1st June 2015, 11:41 | #4521 | Link | |
and in the end way to risky anyway. if the result isn't frame accurate not sure if any benefit is worth that. and it should made as clear as possible to new people "don't use DSS/DSS2". |
1st June 2015, 12:26 | #4522 | Link | |
1st June 2015, 13:48 | #4523 | Link |
i haven't used it in years.
but an easy way to see the issue was this. directshowsource("yoursource") and a script with ffmpegsource2("yoursource") and load it in vdub. it was totally normal that the first frame was missing in the dss source script and if i'm not mistaken even the total number of frames where different. adding a textsub makes things even worse. and the next problem is what directshow decoder and splitter is used. so reproducing an issue with someone using DSS is pretty hard. dss2 does a way better job but still. |
1st June 2015, 16:01 | #4524 | Link |
Zathor,
Is the updating of the TimeStretch plugin still a work in progress? I ask as TimeStretch.dll appears to have been added to the "MeGUI\tools\avisynth_plugin" folder but MeGUI is still loading the old plugin from the other plugin folder like this (Win XP): AddAutoloadDir("C:\Program Files\MeGUI\tools\avs\plugins") (Edit: What's the reason for the two plugin folders anyway?) When the new TimeStretch plugin is eventually being used, the warning about destroying the phase relationship probably should be removed from the log file. The above applies to MeGUI using the portable version of Avisynth or Avisynth+. When it's using Avisynth 2.5.8 or 2.6 etc, MeGUI still seems to be using the "built in" TimeStretch function rather than the new plugin. It would need to be loaded differently, I think. http://forum.doom9.org/showthread.ph...59#post1723059 Cheers. Last edited by hello_hello; 1st June 2015 at 16:09. |
1st June 2015, 20:02 | #4525 | Link |
I encoded a couple of files from mkv and mp4 format to xvid avi and the resulting files all had this strange entry in the mediainfo:
Frame rate : 47.952 fps Original frame rate : 23.976 fps lsmash was used which seems to be the default of late. |
2nd June 2015, 03:07 | #4526 | Link |
kalehrl,
I think "original frame rate" is the frame rate written to the video stream. The other one is the frame rate written to the container. I guess for the moment you could fix it by muxing the video and audio manually as it seems it's a muxing problem. |
2nd June 2015, 20:42 | #4528 | Link | |||
Two plugin folders are there btw because of standalone AviSynth+ and general plugins. Quote:
3rd June 2015, 11:31 | #4529 | Link | |
Sorry, I wasn't meaning to hassle you..... |
4th June 2015, 11:45 | #4531 | Link |
Thanks. FFmpeg does not set the frame rate in the correct way when it is not forced with -r.
2561 [AVI Muxer] improved logging 2560 [FFmpeg Muxer] force source frame rate (regression of 2546) 2559 [MP4 Muxer] support UTF-8 for track names. Patch by Eli Bildirici #68 |
4th June 2015, 11:58 | #4532 | Link | |
Btw. does this new plugin really fix the destroying of the phase relationship? |
4th June 2015, 20:09 | #4533 | Link | |
I think that was the whole point of the new version. To update SoundTouch to something more recent. http://www.surina.net/soundtouch/README.html Change history. 1.8.0: Added support for multi-channel audio processing Last edited by hello_hello; 5th June 2015 at 09:52. |
24th June 2015, 10:51 | #4534 | Link |
Given Avisynth+ development isn't moving at a hectic pace, could I suggest updating the version MeGUI uses (r1576?) to r1825?
According to the info here it's considered to be more stable than the official stable version. I'm suggesting updating it as I found an issue with r1576 that's apparently not an issue with r1825. InpaintFunc.avs - Different result depending on Avisynth version I haven't tested the newer Avisynth+ myself yet, but from what I understand after reading Groucho2004's posts in the above thread, Avisynth+ r1576 produces a different result to Avisynth 2.6.0.6, whereas Avisynth+ r1825 and Avisynth 2.6.0.6 produce the same result with the InpaintFunc script. |
25th June 2015, 11:56 | #4536 | Link | |
I have Avisynth 2.6 installed but unfortunately there's still some sort of memory issue when using MeGUI/ffms2 with MKV source files and the "installed" Avisynth. It causes the Script Creator to produce errors when cropping or resizing if you don't do it very slowly and it's fairly annoying. Unfortunately that's a combination I use quite a bit so I'm forced to stick with the portable version of Avisynth that comes with MeGUI. |
25th June 2015, 12:31 | #4538 | Link | |
25th June 2015, 14:11 | #4539 | Link | |
I'm assuming you're referring to using the portable Avisynth+ as opposed to installing it? |
25th June 2015, 14:27 | #4540 | Link | |
The portable version is what i use. |
