23rd September 2016, 03:01 | #24922 | Link |
Heh... so I'm already doing a full disc encode and I'm about 3/4 the way though. So, I get this bright idea to copy the x264_64.exe from version 5012 and wait until it is multiplexing one of the streams and I opened 5017 which I was using with this encode, and quickly opened the tools folder and dropped in the .exe from 5012 and replaced it before it started encoding the next stream. It worked! So my encode speed went from about 37 fps to 80 and my CPU went from about 50 to 95.
Talk about gunslinging from the hip! |
26th September 2016, 20:08 | #24924 | Link |
Update on BD Rebuilder failing
Another update on my situation. With BD Rebuilder failing every time I did a clean install of Windows 10 Pro x64. I installed AVISynth and Lav filters and nothing else, tried a re-encode and it failed (See first part of log, no x264 tweaks). Feeling very frustrated because previously I had it working well (and my thinking that something I installed messed with x264 settings). So another install of Windows, this time installed AVISynth only, (not even drivers) ran BD-Rebuilder and it completed (see second half of log). So now I'm back with more info, another log, and looking for suggestions before I install all my apps.
---------------------- [09/25/16] BD Rebuilder v0.50.18 [00:05:37] Source: DAYS_OF_HEAVEN - Input BD size: 44.00 GB - Approximate total content: [02:42:34.628] - Target BD size: 22.95 GB - Windows Version: 6.2 [9200] - Quality: Highest (Very Slow), ABR - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [00:05:37] PHASE ONE, Encoding - [00:05:37] Processing: VID_00271 (1 of 5) - [00:05:37] Extracting A/V streams [VID_00271] - [00:26:09] Reencoding video [VID_00271] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 135,226 frames - Bitrate: 15,555 Kbs - [00:26:09] Reencoding: VID_00271, Pass 1 of 1 - Encode failed. Aborting. - BD-Rebuilder v0.50.18 - Windows Version: 6.2 [9200] - Working Path Free Space: 192.59GB - AVISYNTH Version: 2.6.0.6, Ok - LAVFILTERS: Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [08:56:38] - Failed video encode, aborted ---------------------- [09/25/16] BD Rebuilder v0.50.18 [17:31:48] Source: DAYS_OF_HEAVEN - Input BD size: 44.00 GB - Approximate total content: [02:42:34.628] - Target BD size: 22.95 GB - Windows Version: 6.2 [9200] - Quality: Highest (Very Slow), Two Pass - Decoding/Frame serving: X264/LAVF - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [17:31:48] PHASE ONE, Encoding - [17:31:48] Processing: VID_00271 (1 of 5) - [17:31:48] Extracting A/V streams [VID_00271] - [17:52:12] Reencoding video [VID_00271] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 135,226 frames - Bitrate: 15,555 Kbs - [17:52:12] Reencoding: VID_00271, Pass 1 of 2 - [19:19:09] Reencoding: VID_00271, Pass 2 of 2 - [00:27:45] Video Encode complete - [00:27:45] Processing audio tracks - Track 4352 (eng): Keeping original audio - [00:27:45] Multiplexing M2TS - [00:37:20] Processing: VID_00272 (2 of 5) - [00:37:20] Extracting A/V streams [VID_00272] - [00:41:18] Reencoding video [VID_00272] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 36,751 frames - Bitrate: 16,972 Kbs - [00:41:18] Reencoding: VID_00272, Pass 1 of 2 - [00:59:18] Reencoding: VID_00272, Pass 2 of 2 - [02:09:41] Video Encode complete - [02:09:41] Processing audio tracks - Track 4352 (eng): Keeping original audio - [02:09:41] Multiplexing M2TS - [02:10:43] Processing: VID_00273 (3 of 5) - [02:10:43] Extracting A/V streams [VID_00273] - [02:14:42] Reencoding video [VID_00273] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 39,331 frames - Bitrate: 16,970 Kbs - [02:14:43] Reencoding: VID_00273, Pass 1 of 2 - [02:35:53] Reencoding: VID_00273, Pass 2 of 2 - [03:58:15] Video Encode complete - [03:58:15] Processing audio tracks - Track 4352 (eng): Keeping original audio - [03:58:15] Multiplexing M2TS - [03:59:16] Processing: VID_00274 (4 of 5) - [03:59:16] Extracting A/V streams [VID_00274] - [04:01:17] Reencoding video [VID_00274] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 22,561 frames - Bitrate: 16,971 Kbs - [04:01:17] Reencoding: VID_00274, Pass 1 of 2 - [04:13:08] Reencoding: VID_00274, Pass 2 of 2 - [04:59:11] Video Encode complete - [04:59:11] Processing audio tracks - Track 4352 (eng): Keeping original audio - [04:59:11] Multiplexing M2TS - [04:59:36] Processing: VID_00275 (5 of 5) - [04:59:36] Extracting A/V streams [VID_00275] - [05:01:28] Reencoding video [VID_00275] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 20,821 frames - Bitrate: 16,976 Kbs - [05:01:28] Reencoding: VID_00275, Pass 1 of 2 - [05:12:07] Reencoding: VID_00275, Pass 2 of 2 - [05:51:49] Video Encode complete - [05:51:49] Processing audio tracks - Track 4352 (eng): Keeping original audio - [05:51:49] Multiplexing M2TS [05:52:21]PHASE ONE complete [05:52:21]PHASE TWO - Rebuild Started - [05:52:21] Rebuilding BD file Structure [05:52:29] - Encode and Rebuild complete - WORKFILES folder removed. [05:52:29] JOB: DAYS_OF_HEAVEN finished. So thanks for the software, I think it's brilliant. And the forum to seek help. Hoping for more feedback. Thanks |
26th September 2016, 21:12 | #24925 | Link |
@Rad10act1v3
Your second run is using X264/LAVF because LAV Filters aren't available -- which means that AVISYNTH isn't being used at all. That's fine for simple jobs -- but there are some features that simply won't work unless you are able to use DirectshowSource (which uses AVISYNTH and LAV Filters). When you run it the first time with LAV Filters installed, does it successfully configure the registry for them? It can only do that if you run it as Administrator. Last edited by jdobbs; 26th September 2016 at 21:14. |
26th September 2016, 21:17 | #24926 | Link | |
27th September 2016, 00:37 | #24927 | Link |
I love that movie!!! Such great comedy! Now it's very much politically INcorrect, hahaha!
27th September 2016, 02:47 | #24928 | Link |
Hello,
I'm not sure if this is a bug or it is just me. If I try to encode a complete blu ray with extras where some extras are above 30 min and nearly 60 min. All extras above 30 min will not compress at the specified CRF of 25. Here my settings Code:
[Options] VERSION=0.50.0.18 ENCODER=0 MODE=0 ENCODE_QUALITY=2 ONEPASS_ENCODING=1 AUTO_QUALITY=0 TARGET_SIZE=23650 AUDIO_TO_KEEP=deu;eng;ger; SUBS_TO_KEEP=deu;eng;ger; SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 IGNORE_3D=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AUDIO_DRC=0 DECODER=3 AVCHD=1 REMOVE_WORKFILES=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=1 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=1 FRIMSOURCE=0 COMPLETION_BEEP=0 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=0 PGSTOSRT=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23650 QUICK_EXTRAS=1 MOVIEONLY_TYPE=0 ALTCRF=21 ALT_TARGET=1024 ALT_CRF_TARGET=1024 ALTMETHOD=0 ALTAUTOCROP=0 Enable_test=1 Enable_blanking=1 BLANK_THRESHOLD=3600 QUICK_CRF=25 |
27th September 2016, 04:17 | #24929 | Link |
Error message running program
Here's a log while running Forbidden Planet
---------------------- [09/25/16] BD Rebuilder v0.50.18 [19:03:11] Source: FORBIDDEN_PLANET - Input BD size: 30.51 GB - Approximate total content: [05:51:49.313] - Target BD size: 22.95 GB - Windows Version: 6.2 [9200] - Auto Quality: Good (Very Fast), Two Pass - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [19:03:11] PHASE ONE, Encoding - [19:03:11] Processing: VID_00020 (1 of 12) - [19:03:11] Extracting A/V streams [VID_00020] - [19:06:46] Reencoding video [VID_00020] - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 141,705 frames - Bitrate: 14,866 Kbs - [19:06:46] Reencoding: VID_00020, Pass 1 of 2 - [20:16:57] Reencoding: VID_00020, Pass 2 of 2 - [21:25:49] Video Encode complete - [21:25:49] Processing audio tracks - Track 4352 (eng): Keeping original audio - [21:25:49] Multiplexing M2TS - [21:30:25] Processing: VID_00073 (2 of 12) - [21:30:25] Extracting A/V streams [VID_00073] - [21:30:53] CreateAVS() 00000 [21:36:46] - Could not create AVS file ---------------------- [09/26/16] BD Rebuilder v0.50.18 [02:14:57] Source: FORBIDDEN_PLANET - Input BD size: 30.51 GB - Approximate total content: [05:51:49.313] - Target BD size: 22.95 GB - Windows Version: 6.2 [9200] - Auto Quality: Good (Very Fast), Two Pass - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [02:14:59] PHASE ONE, Encoding - [02:14:59] Processing: VID_00073 (2 of 12) - [02:14:59] CreateAVS() 00000 [02:21:27] - Could not create AVS file Any ideas? The process just stops at this point. |
27th September 2016, 06:07 | #24930 | Link | |
27th September 2016, 06:10 | #24931 | Link | |
27th September 2016, 15:25 | #24933 | Link |
@HandiA
Could you run MEDIAINFO.EXE against 00073.M2TS in the source folder and post the results? I'd like to see if there is anything unusual about the source. It's really odd that the main feature completed successfully, but the second file has issues. MediaInfo is available in the BD-RB tools folder and you can run it from a CMD window. An example might be (assuming you fix the path info): "c:\path_to_bd_rebuilder\tools\mediainfo.exe" "c:\path_to_source\bdmv\stream\00973.m2ts" > c:\mediainfo.txt The information will be in the file MEDIAINFO.TXT after the command runs. |
27th September 2016, 20:06 | #24934 | Link |
follow up
General ID : 0 (0x0) Complete name : 00073.m2ts Format : BDAV Format/Info : Blu-ray Video File size : 2.66 GiB Duration : 55mn 31s Overall bit rate mode : Variable Overall bit rate : 6 862 Kbps Maximum Overall bit rate : 48.0 Mbps Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, BVOP : Yes Format settings, Matrix : Custom Format settings, GOP : M=3, N=15 Codec ID : 2 Duration : 55mn 31s Bit rate mode : Variable Bit rate : 5 404 Kbps Maximum bit rate : 7 500 Kbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate : 29.970 fps Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.522 Time code of first frame : 00:59:59:00 Time code source : Group of pictures header Stream size : 2.10 GiB (79%) Audio #1 ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 55mn 31s Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : -66ms Stream size : 76.3 MiB (3%) Audio #2 ID : 4353 (0x1101) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 55mn 31s Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : -66ms Stream size : 76.3 MiB (3%) Audio #3 ID : 4354 (0x1102) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 55mn 31s Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : -66ms Stream size : 76.3 MiB (3%) Audio #4 ID : 4355 (0x1103) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 55mn 31s Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : -66ms Stream size : 76.3 MiB (3%) Audio #5 ID : 4356 (0x1104) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 55mn 31s Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : -66ms Stream size : 76.3 MiB (3%) Audio #6 ID : 4357 (0x1105) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 55mn 31s Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : -66ms Stream size : 76.3 MiB (3%) Text #1 ID : 4608 (0x1200) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Text #2 ID : 4609 (0x1201) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Delay relative to video : 2s 203ms Text #3 ID : 4610 (0x1202) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Delay relative to video : 3s 370ms Text #4 ID : 4611 (0x1203) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Delay relative to video : 2s 136ms Text #5 ID : 4612 (0x1204) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Delay relative to video : 2s 136ms Text #6 ID : 4613 (0x1205) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Delay relative to video : 935ms Text #7 ID : 4614 (0x1206) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Delay relative to video : 935ms Text #8 ID : 4615 (0x1207) Menu ID : 1 (0x1) Format : PGS Codec ID : 144 Delay relative to video : 935ms Note: I had taken the file 00073.m2ts out of the stream folder and ran bd rebuilder again and the same happened with the next file 00074 Last edited by jdobbs; 27th September 2016 at 23:26. |
27th September 2016, 23:32 | #24935 | Link | |
@HandiA
I noticed that this is an MPEG-2 stream. If you're using LAV filters, go into the LAV Filters video configuration (available from the start menu) and make sure MPEG-2 is enabled. If you are using FFDSHOW, make sure you followed the highlighted portion of the installation step below: Quote:
28th September 2016, 20:44 | #24937 | Link | ||
29th September 2016, 04:22 | #24939 | Link |
It is built in to BD-RB, under help menu and second option. Will print all related setting on log tab and log file.
29th September 2016, 05:51 | #24940 | Link |
follow up
Here's the results [09/29/16] Checking System Settings - BD-Rebuilder v0.50.18 - Windows Version: 6.2 [9200] - Working Path Free Space: 622.46GB - AVISYNTH Version: 2.5.8.0, Ok - LAVFILTERS: Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [09/29/16] Systems Settings Check complete looks ok. |
