26th August 2012, 11:17 | #15561 | Link | |
the thing is very curious, would erase all the work again, when I got to thinking the player play with ArcSoft TotalMedia Theatre. And the result is that it works, but you have to put in the program, the audio output as dts mixture. We already heard correctly Ucontrol pip. An accomplishment. |
26th August 2012, 20:50 | #15562 | Link |
Oversize BD5 for Extras
I have used BD Rebuilder for 100's of Movie Only backups and it has worked like a charm. I just purchased the 2 disc Cleopatra set and decided to try (for the first time) to do my normal movie only and then a BD5 for the extras using your new edit mode. Disc 1 worked as expected and produced a 4.1 gb structure. Disc 2 did not work so well. The first disc had failrly small extras and I did 3 of them that totalled 7.08 GB. The second disc had 1 2hr extra and a couple of smaller ones which I kept 1 of for a total of 7.16 GB. The build completed without error but the resulting structure was 4.92 GB. Much too big. I tried it twice. Both of the resulting BD5 Stream directories have a boatload of very small files. Could that be the problem? I am including the logs.
[08/26/12] BD Rebuilder v0.41.01 (beta) [08:09:45] Source: CLEOPATRA_DISC_2 - Input BD size: 7.16 GB - Approximate total content: [04:47:54.715] - Target BD size: 4.36 GB - Windows Version: 6.1 [7601] - Auto Quality: High Quality (Default), Two Pass - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640 [08:09:57] PHASE ONE, Encoding - [08:09:57] Blanking: VID_00001 (1 of 12) - [08:09:57] Processing: VID_00002 (2 of 12) - [08:09:57] Extracting A/V streams [VID_00002] - [08:10:07] Reencoding video [VID_00002] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,344 frames - Bitrate: 15,000 Kbs - [08:10:07] Reencoding: VID_00002, Pass 1 of 2 - [08:11:31] Reencoding: VID_00002, Pass 2 of 2 - [08:15:38] Video Encode complete - [08:15:38] Processing audio tracks - Track 4352 (eng): Keeping original audio - [08:15:38] Multiplexing M2TS - [08:15:53] Processing: VID_00003 (3 of 12) - [08:15:53] Extracting A/V streams [VID_00003] - [08:16:03] Reencoding video [VID_00003] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 1,344 frames - Bitrate: 15,000 Kbs - [08:16:03] Reencoding: VID_00003, Pass 1 of 2 - [08:17:28] Reencoding: VID_00003, Pass 2 of 2 - [08:21:34] Video Encode complete - [08:21:34] Processing audio tracks - Track 4352 (eng): Keeping original audio - [08:21:34] Multiplexing M2TS - [08:21:48] Processing: VID_00004 (4 of 12) - [08:21:48] Extracting A/V streams [VID_00004] - [08:25:23] Reencoding video [VID_00004] - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 214,200 frames - Bitrate: 3,456 Kbs - [08:25:23] Reencoding: VID_00004, Pass 1 of 2 - [09:09:36] Reencoding: VID_00004, Pass 2 of 2 - [11:05:49] Video Encode complete - [11:05:50] Processing audio tracks - Track 4352 (eng): Keeping original audio - [11:05:50] Multiplexing M2TS - [11:08:33] Processing: VID_00005 (5 of 12) - [11:08:33] Extracting A/V streams [VID_00005] - [11:09:06] Reencoding video [VID_00005] - Source Video: MPEG-4 (AVC), 720x480 - Rate/Length: 29.970fps, 27,750 frames - Bitrate: 3,497 Kbs - [11:09:07] Reencoding: VID_00005, Pass 1 of 2 - [11:15:36] Reencoding: VID_00005, Pass 2 of 2 - [11:33:43] Video Encode complete - [11:33:43] Processing audio tracks - Track 4352 (eng): Keeping original audio - [11:33:43] Multiplexing M2TS - [11:33:55] Blanking: VID_00006 (6 of 12) - [11:33:55] Blanking: VID_00007 (7 of 12) - [11:33:55] Blanking: VID_00009 (8 of 12) - [11:33:55] Blanking: VID_00010 (9 of 12) - [11:33:55] Blanking: VID_00011 (10 of 12) - [11:33:55] Blanking: VID_00012 (11 of 12) - [11:33:55] Processing: VID_00720 (12 of 12) - [11:33:55] Extracting A/V streams [VID_00720] - [11:34:00] Reencoding video [VID_00720] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 430 frames - Bitrate: 12,652 Kbs - [11:34:00] Reencoding: VID_00720, Pass 1 of 2 - [11:34:25] Reencoding: VID_00720, Pass 2 of 2 - [11:36:22] Video Encode complete - [11:36:22] Processing audio tracks - [11:36:22] Multiplexing M2TS [11:36:29]PHASE ONE complete [11:36:29]PHASE TWO - Rebuild Started - [11:36:29] Rebuilding BD file Structure [11:37:37] - Encode and Rebuild complete - WORKFILES folder removed. [11:37:37] JOB: CLEOPATRA_DISC_2 finished. Code:
[Status] LABEL=CLEOPATRA_DISC_2 VERSION=v0.41.01 (beta) SOURCE_SIZE=7691801291 SOURCE_VIDEO_SIZE=7343087616 TARGET_SIZE=4686086144 REDUCTION=.590674208972968 RESIZE_1080=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=0 SUBS_TO_KEEP=eng; BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=-1 INSTANCES=1 DGDECNV=0 QUICK=0 ENCODE_STEP=0 COMPLETED=12 REBUILD_COMPLETE=1 [00002] AUDIO=1 PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=132153762 RATE=15000 SPLITS=1 NSIZE=106487808 FLINK=-1 MLINK=-1 [00003] AUDIO=1 PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=132886840 RATE=15000 SPLITS=1 NSIZE=107544576 FLINK=-1 MLINK=-1 [00004] AUDIO=1 PGS=10000000000 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=3574244829 RATE=3456 SPLITS=1 NSTART=27000000 NEND=348621210 NSIZE=4147771392 FLINK=0 MLINK=0 [00005] AUDIO=1 PGS=10000000000 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=467577175 RATE=3497 SPLITS=1 NSTART=27000000 NEND=68665122 NSIZE=542681088 FLINK=0 MLINK=0 [00720] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=30509863 RATE=12652 SPLITS=1 NSIZE=28551168 FLINK=-1 MLINK=-1 |
28th August 2012, 18:46 | #15563 | Link |
hi, not sure if this is a bug or just something I do wrong.
I know the blanking is still experimental, but I find it working very well .. except when I do several discs at once in batch. I select a disc, blank what I want, and choose "add to batch" .. and then open the next one and do the same, and so on. The end result is that the stuff I selected for blanking isn't blanked. I find it weird, since when I look at a disc in the batch serie under it's settings, I do see for instance "blank=1101010101" , which I presume is blank first & second, keep third ... Anyone else have the same issue ? |
28th August 2012, 19:24 | #15564 | Link | |
28th August 2012, 19:56 | #15565 | Link |
Hi
This is the first time I have problems with a movie. Let me know if you need more info. Code:
[08/14/12] BD Rebuilder v0.41.01 (beta) [13:48:47] Source: THE_HUNGER_GAMES - Input BD size: 44,66 GB - Approximate total content: [02:41:40.475] - Target BD size: 22,95 GB - Windows Version: 5.1 [2600] - Auto Quality: Good (Very Fast), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [13:48:51] PHASE ONE, Encoding - [13:48:51] Processing: VID_00001 (1 of 24) - [13:48:51] Extracting A/V streams [VID_00001] - [13:49:06] Reencoding video [VID_00001] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1.033 frames - Bitrate: 15.344 Kbs - [13:49:06] Reencoding: VID_00001, Pass 1 of 1 - [13:50:36] Video Encode complete - [13:50:36] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (spa): Keeping original audio - [13:50:36] Multiplexing M2TS - [13:50:44] Processing: VID_00003 (2 of 24) - [13:50:44] Extracting A/V streams [VID_00003] - [13:50:54] Reencoding video [VID_00003] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 689 frames - Bitrate: 15.159 Kbs - [13:50:54] Reencoding: VID_00003, Pass 1 of 1 - [13:51:53] Video Encode complete - [13:51:53] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (spa): Keeping original audio - [13:51:53] Multiplexing M2TS - [13:51:59] Processing: VID_00004 (3 of 24) - [13:51:59] Extracting A/V streams [VID_00004] - [13:54:03] Reencoding video [VID_00004] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 11.228 frames - Bitrate: 13.048 Kbs - [13:54:03] Reencoding: VID_00004, Pass 1 of 1 - [14:08:01] Video Encode complete - [14:08:01] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (spa): Keeping original audio - [14:08:01] Multiplexing M2TS - [14:09:01] Processing: VID_00020 (4 of 24) - [14:09:01] Extracting A/V streams [VID_00020] - [14:09:11] Reencoding video [VID_00020] - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.368 frames - Bitrate: 8.758 Kbs - [14:09:11] Reencoding: VID_00020, Pass 1 of 1 - [14:10:46] Video Encode complete - [14:10:46] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:10:46] Multiplexing M2TS - [14:10:51] Processing: VID_00021 (5 of 24) - [14:10:51] Extracting A/V streams [VID_00021] - [14:11:05] Reencoding video [VID_00021] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1.869 frames - Bitrate: 6.002 Kbs - [14:11:05] Reencoding: VID_00021, Pass 1 of 1 - [14:12:37] Video Encode complete - [14:12:37] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:12:37] Multiplexing M2TS - [14:12:45] Processing: VID_00029 (6 of 24) - [14:12:45] Extracting A/V streams [VID_00029] - [14:12:58] Reencoding video [VID_00029] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1.573 frames - Bitrate: 6.804 Kbs - [14:12:58] Reencoding: VID_00029, Pass 1 of 1 - [14:14:19] Video Encode complete - [14:14:19] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:14:19] Multiplexing M2TS - [14:14:26] Processing: VID_00449 (7 of 24) - [14:14:26] Extracting A/V streams [VID_00449] - [14:14:38] Reencoding video [VID_00449] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2.017 frames - Bitrate: 8.536 Kbs - [14:14:38] Reencoding: VID_00449, Pass 1 of 1 - [14:17:16] Video Encode complete - [14:17:16] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:17:16] Multiplexing M2TS - [14:17:21] Processing: VID_00450 (8 of 24) - [14:17:21] Extracting A/V streams [VID_00450] - [14:17:32] Reencoding video [VID_00450] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1.921 frames - Bitrate: 8.536 Kbs - [14:17:32] Reencoding: VID_00450, Pass 1 of 1 - [14:19:41] Video Encode complete - [14:19:41] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:19:41] Multiplexing M2TS - [14:19:47] Processing: VID_00451 (9 of 24) - [14:19:47] Extracting A/V streams [VID_00451] - [14:20:08] Reencoding video [VID_00451] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 3.529 frames - Bitrate: 8.538 Kbs - [14:20:08] Reencoding: VID_00451, Pass 1 of 1 - [14:24:31] Video Encode complete - [14:24:31] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:24:31] Multiplexing M2TS - [14:24:40] Processing: VID_00452 (10 of 24) - [14:24:40] Extracting A/V streams [VID_00452] - [14:24:55] Reencoding video [VID_00452] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 2.989 frames - Bitrate: 8.797 Kbs - [14:24:55] Reencoding: VID_00452, Pass 1 of 1 - [14:28:30] Video Encode complete - [14:28:30] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:28:30] Multiplexing M2TS - [14:28:36] Processing: VID_00453 (11 of 24) - [14:28:36] Extracting A/V streams [VID_00453] - [14:28:47] Reencoding video [VID_00453] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1.921 frames - Bitrate: 8.536 Kbs - [14:28:47] Reencoding: VID_00453, Pass 1 of 1 - [14:31:14] Video Encode complete - [14:31:14] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:31:14] Multiplexing M2TS - [14:31:19] Processing: VID_00501 (12 of 24) - [14:31:19] Extracting A/V streams [VID_00501] - [14:36:23] Reencoding video [VID_00501] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 30.664 frames - Bitrate: 14.862 Kbs - [14:36:23] Reencoding: VID_00501, Pass 1 of 1 - [15:17:10] Video Encode complete - [15:17:10] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (spa): Keeping original audio - [15:17:10] Multiplexing M2TS - [15:23:13] Processing: VID_00502 (13 of 24) - [15:23:13] Extracting A/V streams [VID_00502] - [15:39:52] Reencoding video [VID_00502] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 115.939 frames - Bitrate: 12.539 Kbs - [15:39:52] Reencoding: VID_00502, Pass 1 of 1 - [18:07:40] Video Encode complete - [18:07:41] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (spa): Keeping original audio - [18:07:42] Multiplexing M2TS - [18:23:09] Processing: VID_00503 (14 of 24) - [18:23:09] Extracting A/V streams [VID_00503] - [18:25:38] Reencoding video [VID_00503] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 14.271 frames - Bitrate: 14.830 Kbs - [18:25:39] Reencoding: VID_00503, Pass 1 of 1 - [18:51:44] Video Encode complete - [18:51:44] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (spa): Keeping original audio - [18:51:44] Multiplexing M2TS - [18:52:49] Processing: VID_00504 (15 of 24) - [18:52:49] Extracting A/V streams [VID_00504] - [18:53:01] Reencoding video [VID_00504] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 739 frames - Bitrate: 14.918 Kbs - [18:53:01] Reencoding: VID_00504, Pass 1 of 1 - [18:54:33] Video Encode complete - [18:54:33] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (spa): Keeping original audio - [18:54:33] Multiplexing M2TS - [18:54:40] Processing: VID_00505 (16 of 24) - [18:54:40] Extracting A/V streams [VID_00505] - [18:57:20] Reencoding video [VID_00505] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 15.436 frames - Bitrate: 14.732 Kbs - [18:57:20] Reencoding: VID_00505, Pass 1 of 1 - [19:31:10] Video Encode complete - [19:31:10] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (spa): Keeping original audio - [19:31:11] Multiplexing M2TS - [19:32:17] Processing: VID_00506 (17 of 24) - [19:32:17] Extracting A/V streams [VID_00506] - [19:32:27] Reencoding video [VID_00506] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 689 frames - Bitrate: 15.159 Kbs - [19:32:27] Reencoding: VID_00506, Pass 1 of 1 - [19:33:49] Video Encode complete - [19:33:49] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (spa): Keeping original audio - [19:33:50] Multiplexing M2TS - [19:33:56] Processing: VID_00507 (18 of 24) - [19:33:56] Extracting A/V streams [VID_00507] - [19:34:07] Reencoding video [VID_00507] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 739 frames - Bitrate: 14.918 Kbs - [19:34:07] Reencoding: VID_00507, Pass 1 of 1 - [19:35:38] Video Encode complete - [19:35:38] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (spa): Keeping original audio - [19:35:38] Multiplexing M2TS - [19:35:44] Processing: VID_00508 (19 of 24) - [19:35:44] Extracting A/V streams [VID_00508] - [19:36:00] Reencoding video [VID_00508] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1.172 frames - Bitrate: 15.281 Kbs - [19:36:00] Reencoding: VID_00508, Pass 1 of 1 - [19:38:22] Video Encode complete - [19:38:22] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (spa): Keeping original audio - [19:38:22] Multiplexing M2TS - [19:38:30] Processing: VID_00509 (20 of 24) - [19:38:30] Extracting A/V streams [VID_00509] - [19:38:39] Reencoding video [VID_00509] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 631 frames - Bitrate: 14.791 Kbs - [19:38:39] Reencoding: VID_00509, Pass 1 of 1 - [19:39:57] Video Encode complete - [19:39:57] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (spa): Keeping original audio - [19:39:57] Multiplexing M2TS - [19:40:03] Processing: VID_00510 (21 of 24) - [19:40:03] Extracting A/V streams [VID_00510] - [19:40:14] Reencoding video [VID_00510] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 903 frames - Bitrate: 15.235 Kbs - [19:40:14] Reencoding: VID_00510, Pass 1 of 1 - [19:42:02] Video Encode complete - [19:42:02] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (spa): Keeping original audio - [19:42:02] Multiplexing M2TS - [19:42:09] Processing: VID_00511 (22 of 24) - [19:42:09] Extracting A/V streams [VID_00511] - [19:44:42] Reencoding video [VID_00511] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 12.371 frames - Bitrate: 14.419 Kbs - [19:44:42] Reencoding: VID_00511, Pass 1 of 1 - [20:09:39] Video Encode complete - [20:09:39] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (spa): Keeping original audio - [20:09:39] Multiplexing M2TS - [20:10:30] Processing: VID_00512 (23 of 24) - [20:10:30] Extracting A/V streams [VID_00512] - [20:10:40] Reencoding video [VID_00512] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 689 frames - Bitrate: 15.159 Kbs - [20:10:40] Reencoding: VID_00512, Pass 1 of 1 - [20:12:06] Video Encode complete - [20:12:06] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (spa): Keeping original audio - [20:12:06] Multiplexing M2TS - [20:12:12] Processing: VID_04321 (24 of 24) - [20:12:12] Extracting A/V streams [VID_04321] - [20:12:18] Reencoding video [VID_04321] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 1.440 frames - [20:12:19] Reencoding: VID_04321, Pass 1 of 1 - [20:13:19] Video Encode complete - [20:13:19] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (eng): Keeping original audio - [20:13:19] Multiplexing M2TS [20:13:26]PHASE ONE complete [20:13:26]PHASE TWO - Rebuild Started - [20:13:27] Rebuilding BD file Structure - [20:14:07] CorrectMPLS() 00009 2408 [23:35:02] - Aborted at user request Last edited by jdobbs; 28th August 2012 at 23:22. |
29th August 2012, 01:40 | #15567 | Link | |
I can't be involved in any kind of protection circumvention... so I'll have to leave this to others. Last edited by jdobbs; 29th August 2012 at 01:43. |
29th August 2012, 03:48 | #15568 | Link |
I've noticed reports of the Hunger Games having a new type of protection and fake playlists causing the decrypter software problems. I've observed they have been releasing new versions of the major blu-ray decryption software almost daily the past week, so it might be awhile before this particular title is supported completely by the decrypters.
29th August 2012, 05:39 | #15569 | Link |
Using v0.41.01
BDR keeps auto selecting the AC3 audio instead of the True_HD audio track even though I have keep HD audio selected. Previous versions would auto select the TrueHD if I'm not mistaken. The projects with this issue did show the TrueHD audio track as AUD_002 where as in the past I seems like the HD track was AUD_001. |
29th August 2012, 13:13 | #15571 | Link | |
You can select a playlist and do a movie-only backup however. |
29th August 2012, 13:19 | #15572 | Link | |
29th August 2012, 13:49 | #15573 | Link |
weird, cause on the slysoft forums there arent messages about being unplayable rips works fine on PDVD 10 & 12. But be warned, do NOT update to the latest 1905 build for PDVD12. It contains CINAVIA DETECTION. No joke, the first software player that detects it has been born.
29th August 2012, 13:53 | #15574 | Link | |
29th August 2012, 15:18 | #15575 | Link | |
Thanks, I will have to keep and eye out for those that appear as the second track. |
29th August 2012, 18:31 | #15577 | Link | |
@jdobbs re: HUNGER GAMES
Throughout the beta testing period I've had a plethora of FULL DISK backups (all or most of which used Java menuing) that, while not playing properly or at all from either burned disc or hard drive under PowerDVD, played properly on standalone players... |
29th August 2012, 21:13 | #15578 | Link |
Aging Video Hobbyist
This and setarip's post inspire me to ask: are people here using Arcsoft TMT5 to check discs on their computers? I was thinking about upgrading but read somewhere that latest 5.3.1.144 or 146 does not play BD5 or BD9 discs.
29th August 2012, 23:58 | #15579 | Link | |
30th August 2012, 00:15 | #15580 | Link |
I have one of these and have had good luck with it, though I don't use it all that often. Just made a donation to cover the cost. Thanks for your continued work on BD-RB!
