11th May 2019, 17:12 | #402 | Link |
C:\Users\ashlar42\Documents\StaxRip\Apps\Encoders\NVEnc\NVEncC64.exe --cqp 18:20:22 --preset quality --vpp-resize cubic_catmull --output-res 720x392 -i "E:\Movie\Movie.avs" -o "E:\Movie_temp\Movie_out.h264"
resize: --vpp-resize cubic_catmull requires "nppi64_80.dll", not available on your system. resize: switching to spline36. This after copying nppi64_80.dll from the NVENC directory under StaxRip to SysWOW64. |
11th May 2019, 17:13 | #403 | Link |
11th May 2019, 17:15 | #404 | Link |
11th May 2019, 18:09 | #405 | Link | |
resize: failed to resize: -22, NPP_INTERPOLATION_ERROR. I suspect there's a problem with the CUDA SDK files version. In StaxRip there are functions exposed that are not supported out of the box, as the needed CUDA DLLs are not in the installation file. So now I'm using old files or wrong files, I don't know. Last edited by ashlar42; 11th May 2019 at 18:21. |
11th May 2019, 19:15 | #406 | Link |
@ashlar42
I cannot test it because my graphics card don't support nvenc.
12th May 2019, 15:53 | #407 | Link |
Currently, it's 200 MB download size and 600 MB disk space.
Would it make sense to offer three downloads, one with VapourSynth, one with AviSynth and one with both? What would you download? I'd take both I guess.
12th May 2019, 21:38 | #410 | Link |
Maybe I'll buy a better card in the future. I had a GTX 1060 but lost my PC in an unfortunate incident and didn't want to bother spending much time and money to build a new one, so I just bought a basic HP PC with i5-8400 CPU that can fit a GT 1030 card, I don't know if I can fit a better card in this PC due to possible heat and power restrictions.
I'm not sure GT 1030 is good enough for UHD content, I had a file recently (see below) which I can't get to play fluently, other UHD files are better. http://tvdl.zdf.de/none/zdf/diverse/...k_p1112v12.mp4 Code:
CompleteName : C:\Users\frank\Daten\Samples\Brot und Spiele - Wagenrennen im alten Rom.mp4 Format/String : MPEG-4 Format_Profile : Base Media / Version 2 CodecID/String : mp42 (isom/mp42) FileSize/String : 1.83 GiB Duration/String : 58 min 40 s OverallBitRate/String : 4 468 kb/s Encoded_Date : UTC 2019-04-17 09:03:11 Tagged_Date : UTC 2019-04-17 09:03:11 Video ID/String : 1 Format/String : HEVC Format/Info : High Efficiency Video Coding Format_Profile : Main 10@L5.1@Main CodecID : hvc1 CodecID/Info : High Efficiency Video Coding Duration/String : 58 min 40 s BitRate/String : 4 330 kb/s Width/String : 3 840 pixels Height/String : 2 160 pixels DisplayAspectRatio/String: 16:9 FrameRate_Mode/String : Constant FrameRate/String : 50.000 FPS ColorSpace : YUV ChromaSubsampling/String : 4:2:0 BitDepth/String : 10 bits Bits-(Pixel*Frame) : 0.010 StreamSize/String : 1.77 GiB (97%) Encoded_Library/String : x265 3.0:[Linux][GCC 6.3.0][64 bit] 10bit Language/String : German Encoded_Date : UTC 2019-04-17 09:03:11 Tagged_Date : UTC 2019-04-17 09:03:16 colour_range : Limited colour_primaries : BT.2020 transfer_characteristics : HLG matrix_coefficients : BT.2020 non-constant Codec configuration box : hvcC
12th May 2019, 23:11 | #412 | Link | |
Sent from my SM-G965U1 using Tapatalk |
12th May 2019, 23:12 | #413 | Link | |
12th May 2019, 23:17 | #415 | Link | |
12th May 2019, 23:54 | #416 | Link | |
13th May 2019, 00:00 | #417 | Link | |
However the gtx 1650 is fully powered by the motherboard, no need for any pci e wires from PSU. (You buy the base clocked model) Sent from my SM-G965U1 using Tapatalk |
13th May 2019, 00:04 | #418 | Link | |
13th May 2019, 08:43 | #419 | Link |
Herr
I hear that Nvidia GTX 1650 doesn't have Turing-encoding, it uses old Volta Nvidia Encoder (NVENC) for GPU-encoding.
https://www.tomshardware.com/news/nv...enc,39161.html Last edited by Forteen88; 13th May 2019 at 08:46. |
13th May 2019, 13:07 | #420 | Link | |
Especially for GPUs, any chip with a fixed-function unit (AMD from Polaris onward, nVidia from Maxwell 2nd gen onward, Intel Kabylake onward) could handle it easily.
aac, hdr, hevc, nvenc, staxrip, x264, x265 |
