Old 24th March 2023, 19:43   #31421  |  Link
SuperFist
SuperFist's Avatar
Like I posted, use NVENCCRE with a bitrate of 15 Mbps to create a new MKV file that is smaller.
Thanks for your response.
How do I utilize it? From within BD Rebuilder? Do I replace the native NVEncC.exe file there?
I was simply experimenting, hoping to reverse the process and go from REMUX to UHD Blu-ray folder structure and then to a smaller file size. However, the program apparently does not like if the 4K Blu-ray structure isn't from the original disc, since tsMuxeR cannot fix it to work properly with BDRebuilder.
SuperFist is offline   Reply With Quote
Old 24th March 2023, 19:59   #31422  |  Link
MrVideo
MrVideo's Avatar
You don't. It is a separate tool. Search his thread for info about it and where to download it from.
Keep in mind, like BDRebuilder, you need a compatible nVidia card in order to do hardware encoding. Otherwise the software encoding will take many, many, hours.
Old 24th March 2023, 20:05   #31423  |  Link
MrVideo
MrVideo's Avatar
That is just way too many steps for a simple job.That is where the standalone program comes in handy.
Old 24th March 2023, 20:06   #31424  |  Link
SuperFist
SuperFist's Avatar
Thank you, kind sir!
For anyone following along, this is what is being referred to with the link included in the post:
NVENCC does all the work if you pass it the appropriate command line parameters. I just recompiled NVENCCRE.exe and here is a version that supports reencoding with the HDR characteristics.
I didn't add support for HDR10+ until I test it a little. I'm trying to decide whether NVENCC's experimental setting is stable enough to add it.
Old 24th March 2023, 20:50   #31425  |  Link
SuperFist
SuperFist's Avatar
I figured out how to use NVENCCRE.
Thank you so much, MrVideo!
Old 25th March 2023, 00:21   #31426  |  Link
MrVideo
MrVideo's Avatar
You are welcome.
Old 27th March 2023, 05:29   #31427  |  Link
Mark_Venture
SuperFist, post you link to was from Dec 2021.
But BD-Rebuilder 0.61.28 in the first Post of this thread includes NVENCCRE and appears to be dated April 2022.
Is there any difference??
Old 28th March 2023, 03:52   #31428  |  Link
MrVideo
MrVideo's Avatar
The version I have is 0.10.7.
Old 10th April 2023, 10:46   #31429  |  Link
thebuff
Hi all, wondered if someone could help; I've been using BD Rebuilder for many years without issue, but recently a back-up hasn't worked as normal (or at least I don't think it has). The original movie, when ripped, was split into 14 files - this seems to happen on certain movies for some reason. When I went through my normal process with BD Rebuilder, it created the correct file size (as per my normal settings) but still split into 14 files - I'm pretty sure it used to recompile (if that is the right word) into one file.
It feels like I have a setting wrong, or maybe one of the external components incorrectly configured - I haven't reinstalled as yet, thought I'd ask here first?
Many thanks for your help.
thebuff is offline   Reply With Quote
Old 10th April 2023, 12:51   #31430  |  Link
gonca
Your movie might have fit without encoding. The disc should work fine, but if you wish you can use FORCE_ENCODE=1 in your configuration file.
Old 10th April 2023, 22:28   #31431  |  Link
MrVideo
MrVideo's Avatar
There are many movies that are more than one part on the disc. That could be for several reasons. One of the reasons is burned-in on-screen text in different languages, i.e., the title of the movie, the cast and the closing credits. Another is for a strange way of doing copy protection, which I won't go into trying to explain here. The biggest reason is a release with two versions: theatrical and extended.
If the size of the movie fits on a 25 GB disc, there won't be a need to recompile. It will just be assembled into a single file.
I seriously doubt that reinstalling will fix it.
Since we have no clue as to what the movie is, further assistance is a little difficult to provide. Output log from BDRB and MediaInfo information about the original files would be a plus. Be sure and code wrap those listings when posting.
Old 11th April 2023, 09:05   #31432  |  Link
thebuff
Many thanks both - sorry I wasn't clear, I'm not backing these up onto a disc, just onto my PC for playback on Kodi. They play fine, I just have to possibly rename them to play correctly - nothing to do with BD Rebuilder.
But it's just that until recently no other movies have done this before - they've all recomplied as a single file, so I was a bit confused.
I'll try force encode next time i backup a movie that is split into several parts.
Many thanks
Old 12th April 2023, 13:46   #31433  |  Link
MrVideo
MrVideo's Avatar
You should be able to copy all of the M2TS files into a single file.
Old 20th April 2023, 06:48   #31434  |  Link
jetli
Hi, I recently build a new system with a 13900K processor running on Windows 11.
I ran my first real encode now.
It failed and aborted.
Is there something I'm not doing right?
Here are the logs ... PLEASE HELP ...Is there something wrong?
1) BD-REBUILDER.LOG
[02/07/23] Checking System Settings
- BD-Rebuilder v0.61.28
- Windows Version: 6.2 [9200]
- Working Path Free Space: 362.86GB
- AVISYNTH Version: 2.6.0.6, Ok
- LAVFILTERS: Ok
- X264: Ok
- X265: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
[02/07/23] Systems Settings Check complete
[04/20/23] BD Rebuilder v0.61.28
[00:46:44] Source: THE_AGE_OF_INNOCENCE_BD50_CC_00001
- Input BD size: 34.29 GB
- Approximate total content: [02:18:38.727]
- Target BD size: 23.96 GB
- MOVIE-ONLY mode enabled
- Resize: SD to HD 1080 enabled
- Quality: Better (Faster), Two Pass
[00:46:44] PHASE ONE, Encoding
- [00:46:44] Processing: VID_00274 (1 of 1)
- [00:46:44] Extracting A/V streams [VID_00274]
- [00:49:43] Reencoding video [VID_00274]
- Rate/Length: 23.976fps, 199,450 frames
- Bitrate: 18,751 Kbs
- [00:49:43] Reencoding: VID_00274, Pass 1 of 2
- [01:00:30] Reencoding: VID_00274, Pass 2 of 2
- Encode failed. Aborting.
- Working Path Free Space: 353.09GB
- LAVFILTERS: Ok
- X264: Ok
- X265: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
[01:03:42] - Failed video encode, aborted
2) LASTCMD.TXT
"C:\Program Files Uninstalled\BD_Rebuilder\tools\x264.exe" "J:\BD_REBUILDER PROCESSING\WORKFILES\VID_00274.AVS" --preset faster --bluray-compat --b-pyramid none --weightp 1 --qpmin=0 --bitrate 18751 --level 4.1 --qpfile "J:\BD_REBUILDER PROCESSING\WORKFILES\VID_00274.CHP" --sar 1:1 --aud --nal-hrd vbr --pic-struct --vbv-bufsize 30000 --keyint 24 --min-keyint 1 --ipratio 1.1 --pbratio 1.1 --vbv-maxrate 35000 --threads auto --slices 4 --thread-input --stats "J:\BD_REBUILDER PROCESSING\WORKFILES\VID_00274.AVS.264.stats" --pass 2 --output "J:\BD_REBUILDER PROCESSING\WORKFILES\VID_00274.AVS.264"
3) BDREBUILDER.INI
[Options]
VERSION=0.61.0.28
ENCODER=0
MODE=3
ENCODE_QUALITY=1
ONEPASS_ENCODING=0
AUTO_QUALITY=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=eng;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=1
DEINTERLACE=0
SD_TO_1080=1
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AUDIO_DRC=0
DECODER=0
AVCHD=0
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=1
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=1
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=24540
TARGET_SIZE=500
[Paths]
SOURCE_PATH=P:\A NEWLY DOWNLOADED\THE AGE OF INNOCENCE BD50 CC\
WORKING_PATH=J:\BD_REBUILDER PROCESSING\
4) THE_AGE_OF_INNOCENCE_BD50_CC.inf
[Status]
LABEL=THE_AGE_OF_INNOCENCE_BD50_CC
VERSION=v0.61.28
SOURCE_SIZE=36821594112
SOURCE_VIDEO_SIZE=36821594112
TARGET_SIZE=25732055040
REDUCTION=.698830554748145
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=eng;
BACKUP_MODE=1
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=1
DGDECNV=0
DGDECIM=0
FRIMSOURCE=0
FFMS2=0
SSIF_MODE=0
UHD_V3_MODE=0
QUICK=0
ENCODE_STEP=2
[00274]
AUDIO=1
PGS=1
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=25732055040
RATE=18751
SPLITS=1
jetli is offline   Reply With Quote
Old 20th April 2023, 15:15   #31435  |  Link
Strange that it completed pass one with no issue -- and then failed 3 minutes into pass 2... any chance the system overheated?
Have you tried running the command line from LASTCMD.txt from a DOS (command) window? You'd have to do it right after it failed to make sure everything needed is still there (e.g. the stats file).
Old 20th April 2023, 16:17   #31436  |  Link
jetli
I'll run it again, and run lastcmd.txt from dos window.
So I take it, you don't see anything wrong?
Old 21st April 2023, 09:00   #31437  |  Link
musiclover
What I see wrong is this: SOURCE_PATH=P:\A NEWLY DOWNLOADED\THE AGE OF INNOCENCE BD50 CC\
It looks like you downloaded the source. If this is true you can get banned from this forum
You'd better cleaned your logs before posting them here
Old 21st April 2023, 15:07   #31438  |  Link
I don't see an issue unless I'm missing something.
If you run it from the command window, at least you will see what error occurs within X264.
Old 21st April 2023, 21:06   #31439  |  Link
jetli
I ran it again with slower clocks, it passed. So I guess it's the computer, it hasn't had any problems in quite a while, but now it won't pass prime95 either.
working the issue. Thanks.
Old 22nd April 2023, 18:46   #31440  |  Link
Thanks for reporting back. I assume you are overclocked? Anyway, I will say without hesitation that X264 is the ultimate system overclocking test.
Copyright ©2000 - 2023, vBulletin Solutions Inc.
