21st July 2012, 11:02 | #15361 | Link | |
This is very interesting. I actually just installed a new CPU on this machine, an AMD Phenom II X4 965. Not really an "oldie". And the irony is that I installed this new CPU on this machine so I could use bd rebuilder with it, since I considered it as too slow with its older Athlon II X2! The other machine (the one which works OK with bd rebuilder) runs a Phenom II X6 1055T. I wonder where to go from here. If both AFTEN versions included with bd-rb can't work with this Phenom II X4 965, I'm kinda stuck then, am I? |
21st July 2012, 13:11 | #15362 | Link | |
It sounds more like a configuration error. Can you post the contents of AUD_00506_4352.AVS? |
21st July 2012, 13:26 | #15363 | Link | ||
I just crave for a "wrong config" explanation for this issue, since it could then be fixed easily... Here's the content of the file: Quote:
21st July 2012, 13:53 | #15364 | Link | |
A couple things to try: 1. Add this line to the "[Options]" area of your Config file: AUDIO_DIRECTSHOW=0 2. If that doesn't work, delete it and try going into the FFDSHOW Audio Decoder Configuration utility and set "Uncompressed" to "All Supported" in the CODEC list. |
21st July 2012, 14:28 | #15365 | Link | |||
I really appreciate the help
DTS-HD XLL (Same as various BD sources failing to re-encode to AC3: The Incredibles, the Big Lebowski, the Frighteners..) Quote:
21st July 2012, 15:20 | #15367 | Link | |
Nothing is audible but I'm not sure if it's supposed to.The 264 frames only, well that's because it's just one of these countless small segments on Disney DVDs.... maybe it's a mute one! What I'll do, then, is that I'll launch a movie-only backup so to be sure that the AVS file is actually supposed to have something audible... |
21st July 2012, 15:26 | #15368 | Link | |
Just did that and well, the original segment does have audible audio. |
21st July 2012, 21:28 | #15373 | Link | |
22nd July 2012, 00:05 | #15375 | Link |
BD Rebuilder v0.40.11 (beta)
I have updated the first post of this thread with links to an new version of BD Rebuilder (v0.40.11). Changes for this release:
- Added a "vKeyint" parameter to the ALTERNATE.TXT definition file. This allows the user to specify a maximum key interval (GOP size) for non-iPod & iPad MP4 and MKV files. Setting to "Auto" will use an interval of 10x the framerate (10 sec intervals). - Made corrections to AVS entries when deinterlacing or iVTC with certain hidden settings. - Changed the naming algorithm for MKV and MP4 files so file suffixes begin with "01" rather than "00". - Corrected an error in which a secondary stream that is a different length than the primary can cause failure when used with MULTIPROCESS. - Fixed error related to status of list when using batch processing. - Corrected an issue in which under odd circumstances it was possible for a lengthy playlist (e.g. feature) to not be selected or shown under the movie-only playlist selection dialog. - Corrected an issue in which secondary streams could carry over the interlaced/progressive characteristics of a previous encode. This could, rarely, result in a secondary stream being incorrectly flagged as interlaced. - Updated the included version of X264.EXE to the latest release (r2208). - Updated the included version of X264-64.EXE to the latest release (r2208). - Other minor corrections and cosmetic fixes. |
22nd July 2012, 01:59 | #15376 | Link |
I don't understand why the audio is missing, and have tried different settings. I'm wondering if it's something to do with the muxing.. I'll check "The Incredibles" more in some other moment. Anyway, I figured I'd try something different. So I ripped my "The Matrix" Blu-ray and remembering some comments about Picture in Picture I decided to try Full Backup. Everything shows as re-encoded fine (A/V). Information about who's speaking shows but no video and the audio has gaps in the beginning like it's trying to reconnect the audio. I didn't listen too far. Currently the program is set to use High Speed (BD25). I've set it to the setting as well. v0.40.10. Cropping is not set.
I'm also trying "The Matrix" on another machine, fresh install of 7 64-bit.. Same settings as main machine. Currently processing. Edit: I see a new release. Am trying it with my main machine. 0.40.11 keeps failing now at the first secondary video stream. I'm trying different settings.
Life is not a journey to the grave; but rather to skid out broadside, thoroughly used, torn and warn and loudly proclaim; WOW; What a ride!!! Soon, I'm going to do it AGAiN in different skin!! Last edited by AmigaFuture; 22nd July 2012 at 03:15. |
22nd July 2012, 03:56 | #15377 | Link |
The Matrix
BDREBUILDER.INI
[Options] VERSION=0.40.0.11 MODE=0 ENCODE_QUALITY=0 MKV_MUXSUPS=1 ENABLE_TEST=1 ONEPASS_ENCODING=0 AUTO_QUALITY=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 DEINTERLACE=1 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=1 AC3_REENCODE=0 AC3_640=0 AC3_192=0 KEEP_HD_AUDIO=0 AVCHD=1 REMOVE_WORKFILES=0 MOVIE_ONLY_LOOP=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 UNMASK_CHAPTER=0 COMPLETION_BEEP=0 DGDECNV=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23500 MOVIEONLY_TYPE=10 ALTCRF=20 ALT_TARGET=7600 ALTMETHOD=2 ALTAUTOCROP=0 VERBOSE_STATUS=1 TARGET_SIZE=23500 AUTO_BURN=0 ENABLE_BLANKING=1 QUICK_EXTRAS=0 [Paths] SOURCE_PATH=J:\!BLU-RAY\THE_MATRIX\ WORKING_PATH=E:\BLU-RAY\REBUILDER\ Code:
[07/21/12] BD Rebuilder v0.40.11 (beta) [19:29:02] Source: THE_MATRIX - Input BD size: 37.10 GB - Approximate total content: [06:43:52.107] - Target BD size: 22.95 GB - Windows Version: 6.1 [7600] - Quality: Good (Very Fast), Two Pass - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=448 [19:29:03] PHASE ONE, Encoding - [19:29:03] Processing: VID_00000 (1 of 29) - [19:29:03] Extracting A/V streams [VID_00000] - [19:37:59] Reencoding video [VID_00000] - [19:37:59] Reencoding secondary video [TRK_02] - Encode failed. Aborting. - BD-Rebuilder v0.40.11 (beta) - Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.8.0, Ok - HAALI Splitter: 1.9.42.1, Ok - FFDSHOW: 3882, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [19:38:01] - Failed video encode, aborted THE_MATRIX.INF Code:
[Status] LABEL=THE_MATRIX VERSION=v0.40.11 (beta) SOURCE_SIZE=39830640891 SOURCE_VIDEO_SIZE=39405803520 TARGET_SIZE=24641536000 REDUCTION=.614546499900936 RESIZE_1080=0 AUDIO_TO_KEEP=eng; KEEP_HD_AUDIO=0 SUBS_TO_KEEP=eng; BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=0 INSTANCES=1 DGDECNV=0 QUICK=0 ENCODE_STEP=1 [00000] AUDIO=110000011111 PGS=0100000000000010000000000 SPLITS=1
22nd July 2012, 10:37 | #15378 | Link |
New version crashed again on the same disc and at the same point: "Resizing Subtitle_01 to 1280x720 PID:4608, JAPANESE".
Inspect.exe all ok. Code:
[07/14/12]BD Rebuilder v0.40.11 (beta) [10:19:48] Source: DARK_KNIGHT_BONUS_DISC_DOUBLE - Input BD size: 19,48 GB - Approximate total content: [03:39:37.530] - Target BD size: 7,84 GB - Windows Version: 6.1 [7601] - RESIZE 1080p to 720p enabled - Quality: High Quality (Default), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=0 Kbs=640 [10:19:48] PHASE ONE, Encoding - [10:19:48] Processing: VID_00000 (1 of 30) - [10:19:48] Extracting A/V streams [VID_00000] - [10:20:56] Reencoding video [VID_00000] - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 66.169 frames - Convert: 1280x720, 23,976fps, 66.169 frames - Bitrate: 4.535 Kbs - [10:20:56] Reencoding: VID_00000, Pass 1 of 1 - [11:17:51] Video Encode complete - [11:17:51] Processing audio tracks - Track 4352 (eng): Keeping original audio - [11:17:51] Multiplexing M2TS - Non-text or anomalous PGS 00000.track_4608.sup ignored. - [11:25:27] Processing: VID_00001 (2 of 30) - [11:25:27] Extracting A/V streams [VID_00001] - [11:26:31] Reencoding video [VID_00001] - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 66.241 frames - Convert: 1280x720, 23,976fps, 66.241 frames - Bitrate: 4.594 Kbs - [11:26:31] Reencoding: VID_00001, Pass 1 of 1 - [12:28:12] Video Encode complete - [12:28:12] Processing audio tracks - Track 4352 (eng): Keeping original audio - [12:28:12] Multiplexing M2TS - Non-text or anomalous PGS 00001.track_4608.sup ignored. - [12:28:15] CreateBDFiles() 00055 3304 [12:35:30]PHASE ONE aborted by user request Last edited by Weirdo; 22nd July 2012 at 11:06. |
22nd July 2012, 13:03 | #15380 | Link | |
