Old 22nd March 2020, 03:57   #201  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
ChangeLog for ffhevc 4.2.4
* Bugfix: -c used instead of -ac for audio channels
Old 23rd March 2020, 07:12   #202  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.2.5 and ffx264 4.0.8
* Add -max_muxing_queue_size switch to workaround possible issues when muxing Atmos/DTS-X audio
Old 26th March 2020, 19:32   #203  |  Link
ravs
froggy1, first thanks for creating the ffmpeg scripts.
About ffx264-4.0.8
I try to find the option for selecting the audio channels I want to have, but to no prevail.
-c is the option for the setup file.
According to ffx264 -h there is no such option as -ac. -ac is not to be found in the man page either.
What do I miss here?
Do I need to create a setup file for each DVD to get the audio tracks that I want?
ravs is offline   Reply With Quote
Old 26th March 2020, 19:35   #204  |  Link
microchip8
microchip8's Avatar
About ffx264-4.0.8
-ac is used internally by the channel code itself to set the channels desired by the user. I made a change to that code that I left and didn't revert. There's no -ac parameter in the ffx264 options
You don't need to set up any setup/config files. Just pass through the script and answer the questions
Old 26th March 2020, 23:55   #205  |  Link
ravs
Ahh good to know.
One issue remains. It aborts with an error:
-> MPlayer is missing from your system!
I don't have mplayer but mpv installed in my system.
Can mpv used instead of mplayer?
If not and if I do not want any crop, how can ffx264 be convinced to run without mplayer?
I do not see an option to disable crop.
When I understand it correctly, ffx264 as well as fhevc and ffxvid all use mplayer for crop, so when one not uses crop all scripts should be able to work without mplayer.
Old 27th March 2020, 07:26   #206  |  Link
microchip8
microchip8's Avatar
Ahh good to know.
Set AUTOCROP to "n" in the config file located in $HOME/.ffx264 (a hidden file)
MPlayer is a requirement, though. It is used only for crop preview, not crop itself which uses FFmpeg. I'll make it optional in another release shortly
I will not switch to mpv as someone else can come and say he has MPlayer installed but not mpv. I've chosen MPlayer for crop preview because it has the rectangle filter. I do not know if mpv has it too, for that matter
Old 27th March 2020, 07:49   #207  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.2.7 and ffx264 4.0.9
* Check for MPlayer only if AUTOCROP is enabled
Old 25th April 2020, 08:16   #208  |  Link
microchip8
microchip8's Avatar
* Update default encoding options
Old 16th June 2020, 20:10   #209  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.2.8
* Support TrueHD audio in the MP4 container
* Lower max-merge from 4 to 2
ChangeLog for ffx264 4.1.0
Old 21st June 2020, 16:12   #210  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.2.9 and ffx264 4.1.1
* Fixed a bug that prevents using TrueHD mono audio in the MP4 container
Old 4th July 2020, 19:52   #211  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.3.0
* Switch to rskip mode 2 (edge density). Should prevent onion artifacts and speed up encoding a bit
Old 5th July 2020, 10:19   #212  |  Link
richardpl
mpv have if you have not know all ffmpeg filters, thus it have drawbox filter which is much more powerful than rudimentary and unmaintained mplayer filter.
Old 13th July 2020, 10:38   #213  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.3.1
* Enable tskip and hme in default encoding options
* Merge mp4 audio support with ts/m2ts/mts in the case statement for additional container formats
* Removed not in use, commented out code
* Lower default AAC audio bitrate from 448 to 384 kbps
Old 3rd October 2020, 12:31   #214  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.3.2
* Lower edge density recursion skip to 3%
* Lower RC lookahead to 80
* Lower subme from 5 to 4
Old 5th October 2020, 20:25   #215  |  Link
microchip8
microchip8's Avatar
Change Log for ffhevc 4.3.3
* Fixed an issue in default encoding option where using a CTU of 64 can cause visual distortion when using rskip=2 (edge density). Workaround is to use a CTU of 32 and qg-size of 32
Old 10th November 2020, 21:27   #216  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.3.4
* Bump up psy-rd from 3.3 to 4.0
* Lower deblock strength to -4,-4
* Enable strong intra smoothing
* Lower rskip edge threshold to 2
Old 15th December 2020, 19:30   #217  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.3.5
* Tweaks to the default encoding options
Old 27th December 2020, 19:33   #218  |  Link
microchip8
microchip8's Avatar
ChangeLog ffx264 4.1.2 and ffhevc 4.3.6
* Fixed a long standing bug where audio mapping values were incorrect for audio metadata resulting in incomplete or wrong values
Old 28th December 2020, 02:52   #219  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.3.7 and ffx264 4.1.3
* Fix a bug in the $vidtrack variable
Old 22nd January 2021, 09:02   #220  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.3.8 and ffx264 4.1.4
* Remove "a" from the -ac audio option
* Fix possible negative index in the audio option
