9th November 2015, 18:13 | #801 | Link | |
random user
Tell me if you encounter syntax errors with newer versions, they can be easily fixed.
BeHappy Audio Transcoder > <Doom9 forum> <Gleitz forum> <GitHub> MP4.tool GUI for MP4Box & L-SMASH muxer > https://www.mediafire.com/folder/3i6y6cbkyhblm/MP4.tool |
5th October 2018, 18:12 | #802 | Link |
This thread is old but I need to bump it to warn about something...
The videos created by Apple cannot have an audio track added to it, using YAMB. It will save as MP4 with the audio only, and say that HEVC is not recognized. I used the 4K recording in the iPAD Pro 10.5 (256 GB, wifi+cell), and then this app: https://itunes.apple.com/us/app/npla...539397400?mt=8 To copy the MOV from the camera roll to another folder in nPlayer. Then I uploaded to my PC. Turns out I can't remove the audio track recorded by the iPAD and add another one * * This "other one" was recorded with this sort of device: https://www.bhphotovideo.com/c/produ...der_black.html When I tried to do this it failed to join streams. More info about my video: https://pastebin.com/DsT30j2W The extension is .MP4. This file described by Pastebin can't be edited by YAMB. So YAMB needs to receive a new version with this new codec. P.S. Extracting to RAW format also doesn't work in this case. The video stream will be extracted, but will be considered an audio track instead. Last edited by Perenista; 5th October 2018 at 18:19. |
8th October 2018, 17:31 | #803 | Link |
The latest YAMB build is from 2009, at this time the HEVC video format did not even exist. I doubt that KurtNoise will ever update it.
I can reproduce your findings, but it was easy to fix by replacing MP4Box.exe with a later version from 2013 (taken from MP4Tool). Just download MP4Tool 0.60 from VideoHelp, extract MP4Box.exe from the "Tools" folder and save it in the "YAMB" folder replacing the old version. //Obsolete, see post #808// Of course you can also ditch YAMB altogether and use MP4Tool for these tasks. For H.264 video my usual workflow is to manage my tracks in MKVToolNix and then use MkvToMp4 to convert the MKV to a highly Apple compatible AVC/AAC MP4. Cheers manolito Last edited by manolito; 9th October 2018 at 15:31. |
8th October 2018, 18:12 | #804 | Link |
Life's clearer in 4K UHD
The MP4 muxer in MeGUI does a pretty good job
9th October 2018, 01:12 | #806 | Link | |
According to my tests the most reliable MP4Box version is v 0.5.1. Get it from the link in this post (download MP4Box Update [Test]): https://forum.doom9.org/showthread.p...74#post1845574 Use the "official" version 0.5.1, all later versions have problems... Cheers manolito Last edited by manolito; 9th October 2018 at 22:59. |
2nd March 2019, 19:45 | #810 | Link |
Sorry, you are correct. Yamb does honor this setting for the current task, but after restarting Yamb it resets this setting. Looks like you have to change this setting every time before you start a job...
Well, it is Beta after all (and will probably stay in Beta forever). |
