Old 8th October 2004, 19:23   #21  |  Link
Wilbert
You need to use it in case your source is: MPEG2 default or SMPTE 240M standard (both set of coefficients are approximately the same).
The other set of coefficients are approximately the same and equal to the MPEG1 coefficients.
It doesn't really matter what your target is. If you use VDub or AviSynth, these matrix coefficient info is lost, and mpeg1 coefficients will be assumed during playback (at least for DivX/XviD/TMPGEnc/QuEnc, not sure about CCE).
Should I use ColorMatrix before converting to ConvertToYUY2 for CCE and ConvertToRGB24 for TMPGE?
Yes. Just directly after loading the source.
Perhaps you can make an avs script, encode it to MPEG2 with CCE, and post the coefficients for me?
Wilbert is offline   Reply With Quote
Old 9th October 2004, 01:47   #22  |  Link
ltc
Hmn, interesting. The source DVD is NTSC interlaced. Color coefficient is S170 (SMPTE 170M) according to GSpot.
I re-encoded to D1/2 size using KSVCD template. Encoded with tmpgenc the result video has FCC coefficient. Encoded with CCE, no coefficient present.
script:
Mpeg2Source("D:\TietNhonQuy_DVD\TietNhonQuy_01.d2v")
ColorMatrix()
crop(8, 0, -32,0)
GripCrop(352, 480, source_anamorphic=false)
GripSize(resizer="LanczosResize")
dgbob(FOrder(),mode=1 )
convert60ito24p(2,0)
DegrainMedian(mode=1)
converttoyuy2()
# Detect field order
function FOrder(clip c) {
fo= GetParity(c)? 1:0
return fo
ltc is offline   Reply With Quote
Old 10th October 2004, 12:33   #23  |  Link
Wilbert
That's interesting. It means if you are doing DVD -> DVD using AVS_YUY2 -> CCE, the same coefficients are used (in both cases the default MPEG2 coefficients). Thus, in this case, you shouldn't apply ColorMatrix.
Old 26th October 2004, 23:46   #24  |  Link
Wilbert
I put up a new version (v1.4). Changelog:
* Added a mode parameter (default is mode="mpeg2->mpeg1" which gives the same output as older versions).
In case you captured something or you have a XviD/DivX (both are encoded mpeg1 coefficients), and you want to encode it to mpeg2 using CCE (which assumes mpeg2 coefficients):
ColorMatrix(clip, mode="mpeg1->mpeg2")
* Added rgb=true, which converts to RGB24 using mpeg2 coefficients.
The following converts a YV12/YUY2 stream to RGB24 using MPEG-2 coefficients (which might be useful if you want to convert DVD to mpeg2 using TMPGEnc):
ColorMatrix(clip, rgb=true)
It should give the same results as
ConvertToRGB24()
Old 29th October 2004, 06:06   #25  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Is rgb=true the default in the new version? The filter was slower than usual with just ColorMatrix(), adding rgb=false fixed that.
I'd also like to clear some things up, is this the correct way:
1) DivX/XviD clip to MPEG-2 in CCE : ColorMatrix(mode="mpeg1->mpeg2")
2) MPEG-2 capture (no coeffs shown) to MPEG-2 in CCE : ColorMatrix()
Old 29th October 2004, 08:53   #26  |  Link
Wilbert
Default is rgb=false.
Btw, rgb=true is the same as
ConvertToRGB(matrix="rec709")
which should be faster. I didn't know that when adding that option
Yup.
That's a tricky one. Of course, your cap application (assuming it's just an analog cap) doesn't know which coefficients should be used. Since pal/ntsc standards always (should) use mpeg1 coefficients (ITU BT.601-4), you should use
Old 29th October 2004, 09:04   #27  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Thanks, that cleared things up
Old 30th October 2004, 16:53   #28  |  Link
Wilbert
I put up a new version. In the previous ones, the used coefficients were slightly wrong. Although the difference is not noticable in practice
btw, I corrected the naming convention. MPEG-2 coefficients are called Rec.709 and MPEG-1 coefficients Rec.601. Thus
ColorMatrix(clip, mode="Rec.709->Rec.601") (default)
ColorMatrix(clip, mode="Rec.601->Rec.709")
I advice you to use the internal
ConvertToRGB(clip, matrix="Rec.709")
instead of
ColorMatrix(clip, rgb=true).
Output is identical (thx IanB), but the former is faster.
Old 2nd January 2005, 05:46   #29  |  Link
North2Polaris
North2Polaris's Avatar
ColorMatrix and Gordian Knot
@Wilbert,
I recently used your filter on a Mpeg2 to Xvid conversion using AviSynth and VDubMod. The difference, to my eyes at least, was remarkable. I have wondered why past encodes were "less bright" than I expected and needed to be adjusted.
I took a look at the AviSynth plugins that come with Gordian Knot. I did not see ColorMatrix among them, which surprised me given the discussion in the current thread and the following threads:
http://forum.doom9.org/showthread.ph...0&pagenumber=3
http://forum.doom9.org/showthread.php?s=&threadid=81191
Does Gordian Knot handle this problem another way or not at all?
Thanks for your work on this! Happy New Year!
North
North2Polaris is offline   Reply With Quote
Old 2nd January 2005, 13:53   #30  |  Link
Wilbert
No. Perhaps len0x is not aware of the problem. Did you ask him about this?
Old 2nd January 2005, 15:52   #31  |  Link
North2Polaris
@Wilbert,
I just sent a PM to len0x about this.
I tried using LumaFilter in DGDecode to adjust the "brightness".
From DGDecode html,
Useful additional YV12 Filters :
To Darken Luminosity.
LumaFilter(-10,0.9)
To Ligthen Luminosity.
LumaFilter(+10,1.1)
Will lightening luminosity address the brightness problem addressed by ColorMatrix or just "cover it up"?
North
Old 2nd January 2005, 16:02   #32  |  Link
Boulder
Pig on the wing
Boulder's Avatar
The original problem is not actually the brightness, it's that the colors are off slightly.
Old 2nd January 2005, 16:10   #33  |  Link
len0x
I'm afraid we've to stop
len0x's Avatar
Hm... Am I right in understanding that every DVD source needs to be converted to a proper color matrix before encoding into MPEG4?
*Edit* remark about RGB removed
Gordian Knot Family:
Gordian Knot: website, download
Auto Gordian Knot: Website and download, tutorial, FAQ
len0x is offline   Reply With Quote
Old 2nd January 2005, 16:35   #34  |  Link
Wilbert
Yup, well "to the same color matrix" as MPEG4 uses/assumes (Rec.601 coefficients).
Old 2nd January 2005, 16:52   #35  |  Link
North2Polaris
@Boulder,
Thanks. When you don't know that the underlying problem is a color problem, it looks like a problem with brightness, which can lead to unsatisfactory attempts to correct it.
North
Old 2nd January 2005, 17:19   #36  |  Link
len0x
len0x's Avatar
Bummer - now I have a dilemma since speed loss is at least 10% when doing correction so it might not be a good idea to make it default in GK/AGK...
Btw, do you have XML description of the filter? (I can add it to GK then)
Old 2nd January 2005, 17:25   #37  |  Link
Wilbert
I wish I could do MMX
Not yet. I will do it this week and send you a pm.
Old 2nd January 2005, 17:30   #38  |  Link
len0x
len0x's Avatar
cheers
Old 17th January 2005, 06:46   #39  |  Link
Steve56
ColorMatrix does virtually the same as BT709ToBT601 from http://mywebpages.comcast.net/trbarry/downloads.htm, or?
Steve56
Steve56 is offline   Reply With Quote
Old 17th January 2005, 10:26   #40  |  Link
Wilbert
I corrected the url above
Yes that's true, I noticed that too late. His plugin contains optimization code, so it might be faster. (btw, hdtv isn't always Rec.709 as suggested in his docs ...)
colormatrix
