Old 28th February 2010, 21:14   #21  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
Originally Posted by Brazil2 View Post
For x264 I couldn't find the option for --no-dct-decimate so I had to use the command line addition box. Not a big deal but a switch, a box, would be usefull.
thanks for the front-end Selur it's shaping out real nice keep it up
MuLTiTaSK is offline   Reply With Quote
Old 28th February 2010, 21:21   #22  |  Link
CpT
Yup, f4v's work fine now
CpT is offline   Reply With Quote
Old 28th February 2010, 21:22   #23  |  Link
Selur
Selur's Avatar
looking at the subMe 10 problem now.
Old 28th February 2010, 21:32   #24  |  Link
Selur
Selur's Avatar
updated http://www.selur.info/hybrid/Hybrid_100227_3.zip subMe 10 should now work too (didn't update subMe on trellis change )
Does anyone know all of the container extensions mp4box can handle (atm. it's restricted to 3gp, mp4 and f4v inside Hybrid)
Old 28th February 2010, 22:08   #25  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@Selur
MP4Box -h import
Old 28th February 2010, 22:11   #26  |  Link
Selur
Selur's Avatar
Don't see any container thats 'mp4 compatible' as I ment it.
I'm looking for which container can be re-/demuxed by mp4box and from which it can extract stuff.
Old 28th February 2010, 22:43   #27  |  Link
Riki
Thanks Selur, I can confirm the multiple input bug if fixed!!
Riki is offline   Reply With Quote
Old 28th February 2010, 22:50   #28  |  Link
Selur
Selur's Avatar
Just made a silent update to all the Hybrid_100227_3-builds, will now take a shower, grab a bite, watch daily show and then go to sleep, so I'll be back in around 9 hrs.
Cu Selur
Old 28th February 2010, 22:52   #29  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@Selur
Old 1st March 2010, 14:31   #30  |  Link
Alex_080
User of X264
Hi Selur
Audio Synchronization Problem
Sample File : http://www.mediafire.com/?4d4ntwxymn2
Encoded File : http://www.sendspace.com/file/vkr7qc
Log Messages : http://www.sendspace.com/file/v5r5t8
I Use :
Hybrid - 100227_3
Video--------x264
Audio ---------Custom add all
Bitrate------------380
AVC----------High/5.1
Threads---------6
Present--------------slower
Tune-------------------Animation
Reencode audio stream
aac auto Nero AAC
Downmix --------don't change
I also face Problem in encoding 6 channel audio file to 2 channel please help.
Alex_080 is offline   Reply With Quote
Old 1st March 2010, 14:47   #31  |  Link
Selur
Selur's Avatar
will look at it
Old 1st March 2010, 15:14   #32  |  Link
Selur
Selur's Avatar
tried to extract and remux the file via:
mkvextract tracks "Input.mkv" 2:"test_eng.ac3"
mkvextract tracks "Input.mkv" 3:"test_jpn.ac3"
mkvextract tracks "Input.mkv" 1:"test.264"
mkvmerge --ui-language en -o "test.mkv" -d 0 --no-track-tags --default-duration 0:30000/1001fps --aspect-ratio-factor 0:1.185 --fourcc 0:MP4V --no-chapters --forced-track 0:no --no-audio --no-subtitles "test.264" --no-track-tags --no-chapters --forced-track 0:no -a 0 --no-video --no-subtitles "test_eng.ac3" --no-track-tags --no-chapters --forced-track 0:no -a 0 --no-video --no-subtitles "test_jpn.ac3" --no-global-tags
-> no clue what's with the file but even after a simple remux it's asynch.
Old 1st March 2010, 20:06   #33  |  Link
Two solutions
1) remux source mkv and force 24000/1001 frame rate
2) add convertfps=true to DirectShowSource
Old 1st March 2010, 20:12   #34  |  Link
Selur
Selur's Avatar
Problem is: how to detect that it is 24000/1001 automatically?
(ffmpeg detects '23.98 tbr', but mediaInfo and mplayer both detect 29.976 fps and mkvinfo also shows 29.976)
Hybrid ver. 100228
*fixed*
- a bunch of audio related problems on linux (e.g. ffmpeg->sox->neroAacEnc)
- audio copy (used on audio passthrough or when using raw audio input)
- job indexing on multi audio
-> updated links in 1st post
Cu Selur
Ps.: no clue atm how to better detect fps than mediainfo,... -> got an idea may be extracting the time codes will help (just have to figure out how to get them with mkvextract and then integrate them into Hybrid)
('mkvextract.exe timecodes_v2 wrongFramerate.mkv 1:timecodes.txt' seems to work )
Old 2nd March 2010, 15:09   #35  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@Selur
i keep getting this error upon startup?
Log Messages
subPixelPrecision value "10: trellis based rate refinement on all frames" is not present in current list
any chance for eac3to support?
Old 2nd March 2010, 15:21   #36  |  Link
buzzqw
HDConvertToX author
eac3to hasn't a linux build available ...
BHH
HDConvertToX: your tool for BD backup
MultiX264: The quick gui for x264
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline   Reply With Quote
Old 2nd March 2010, 17:41   #37  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@buzzqw
HOWTO: running eac3to under wine with Arcsoft TotalMedia Theater for DTS-HD decoding
Old 2nd March 2010, 18:23   #38  |  Link
Selur
Selur's Avatar
no wine for me
I know where the problem is, will fix it later. (when I'm back home )
Old 2nd March 2010, 20:30   #39  |  Link
MuLTiTaSK
MuLTiTaSK's Avatar
@Selur
eac3to would allow the user to open complete BluRay's directly in Hybrid not just files (*.m2ts)
title choice for multiple titled discs like you allow with DVD's
extract original chapters from source
eac3to audio functions it's what seperate it's from most demuxers hands down essential tool for BluRay conversions
Hybrid x264 interface is awesome control of so many switches in a GUI is sweet great coding you doing keep it up
Old 2nd March 2010, 23:07   #40  |  Link
Selur
Selur's Avatar
working on timecode extraction atm to be able to get the right averageFps and keep them on passthrough.
strange thing is
mkvextract timecodes_v2 "D:\sx264\testclips\wrongFramerate.mkv" 1:"timeCode_22_55_22_058.txt"
creates a timecode file
mkvextract timecodes_v2 "D:\sx264\testclips\wrongFramerate.mkv" 1:timeCode_22_55_22_058.txt
mkvextract timecodes_v2 "D:\sx264\testclips\wrongFramerate.mkv" 1:"D:\Encoding Temp\timeCode_22_55_22_058.txt"
doesn't create a timecode file
->going to ask mosu for help,..
seems to be my system was at fault, works now
-> send Alex a link to a fixed version for testing
