23rd November 2012, 14:54 | #501 | Link |
Just recently started using VidCoder x64.
& i'm confused by one thing. When i try to demux the file with MKVcleaver or MKVExtractGUI2 & mux it with mkvmerge, video plays really fast & there is no timeline, tried both MPC-HC & KMPlayer, same thing. & if i only use mkvmerge, without demuxing, then the picture freezes & there's only audio. This doesn't happen with StaxRip encodes... Last edited by den78; 23rd November 2012 at 16:08. |
25th November 2012, 03:56 | #505 | Link |
VidCoder Author
Released VidCoder 1.4.9 Beta:
* Updated HandBrake core to SVN 5079. * Fixed crashes when encoding DVDs with title gaps. |
29th November 2012, 00:36 | #511 | Link |
Ok. I see. Let me ask this then while I have your ear...when the original source is 4:3 ratio and you want to it to stay 720x480 with a 16:9 ratio without a overly stretched picture from turning off the anamorphic settings, how is that done precisly? Sure it's no big deal to just do a 720x400 but I have used media info on some 720x480 DVD encodes with perfect crisp 16:9 ratio outputs.
29th November 2012, 00:59 | #512 | Link |
VidCoder Author
Anamorphic is what allows you to get a 16:9 ratio output with a 720x480 storage resolution. HandBrake has a good Anamorphic guide.
If I can't have Anamorphic for some reason I just like to stretch one dimension out: for example having the output at 854x480. That way I have not lost any vertical pixels and the horizontal pixels have been given more room and stretched out. |
29th November 2012, 01:51 | #513 | Link | |
29th November 2012, 05:46 | #514 | Link |
VidCoder Author
You should be able to enter 854x480, just make sure "None" is selected for Anamorphic. In fact if you have "Keep Aspect Ratio" checked it should actually do this automatically if the source has the right aspect ratio listed.
29th November 2012, 16:19 | #515 | Link |
is there a way to add the aspect ratio suggestion?. i mean, the user can choose between 2.35, 1.33, 1.77, 2.40, etc when "Keep Aspect Ratio" is unchecked...
or somebody can help me to know where to find the aspect ratio like 16/9, 4/3 for 2.35 and 2.40???... |
29th November 2012, 21:14 | #516 | Link |
VidCoder Author
I don't think you can modify the target aspect ratio directly. If you think the source has it wrong you'll have to do it manually by leaving anamorphic off and changing the picture dimensions or choosing "Custom" anamorphic and changing the pixel aspect ratio.
29th November 2012, 22:43 | #517 | Link | |
It did go to 854x480 with a 1:1 source of 720x404 though. |
30th November 2012, 12:57 | #518 | Link |
Is this GUI "bug" (GUI like in Win2000) related somehow with WinXP or is there some other problem?
One suggestion: can you add % of finished job in front (or behind) of word VidCoder in taskbar? Could be useful for WinXP - it is better to say "52% VidCoder" or "VidCoder 52%" than just VidCoder... |
30th November 2012, 16:57 | #519 | Link | |||
VidCoder Author
