27th February 2019, 11:14 | #281 | Link | |
Hello,
when I do a "Run Compressibility Check" I have an error Error : Code:
Error Compressibility Check using x265 2.9+34 (2.0.0.1) Compressibility Check using x265 2.9+34 failed with exit code: -1073741795 (0xC000001D) The exit code might be a system error code: {EXCEPTION} Instruction non autorisée Tentative d’exécution d’une instruction interdite. --------------- Compressibility Check using x265 2.9+34 --------------- "C:\Program Files\Staxrip.2.x64\Apps\Support\avs2pipemod\avs2pipemod64.exe" -y4mp F:\Passengers.2016.2160p.UHD.BluRay.HEVC.HDR.Muti.VFF.DTS-HD.MA-tlub_temp\Passengers.2016.2160p.UHD.BluRay.HEVC.HDR.Muti.VFF.DTS-HD.MA-tlub_new_source_CompCheck.avs | "C:\Program Files\Staxrip.2.x64\Apps\Encoders\x265\x265.exe" --crf 18 --output-depth 10 --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1)" --colorprim bt2020 --colormatrix bt2020nc --transfer smpte2084 --range limited --max-cll "1529,380" --hdr --repeat-headers --hrd --aud --frames 8358 --y4m --output F:\Passengers.2016.2160p.UHD.BluRay.HEVC.HDR.Muti.VFF.DTS-HD.MA-tlub_temp\Passengers.2016.2160p.UHD.BluRay.HEVC.HDR.Muti.VFF.DTS-HD.MA-tlub_new_source_CompCheck.hevc - avs2pipemod[info]: writing 8358 frames of 24000/1001 fps, 3840x1606, sar 0:0, YUV-420-planar-8bit progressive video. avs2pipemod[info]: finished, wrote 0 frames [0%]. avs2pipemod[info]: total elapsed time is 1.470 sec. avs2pipemod[error]: only wrote 0 of 8358 frames. StaxRip.ErrorAbortException: Compressibility Check using x265 2.9+34 failed with exit code: -1073741795 (0xC000001D) The exit code might be a system error code: {EXCEPTION} Instruction non autorisée Tentative d’exécution d’une instruction interdite. --------------- Compressibility Check using x265 2.9+34 --------------- "C:\Program Files\Staxrip.2.x64\Apps\Support\avs2pipemod\avs2pipemod64.exe" -y4mp F:\Passengers.2016.2160p.UHD.BluRay.HEVC.HDR.Muti.VFF.DTS-HD.MA-tlub_temp\Passengers.2016.2160p.UHD.BluRay.HEVC.HDR.Muti.VFF.DTS-HD.MA-tlub_new_source_CompCheck.avs | "C:\Program Files\Staxrip.2.x64\Apps\Encoders\x265\x265.exe" --crf 18 --output-depth 10 --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1)" --colorprim bt2020 --colormatrix bt2020nc --transfer smpte2084 --range limited --max-cll "1529,380" --hdr --repeat-headers --hrd --aud --frames 8358 --y4m --output F:\Passengers.2016.2160p.UHD.BluRay.HEVC.HDR.Muti.VFF.DTS-HD.MA-tlub_temp\Passengers.2016.2160p.UHD.BluRay.HEVC.HDR.Muti.VFF.DTS-HD.MA-tlub_new_source_CompCheck.hevc - avs2pipemod[info]: writing 8358 frames of 24000/1001 fps, 3840x1606, sar 0:0, YUV-420-planar-8bit progressive video. avs2pipemod[info]: finished, wrote 0 frames [0%]. avs2pipemod[info]: total elapsed time is 1.470 sec. avs2pipemod[error]: only wrote 0 of 8358 frames. à StaxRip.Proc.Start() à StaxRip.x265Enc.Encode(String passName, String commandLine, ProcessPriorityClass priority) à StaxRip.x265Enc.RunCompCheck() And same with encode : Quote:
28th February 2019, 15:56 | #282 | Link |
Well finally I found the problem : it is the x265 version provided by staxrip (2.9 + 34) that does not work at home.
Replace with version 3.0_Au + 7 it works. I still have some questions my source file is 420 10bit HDR : 1. In the AVS file I have: format = "YUV420P8" and in the encoding log I have : avs2pipemod [info]: writing 2843 frames of 24000/1001 fps, 3840x1600, sar 0: 0, YUV-420-planar-8bit progressive video. y4m [info]: 3840x1600 fps 24000/1001 i420p8 unknown frame count raw [info]: output file: NUL Normally it should not be 10 bit ? 2. in the encoding log I also : x265 [warning]: NAL HRD parameters require VBV parameters, ignored What do these parameters correspond to ? 3. Is it better to use LSMASHSource.dll or ffms2.dll ? Are there any other parameters to modify to encode in HDR ? |
28th February 2019, 17:03 | #284 | Link |
OK, thanks
I redid a test with ffms2 but in the encoding log I always 8bit : Code:
------------------ Video encoding using x265 3.0_Au+7 ------------------ "C:\Program Files\Staxrip.2.x64\Apps\Support\avs2pipemod\avs2pipemod64.exe" -y4mp F:\Lucy_temp\Test-001_new.avs | "C:\Program Files\Staxrip.2.x64\Apps\Encoders\x265\x265.exe" --pass 1 --bitrate 9161 --output-depth 10 --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1)" --colorprim bt2020 --colormatrix bt2020nc --transfer smpte2084 --range limited --max-cll "1000,400" --hdr --repeat-headers --hrd --aud --frames 2843 --y4m --stats F:\Lucy_temp\Test-001_new.stats --output NUL - avs2pipemod[info]: writing 2843 frames of 24000/1001 fps, 3840x1600, sar 0:0, YUV-420-planar-8bit progressive video. y4m [info]: 3840x1600 fps 24000/1001 i420p8 unknown frame count raw [info]: output file: NUL x265 [info]: HEVC encoder version 3.0_Au+7-cb3e172a5f51 x265 [info]: build info [Windows][GCC 8.2.1][64 bit] 10bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.1 Cache64 x265 [info]: Main 10 profile, Level-5 (Main tier) x265 [info]: Thread pool created using 24 threads x265 [info]: Slices : 1 x265 [info]: frame threads / pool features : 4 / wpp(25 rows) x265 [warning]: NAL HRD parameters require VBV parameters, ignored x265 [info]: Coding QT: max CU size, min CU size : 64 / 8 x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra x265 [info]: ME / range / subpel / merge : hex / 57 / 2 / 2 x265 [info]: Keyframe min / max / scenecut / bias: 23 / 250 / 40 / 5.00 x265 [info]: Lookahead / bframes / badapt : 20 / 4 / 2 x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0 x265 [info]: References / ref-limit cu / depth : 3 / on / on x265 [info]: AQ: mode / str / qg-size / cu-tree : 2 / 1.0 / 32 / 1 x265 [info]: Rate Control / qCompress : ABR-9161 kbps / 0.60 x265 [info]: tools: rd=3 psy-rd=2.00 rskip signhide tmvp strong-intra-smoothing x265 [info]: tools: lslices=8 deblock sao stats-write My AVS : Code:
LoadCPlugin("C:\Program Files\Staxrip.2.x64\Apps\Plugins\both\ffms2\ffms2.dll") FFVideoSource("F:\Lucy_temp\Test-001.mkv", colorspace = "YV12", \ cachefile = "F:\Lucy_temp\Test-001.ffindex") Last edited by vanden; 28th February 2019 at 17:25. |
28th February 2019, 17:20 | #286 | Link |
Super it works ! Thank you !
avs2pipemod[info]: writing 2843 frames of 24000/1001 fps, 3840x1600, sar 0:0, YUV-420-planar-10bit progressive video. y4m [info]: 3840x1600 fps 24000/1001 i420p10 unknown frame count |
28th February 2019, 23:20 | #287 | Link |
Guys,
Is there a guideline in coverting UHD hdr(mkv) to Blueray(mkv)?
1st March 2019, 04:50 | #289 | Link | |
--blu-ray-compat to x265, enforcing profile, level and tier limits as well as GOP structure limitations defined by the Blu-Ray Disc Association. If I recall Flag is mainly for Legacy devices, It does nothing for newer hardware that has HDR / UHD support. Many of the auto Switches are set to 8 Bit, I should remove them, Since allot are creating more problems then they solve. |
1st March 2019, 05:06 | #291 | Link | |
StaxRip switched to 3.0 awhile ago. FYI, I have no idea if x265 flag HRD Concat is correctly marked or not. the cli list it as ---hrd-concat and the doc has it as the normal two dash flag --hrd-concat. I assume it an oversight in the cli If it's MP4 LSMASHSource(LWLibavVideoSource should be used since it has a larger range of support) Just be careful with ffms2 it has a history of reporting incorrect metadata since it doesn't read certain mediaFiles correctly. |
4th March 2019, 10:14 | #293 | Link |
Raven,
There are times the default source doesn't work. I have to explicitly put "LWLibavVideoSource". I was wondering why does it create a "*.lwi" file in the source directory instead in the designated temp folder?
4th March 2019, 19:31 | #294 | Link | |
I really wish some more sourcefilters would get released to expand source filter choices. DG Index works the best with most common formats(minus webm (Since there VP9 or VP8) and Apple encoded mp4 files. videoh has apple supported files planned for releases sometime in the future. The tool is Well worth the small fee if you got hardware that supports it. .lwi is created where ever the source is (This is hard coded inside the dll), I can't do anything about that Since it's not directly tied to StaxRip. If you call ffms2 without indexing it will create a similar type file. Technically I could tell StaxRip to delete the file Once encoding is complete. However It could screw things up with the encoding process if you try to encode it again. With the Thumbnailer, I have it set to auto delete the index file once done. |
5th March 2019, 05:08 | #296 | Link |
Noob
latest ffms2 has so many bugs so you may try to use older version. this is a new trend.
https://forum.doom9.org/showthread.p...97#post1866797 |
6th March 2019, 03:15 | #297 | Link | |
6th March 2019, 08:43 | #298 | Link |
StaxRip is the best tool,
congratulations Please add ffmpeg | AMD | Amd H.264 -c:v h264_amf ffmpeg | AMD | Amd H.265 -c:v hevc_amf VCEEncC replace with version 4.02 by rigaya, build Dec 11 2018 21:03:34, and add : --crop <int>,<int>,<int>,<int> set crop pixels of left, up, right, bottom. option. I have Amd Ryzen7 with VEGA 10 With VCEEncC (x64) 4.02 it encodes 120 FPS 1080 HEVC using LAV Video Decoder 0.73.1 thank you Last edited by zildan; 7th March 2019 at 23:04. |
aac, hdr, hevc, nvenc, staxrip, x264, x265 |
