Old 23rd September 2012, 16:44   #13961  |  Link
wanezhiling
Tested on 4650m/6850/7750, black screen.
Old 23rd September 2012, 16:46   #13962  |  Link
robpdotcom
Best guess: AMD drivers don't like what I'm doing. Can I have a debug log, please?
http://depositfiles.com/files/w5ggyvnq5
Windows 7 x64
i7 870
16GB RAM
AMD 6870
robpdotcom is offline   Reply With Quote
Old 23rd September 2012, 16:50   #13963  |  Link
JarrettH
How do I go about making the sample? I was going to use dgindex, unsure of what field operation setting to use. Forced Film and Honour flags both look interlaced
Old 23rd September 2012, 16:52   #13964  |  Link
madshi
Originally Posted by v0lt View Post
http://samples.mplayerhq.hu/V-codecs...ock-cram16.avi
http://samples.mplayerhq.hu/V-codecs/CRAM/worm.avi
http://samples.mplayerhq.hu/V-codecs...4.apple_ad.mov
http://samples.mplayerhq.hu/V-codecs/CVID/handss.avi
4 Day Weekend.mov
AVI Decompressor (RGB24) + madVR = artifacts
ffdshow (RGB24) + madVR = normal
AVI Decompressor (RGB24) + Color Space Converter(ARGB32) + EVR = normal
This is a bug in the decoder. Basically the decoder asks madVR to provide an IMediaSample interface to write the decoded frame to. madVR does provide an IMediaSample. However, the decoder seems to expect that the buffer of the media sample is still filled with the previously decoded media sample. That is not the case with madVR due to its queue design. The decoder should not rely on a newly fetched IMediaSample to have a specific buffer content. It's the decoders job to fully initialize the media sample buffer. There's really nothing I can do about this. You can work around the problem by forcing the ffdshow raw video processor into the chain.
Old 23rd September 2012, 16:57   #13965  |  Link
madshi
For you AMD users here are a couple of test builds:
http://madshi.net/madVR83a.rar
Please copy one madVR test build into official madVR v0.83.0 folder at a time, renamed to "madVR.ax", of course. Please test all test builds and let me know which one of them work (if any) and which don't. Thanks!
Originally Posted by fairchild View Post
Also noticing a new bug, when in FSE (tested both old path and the new) and you close the media file/video while it's still playing, it freezes the player.
Can anybody else reproduce this?
Can you please try creating a freeze report by pressing Ctrl+Alt+Shift+Pause?
Originally Posted by andybkma View Post
v83, Luma downscaling "Activate anti ringing filter" option is greyed out and can't be selected. Is that normal? Both the "ups" are not greyed out...
That is normal. Anti-ringing is not yet supported for downscaling.
Originally Posted by vivan View Post
nVidia Optimus system: On integrated Intel HD 3000 overlay is slower by 0.30 ms. But on discrete nVidia 540m overlay is more than 2 times faster (14.1->6.5 ms rendering and 4.28->2.55 ms present time)!
That's interesting. So playback on Intel is stuttering, I suppose?
I'm not sure what's the best way to cut. There are probably many tools out there for that purpose. You could probably mux to DVD, then use the mkvtoolnix GUI to split the MKV into small parts. Probably there's a better way. Maybe someone else has a good suggestion?
Old 23rd September 2012, 17:02   #13966  |  Link
mzso
madVR v0.83 released
http://madshi.net/madVR.zip
I agree that resizing is ugly (and slower) in overlay mode. Otherwise it seems to work without problem on my GTS450.
One other thing I noticed that stopping playback is noticeably slower. I get a 1-2 second black window.
Old 23rd September 2012, 17:04   #13967  |  Link
vivan
/人 ◕ ‿‿ ◕ 人\
No. When I posted first time I wrote "30 ms" instead of "0.30 ms". I've added more accurate numbers now.
It's slightly noticeable only when rendering time is near frame interval time (it happens with 60 fps video).
Old 23rd September 2012, 17:06   #13968  |  Link
madshi
One other thing I noticed that starting and stopping playback is noticeably slower. In both occasions I get a 1-2 second black window.
Does the slower start/stop only occur with Overlay mode active? Or does that happen in any mode with v0.83?
Do you see any advantages of Overlay mode compared to conventional Windowed mode on your PC?
Old 23rd September 2012, 17:08   #13969  |  Link
madshi
What is your opinion on enabling/disabling Overlay by default?
Old 23rd September 2012, 17:08   #13970  |  Link
dansrfe
I can't reproduce the media player freeze bug that fairchild commented on using MPC-HC.
None of the test builds work for me with Windowed overlay mode enabled with ATI.
Old 23rd September 2012, 17:10   #13971  |  Link
robpdotcom
Same for me.
Windows 7 x64
i7 870
16GB RAM
AMD 6870
Old 23rd September 2012, 17:12   #13972  |  Link
madshi
I hate AMD right now. Not sure, maybe they simply don't support Windows 7 D3D9 Hardware Overlay at all? I guess I'll have to setup a win7 PC with AMD GPU here myself to get to the bottom of this.
Old 23rd September 2012, 17:13   #13973  |  Link
wanezhiling
Originally Posted by robpdotcom View Post
Same for me.
ME too
Old 23rd September 2012, 17:14   #13974  |  Link
mzso
I'm really slow... I probably imagined the start thing because of the delay at stopping. It's independent from overlay mode, guess that's the new shutdown behaviour.
For me the normal mode is better since I didn't have problems, so the overlay mode brings just losses. Apart from the resizing there's the impossibility to take screenshots. Otherwise I didn't notice anything different in the two modes.
Old 23rd September 2012, 17:17   #13975  |  Link
fairchild
Here is the freeze report:
http://www.sendspace.com/file/t6urb1
Also tested with the latest mpc-hc from xhmikosr and same thing, black screen when I close the media file while it's running and in FSE mode.
MPC-HC/MPC-BE, Lav Filters, MadVR
CPU: AMD Ryzen 5 1600, Video: AMD Radeon RX Vega 56 -> TCL S405 55", Audio: Audio-Technica M50S
fairchild is offline   Reply With Quote
Old 23rd September 2012, 17:17   #13976  |  Link
madshi
New test build for AMD users:
http://madshi.net/madVR83b.rar
In the debug log please search for "Overlay". Does it say "Overlay Caps: -" or "Overlay Caps: +"? Thanks!
Old 23rd September 2012, 17:17   #13977  |  Link
vivan
/人 ◕ ‿‿ ◕ 人\
Off, because I'm using integrated graphics all the time. Also I'm making screenshots (press 1, than alt+2, than alt+prtSc - and you'll get frame in 100% size) quite often...
However it would be cool if it would possible to have different settings for different GPU's (e.g. overlay off for intel, but on for nVidia).
Old 23rd September 2012, 17:18   #13978  |  Link
ranpha
madVR 0.83 with overlay enabled will give a black screen if playing a video with multiple subtitles, and I switch the subtitle stream. Happens with both nVidia and Intel GPUs. Also happens with either MPC-HC internal subtitle renderer and vsfilter.
The only way to make the problem goes away is to disable the overlay feature.
ranpha is offline   Reply With Quote
Old 23rd September 2012, 17:18   #13979  |  Link
mzso
I hope they pull themselves together on the software side. Kaveri APU-s look interesting. I'm thinking of upgrading to one if they live up to their promise.
Old 23rd September 2012, 17:22   #13980  |  Link
dansrfe
Just tried the new test build and I can't find/search for "Overlay" with/without case-sensitivity in the log with notepad.
