2nd October 2019, 15:47   #489  |  Link
_Al_
for overlay you can use this overlay function (based on our discussion on ramping), I just simplified that, no moduls needed only numpy.
avantages: much faster, YUV does not need to be converted to 444, numpy does it on the fly even chroma resolutions, works with any vs format
cons: numpy modul needed
formats needs to be the same though, also make sure the lengths are same, and there is enough room for pasting pip did not troubleshoot that:
import vapoursynth as vs
from vapoursynth import core
import numpy as np
file1 = r'C:\path\background.mp4'
file2 = r'D:\path\pasted_video.avi'
X1,Y1 = (100,100)
clip = core.ffms2.Source(file1)
pip = core.ffms2.Source(file2)
#make sure clips have the same format and lenght, then continue
def overlay(clip, pip, X1, Y1):
    pl = clip.format.num_planes
    if clip.format.name == 'CompatBGR32':
        Y1 = clip.height - (Y1 + pip.height)       #Y is mirrored
    X2,Y2 = (X1 + pip.width, Y1 + pip.height)
    #shifting 0,1 or 2 to get chroma coordinates, equivalent of dividing Y plane coordinates by 1,2 or 4
    X1CH,Y1CH  = (X1 >> clip.format.subsampling_w, Y1 >> clip.format.subsampling_h)
    X2CH,Y2CH  = (X2 >> clip.format.subsampling_w, Y2 >> clip.format.subsampling_h)
    def pip_func(n,f):
        fout = f[0].copy()
        for p in range(pl):
            plane     = np.asarray(f[0].get_read_array (p))
            rectangle = np.asarray(f[1].get_read_array (p))
            plane_out = np.asarray(fout.get_write_array(p))
            if p:  plane[Y1CH:Y2CH, X1CH:X2CH] = rectangle    #p=1,2   U,V plane
            else:  plane[Y1:Y2, X1:X2]         = rectangle    #p=0     Y plane
            np.copyto(plane_out, plane)            #writing np.array plane into vapoursynth._memoryviewslice
            del plane_out
        return fout
    return core.std.ModifyFrame(clip, [clip,pip], pip_func)
clip = overlay(clip, pip, X1, Y1)
clip.set_output()
_Al_ is online now
Old 2nd October 2019, 16:04   #490  |  Link
poisondeathray
Thanks _Al_ ;
I don't "need" it right now in terms of some pressing engagement ; but there are some functions and scripts that rely MaskedMerge and/or Overlay that are probably broken in R47.x
If that method is better in terms of pros/cons , maybe it can be implemented in vapoursynth core, maskedmerge, or havsfunc overlay ?
Old 2nd October 2019, 16:20   #491  |  Link
_Al_
To be fully replaceable, opacity and mask arguments would need to be added. Havsfunc.Overlay offers arguments like that, in a sense if there is no opacity it might not be calledd overlay (as I named that function). It would involve some numpy calculations to achieve that. But MaskedMerge is a vs function, so it is fast, it would be interesting to compare it speed wise.
_Al_ is online now
Old 20th October 2019, 20:46   #492  |  Link
ChaosKing
Contrasharpen and smdegrain(contrasharp=True) produce a pink border. VS R48 RC1
clip = core.std.BlankClip(format=vs.YUV420P8)
clip=haf.SMDegrain(clip, contrasharp=True)
ChaosKing is offline
Old 20th October 2019, 21:07   #493  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
I can't reproduce it. Using the vsrepo version of everything. Try adding vs.core.std.SetMaxCPU("none") to the start of the script on your end.
Myrsloik is offline
Old 20th October 2019, 22:48   #494  |  Link
ChaosKing
The pink border disappears with SetMaxCPU("none"). My cpu is a ryzen 2600
With SetMaxCPU("avx2") and "sse2" it's still pink.
EDIT
With BlankClip(format=vs.YUV420P16) (and 420P10) it's the same, except that sse2 produces vertical stripes.
EDIT
422, 444 is also affected.
Old 21st October 2019, 07:42   #495  |  Link
l00t
Where's my loot?
bbmod also seems to be affected, it was OK with R47.2 and broken in R48-RC1
(tested with YUV420P8, YUV444P16 and YUV420P16)
l00t is offline
Old 21st October 2019, 08:11   #496  |  Link
Myrsloik
Myrsloik's Avatar
I still can't reproduce it. What are you using to view the output?
Myrsloik is offline
Old 21st October 2019, 08:39   #497  |  Link
l00t
Where's my loot?
VapourSynth Edtior r19
l00t is offline
Old 21st October 2019, 08:46   #498  |  Link
ChaosKing
vsedit r19
import mvsfunc as mvf
import havsfunc as haf
core = vs.core
clip = core.std.BlankClip(width=200,height=100, format=vs.YUV420P8)
sm=haf.SMDegrain(clip, contrasharp=True) # havsfunc from master
clip=core.std.StackHorizontal([clip.text.Text("blank"), sm.text.Text("smdegrain +\ncontrasharp \ncpu default/not set")])
clip2 = core.std.BlankClip(width=200,height=100, format=vs.YUV420P8)
sm=haf.SMDegrain(clip2, contrasharp=True) # havsfunc from master
clip2=core.std.StackHorizontal([clip2.text.Text("blank"), sm.text.Text("smdegrain +\ncontrasharp cpu none")])
c=core.std.StackVertical([clip, clip2])
vs.core.std.SetMaxCPU("sse2")
clip3 = core.std.BlankClip(width=200,height=100, format=vs.YUV420P16) #16!
sm=haf.SMDegrain(clip3, contrasharp=True) # havsfunc from master
clip3=core.std.StackHorizontal([clip3.text.Text("blank"), sm.text.Text("smdeg + contrasharp \ncpu sse2 16bit")])
c=core.std.StackVertical([c, mvf.Depth(clip3, 8)])
c.set_output()
Old 21st October 2019, 08:58   #499  |  Link
Myrsloik
Myrsloik's Avatar
Nice, that manages to reproduce the green stripes. Oddly enough the pink border doesn't happen on my system.
Myrsloik is offline
Old 21st October 2019, 09:19   #500  |  Link
ChaosKing
And if it helps. The problem is produced somewhere in contrahsrapening and not smdegrain: https://github.com/HomeOfVapourSynth...sfunc.py#L5406
It's a short script and the pink border still happens if you remove miniblur.
When I remove the only Expr line, the stripes disappear but the pink border is still there. Border could be Repair or MakeDiff. Will test later more.
EDIT
should this produce a pink image?
matrix1 = [1, 2, 1, 2, 4, 2, 1, 2, 1]
con = core.std.Convolution(clip, matrix=matrix1)
clip=core.std.MakeDiff(clip, con)
EDIT2
mode=0 -> green image. So I guess the pink border comes from MakeDiff.
EDIT3
This is how it looks in R47
