Old 22nd June 2019, 17:22   #6381  |  Link
chros
chros's Avatar
Image from here.
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v385.28),Win10 LTSB 1607,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(2160p@23/24/25/29/30/50/59/60Hz)
Old 22nd June 2019, 18:43   #6382  |  Link
v0lt
chroma scaler had been check a countless time in the madVR but i can do you another test with it.
I repeat. I need a test file where people can see the difference between bilinear and bicubic/lanczos chroma upscaling.
the biggest problem is nvidia right now there DXVA chroma scaler is moving the chroma which can results in a lot of aliasing. this has been tested with EVR and madVR. even a simple bicubic 60 should be far better.
You are exaggerating the problem. When the driver has an error and simply duplicates the color values (nearest neighbor), users quickly notice this. But in other cases, people do not see the difference in their video.
PS: I talked to users who install madVR, put up heavy settings, and then canít answer the question "What did not suit you in the standard settings?". They just read one of the stupid instructions from the Internet.
Old 22nd June 2019, 20:05   #6383  |  Link
as i said i will provide this but this will take sometime i want to do it properly.
i can not disagree that the normal user don't see it but this doesn't change that nvidia is doing it wrong.
happens all the time. and other user have to fix it in the madVR thread...
but i can answer your question what doesn't suite me and i'm able to make samples to show the differences. but this needs time.
@chros this image very outdated.
Old 22nd June 2019, 20:52   #6384  |  Link
chros
chros's Avatar
Asmodian's chroma omparison from 2 years ago, maybe it helps.
Old 23rd June 2019, 15:41   #6385  |  Link
beter
Update of translation for Chinese Traditional and Dutch:
https://www.sendspace.com/file/d12puh
beter is offline   Reply With Quote
Old 24th June 2019, 08:48   #6386  |  Link
Grimsdyke
@devs. Is there any way to make the OSD bigger in MPC Video Renderer ??
Old 24th June 2019, 09:04   #6387  |  Link
Aleksoid1978
Aleksoid1978's Avatar
Current - no. In feature - yes
I7 2600K@4.2 /Asrock P67 Extreme4 Gen 3 /Kingston HyperX 8Gb 1866 (4x2) Kit /OCZ Vertex 3 256Gb /Gigabyte GTX 960 /BenQ EW2430 /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Old 24th June 2019, 09:04   #6388  |  Link
Asmodian
I did not go all the way down to bilinear, bicubic was the fastest option I demoed. I should probably add nearest neighbor and bilinear.
madVR options explained
Old 24th June 2019, 11:37   #6389  |  Link
this test pattern shows obvious difference between chroma scaler accessible for everyone: https://www.youtube.com/watch?v=cSxz1HYhzys
not a friend of these so here is a image from a show:
mpcVR: https://abload.de/img/mpcvrlastsongfyjpr.png (broke nvidia driver?)
madVR:
bicubic 60: https://abload.de/img/bicubic60lastsong5xjnm.png
bilinear: https://abload.de/img/nilinearlastsongnlkzd.png
NN: https://abload.de/img/nnlastsongxyjds.png (reminds me of nvidia)
super xbr 100: https://abload.de/img/superxbr100lastsongijkvr.png
edit: EVRCP for control: https://abload.de/img/evrcpmmkl3.png
Old 24th June 2019, 12:05   #6390  |  Link
Aleksoid1978
madVR:
Original image ?
Old 24th June 2019, 12:13   #6391  |  Link
is h264 lossless fine?
if yes i will encode this frame like that and upload it.
Old 24th June 2019, 12:18   #6392  |  Link
Aleksoid1978
You can upload video file and show timestamp for test.
Old 24th June 2019, 12:35   #6393  |  Link
http://s000.tinyupload.com/index.php...84126818673936
does this work?
38, 23.976
Old 24th June 2019, 12:59   #6394  |  Link
Aleksoid1978
Good test.
My result:
EVR - bad
EVR-CP -good(if use 16-bit float surface), bad if 8
madVR(bicubic60) - good
MPC VR DX9 -good(if use 16-bit float surface), bad if 8
MPC VR DX11 - good.
P.S. Verdict - EVR-CP/MPC VR DX9 with 16-bit float surface and MPC VR DX11 is the same quality as madVR bicubic60. So - we don't need to process chromium ourselves, DXVA2/D3D11 Video processor do it not bad
Old 24th June 2019, 13:27   #6395  |  Link
i can confirm that MPCVR d3d11 is not broken and looks more like bicubic 60.
super xbr still looks a lot better.
EVR CP mpc-hc is broken for me.
sadly there is an issue with d3d11 it is incorrectly rendering colors they are to "dark" but it is not an level issue.
d3d9: https://abload.de/img/d3d9zxku0.png
d3d11: https://abload.de/img/d3d11mzjog.png
d3d9 looks similar to madVR so it should be correct.
edit: found the source of the issue.
it is p010 input forcing nv12 as input fixes the issue.
Old 24th June 2019, 17:22   #6396  |  Link
v0lt
@beter
Thanks. Updated in r4597.
Good test video.
Yes, it looks like a bug. This file is played normally by me. On my system (GTX 950) there is a similar problem with the YUY2 format.
Old 24th June 2019, 20:01   #6397  |  Link
Anima123
Originally Posted by Aleksoid1978 View Post
Good test.
My result:
EVR - bad
MPC VR DX11 - good.
How about MPC VR DX9 10 bit?
Anima123 is offline   Reply With Quote
Old 25th June 2019, 00:00   #6398  |  Link
Aleksoid1978
So - it's bug(at last Nvidia) when convert 10bit 4:2:0 to 8bit RGB using DXVA2 VP. Fix using 16bit RGB output in DXVA2 VP.
Old 25th June 2019, 00:11   #6399  |  Link
Aleksoid1978
Check EVR-CP in MPC-BE with Surface format: 16-bit Floating Point.
Old 25th June 2019, 01:27   #6400  |  Link
the bug that NN is used with p010 and 8/10 bit surfaces was just a by product that wasn't planned at all.
my plan was to show the difference between bilinear and bicubic 60.
but there are sadly more DXVA processing issues.
try frame 51, 23.976 you can see black parts in the red text now. this issue comes from not moving the chroma when it is upscaled.
you can test this with madVR using default settings by going to this frame and by pressing control+shift+alt+d to toggle through deinterlancing where madVR usess DXVA by default and where it moves the chroma to the wrong position.
it can be far worse then this example.
