2nd August 2008, 05:59 | #2001 | Link | ||
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 2nd August 2008 at 06:11. |
10th August 2008, 15:18 | #2002 | Link |
I have questions about the advanced options
Auto correct crop values (don't disable!) Auto aspect ration signalin (don't disable!) I wonder why shouldn't these be disabled? Perhaps it's better if I explain my goal. I'm trying to rip a very old movie from DVD and it's in 4:3 ratio, i.e. a square old regular TV image. And now all I got is Widescreen TV's. So when I'm about to crop the DVD it on the sides to the remove "the black". It crops to much.. I wonder how am I to do if I want my cropping to be exactly as i choose it in the crop window? Why is it so important that it's correct aspect ratio? It's a 4:3 movie, It's going to be stretched anyway...so? |
10th August 2008, 21:40 | #2003 | Link |
I'm new to StaxRip, and currently I'm trying to configure it. But there is problem I couldn't solve. For BeSweet configuration I receive "There is a problem with the bsn library.".
I tried StaxRip 1.1.1.0 and latest beta, BeSweet 1.4 and 1.5b31. What should I do? Last edited by Grossmeister; 10th August 2008 at 21:43. |
10th August 2008, 22:03 | #2004 | Link | ||
11th August 2008, 00:48 | #2005 | Link |
11th August 2008, 08:50 | #2007 | Link |
@Grossmeister
Didn't StaxRip ask to download BeSweet with the internal download feature? Please post the exact error/warning (the image attachment wasn't approved, please use 2shared.com instead of forum attachments) or the first sentence of it if it's too long. @Raboo I don't know a guide explaining this in detail but it's discussed in the forum extensively, please use the forum search entering the following two words together in arbitrary order using default search options: overcrop mod
11th August 2008, 11:49 | #2008 | Link | |
11th August 2008, 13:28 | #2009 | Link | |
11th August 2008, 14:56 | #2011 | Link | |
11th August 2008, 17:33 | #2012 | Link |
Just a note, Microsoft has released Net Framework 3.5 SP1, since Staxrip uses Net framework thought it might be worth mentioning
This also updates Net framework 2 and 3 as its inclusive, so both of these are now Net Framework 2.0 SP1 and Net Framework 3.0 SP1! Separate Visual C++ Runtimes have also been updated to SP1 versions, so install these too - x64 users should install both the x86 and x64 versions. |
11th August 2008, 18:35 | #2014 | Link |
From what I understand the x64 version is for x64 programme support and the x86 is for 32 bit programme support 32 bit programmes can't use the 64 bit runtime! Therefore, on x64, you need to install both. Actually since most programmes are x86, its probably more important to install the x86 version! The x64 version doesn't install the x86 version along with it, hence why it allows you to install the x86 without saying its not designed for the particular system for which you are installing it on.
11th August 2008, 19:56 | #2015 | Link |
When I click "Download" in StaxRip menu it starts to download 7-z - I have 7-z 4.57, StaxRip says that it doesn't know this version of 7-z and starts to download 4.57 again (!). This is some kind of joke. Can I fix only problem with BeSweet?
By the way, when I click "Tools"->"Download with Browser" StaxRip is opening link to 1.5b31 download. OK, finally I just downloaded BeSweet from StaxRip website, and this 1.5b31 really has different bsn.dll. Last edited by Grossmeister; 11th August 2008 at 21:11. |
12th August 2008, 10:50 | #2016 | Link |
Najarenthur
@burfadel
Hmm... I'm afraid, I always thought, you can use .NET programs with both runtimes. Maybe it was just wishful thinking. Of course I never tested it nor I asked it, but I never read anything about it too. It seems I have something to research for. |
14th August 2008, 17:12 | #2018 | Link | |
Seems like staxrip wont run on my pc... =( |
14th August 2008, 22:57 | #2019 | Link |
I am having a problem with mp4box muxing. It appears that it can not load my subtitles. Here is the log.
============================================================== ------------------------------------------------------------ Muxing ------------------------------------------------------------ "C:\Documents and Settings\Trey Weaver\Local Settings\Application Data\StaxRip\Applications\MP4Box\MP4Box.exe" -fps 23.976 -add "D:\aa-Rips\MainMovie\SP\VIDEO_TS\SP.zsxq21_EncoderOutput.264#video:name=Video" -add "D:\aa-Rips\MainMovie\SP\VIDEO_TS\VTS_01_1 01 en-English 3_2ch 448Kbps DELAY -212ms_AudioOutput.mp4:lang=eng:name=English" -add "D:\aa-Rips\MainMovie\SP\VIDEO_TS\VTS_01_1.idx#1" -add "D:\aa-Rips\MainMovie\SP\VIDEO_TS\VTS_01_1.cc.srt:lang=eng" -add "D:\aa-Rips\MainMovie\SP\VIDEO_TS\VTS_01_1.cc.utf8.srt:lang=eng" -add "D:\aa-Rips\MainMovie\SP\VIDEO_TS\VTS_01_1.cc.utf16le.srt:lang=eng" -add "D:\aa-Rips\MainMovie\SP\VIDEO_TS\VTS_01_1.cc.utf16be.srt:lang=eng" -new "E:\SP.zsxq21.mp4" AVC-H264 import - frame size 640 x 272 at 23.976 FPS Import results: 131461 samples - Slices: 1609 I 55665 P 74187 B - 1 SEI - 1565 IDR Stream uses B-slice references - max frame delay 2 IsoMedia import - track ID 1 - Audio (SR 48000 - 2 channels) VobSub import - subpicture stream 'eng' Timed Text (SRT) import - text track 640 x 272, font Serif (size 18) Timed Text (SRT) import - text track 640 x 272, font Serif (size 18) Timed Text (SRT) import - text track 640 x 272, font Serif (size 18) Error importing D:\aa-Rips\MainMovie\SP\VIDEO_TS\VTS_01_1.cc.utf16be.srt:lang=eng: Feature Not Supported ------------------------------------------------------------ Error ------------------------------------------------------------ MP4 muxing failed Last edited by weaver4; 14th August 2008 at 23:35. |
15th August 2008, 08:45 | #2020 | Link |
HDConvertToX author
try renaming subs with a simplier name not with a triple point name
BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
gui, h.264, h.265, hevc, mkv, x264, x265 |
