Old 11th July 2019, 21:38   #621  |  Link
mparade
------- Convert MKA to FLAC 2 using ffmpeg 2019-05-29 Wolfberry -------
C:\StaxRipV2023x64\Apps\Encoders\ffmpeg\ffmpeg.exe -i "C:\Temp\x\x.mka" -y -hide_banner -ac 2 "C:\Temp\x\x.flac"
Input #0, dts, from 'C:\Temp\x\x.mka':
Duration: N/A, start: 0.000000, bitrate: N/A
Stream #0:0: Audio: dts (DTS-HD MA), 48000 Hz, 7.1, s32p (24 bit)
Stream mapping:
Stream #0:0 -> #0:0 (dts (dca) -> flac (native))
Press [q] to stop, [?] for help
Output #0, flac, to 'C:\Temp\x\x.flac':
Metadata:
encoder : Lavf58.27.103
Stream #0:0: Audio: flac, 48000 Hz, stereo, s32 (24 bit), 128 kb/s
Metadata:
encoder : Lavc58.52.102 flac
video:0kB audio:1224817kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.000661%
Start: 8:44:22
End: 8:47:10
Duration: 00:02:47
source is 7.1 DTS-X, ffmpeg converted to stereo, however my settings correct for keeping number of channels etc. I thought ffmpeg can decode DTS-X as DTS-HD MA.
Anyone knows why?
mparade is offline
Old 13th July 2019, 00:58   #622  |  Link
Natty
Noob
ColorMatrix(Mode="Rec.601->Rec.709")
whenever I use this, staxrip just hangs and then crashes
http://avisynth.nl/index.php/Externa...oma_correction
Natty is offline
Old 14th July 2019, 20:35   #623  |  Link
AMED
AMED's Avatar
Anyone knows why?
Its the -ac 2 in your log that is causing it. Have you accidentally set a custom parameter somewhere in the audio profile?
A Man Eating Duck
AMED is offline
Old 14th July 2019, 22:39   #624  |  Link
stax76
stax76's Avatar
Anyone knows why?
Can you upload a short sample or post mediainfo using the built in mediainfo gui in developer mode.
I cannot find a x64 plugin named ColorMatrix.
Something very minor I found using dotnet 4.8 build of v2.0.2.4 (Revan654).
When i have minimize processing dialog to tray enabled in the settings and then minimise StaxRip in a batch run it just disappears from the taskbar and doesn't appear in the system tray. I couldn't find any way to get focus of the StaxRip processing window so i had to kill tasks and then rerun it again with that setting disabled.
I committed a change that might fix it.
NvEnc will not encode with Vapoursynth R46 because it expects to find vsscript.dll in the system directory. But it works fine with x265.
staxrip.log
vpy: Failed to load vsscript.dll.
Failed to open input file.
https://github.com/vapoursynth/vapou...ster/ChangeLog
Line 6: "the windows installer no longer puts a copy of vsscript.dll in the system directory and no longer writes the legacy registry entries, deprecated since r31"
I believe it's a problem in nvencc, maybe you can report it to the nvencc tracker.
stax76 is offline
Old 15th July 2019, 00:25   #625  |  Link
Natty
Noob
https://forum.doom9.org/showthread.p...05#post1374605
https://github.com/sorayuki/ColorMatrix/releases
Natty is offline
Old 15th July 2019, 00:30   #626  |  Link
stax76
stax76's Avatar
does not work for me.
Cannot load a 32 bit DLL in 64 bit Avisynth: 'C:/Users/jd/Desktop/colormatrix_v2_6/colormatrix.dll'.
(D:\Samples\aaa_temp\aaa_new.avs, line 5)
stax76 is offline
Old 15th July 2019, 09:24   #627  |  Link
lasa
With the Version 2.0.2.4 I get an error when I trie to open a VC1 File.
Video format VC-1 is not supported.
What can I do, to open it correct?
lasa is offline
Old 15th July 2019, 10:35   #628  |  Link
stax76
stax76's Avatar
You mean the file extension is VC1? Does that play in mpc or mpv?
stax76 is offline
Old 15th July 2019, 10:53   #629  |  Link
Groucho2004
I made a 64 bit version.
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 15th July 2019, 12:01   #630  |  Link
lasa
I have a demuxed MKV file with VC1 codec. MPC plays the file.
lasa is offline
Old 15th July 2019, 18:48   #631  |  Link
stax76
stax76's Avatar
So you had a MKV file that was containing VC1 and you demuxed this into a raw VC1 file?
stax76 is offline
Old 15th July 2019, 19:33   #632  |  Link
Natty
Noob
can i somehow put all stax bundled dlls/avsi files located in subfolders of staxrip/apps/plugins/avs in one single folder (not program files/avisynth)? it will make it easier to manual update them, keep a track of versions and scan via avsmeter64 in case of some issues.
Natty is offline
Old 16th July 2019, 01:14   #633  |  Link
stax76
stax76's Avatar
You can do that using the custom path option in the toolbar of the app manage dialog.
stax76 is offline
Old 16th July 2019, 11:37   #634  |  Link
Santojob
I ask for advice
I'm doing tests with StaxRip, compressing videos in x265 + nVENC, the quality is good and especially the speed very fast. Could you recommend the implementation of a filter that improves the final quality of the x265 video and does not consume or reduce compression times too much?
Santojob is offline
Old 16th July 2019, 15:40   #635  |  Link
videoh
Useful n00b
Look for the MakeAnyVideoBetter() filter.
videoh is offline
Old 16th July 2019, 15:49   #636  |  Link
ChaosKing
removegrain(1) helps a bit with compressibility(2-3%) and is usually a safe and very fast option.
ChaosKing is offline
Old 16th July 2019, 19:06   #637  |  Link
AMED
AMED's Avatar
There is an update to the VS script ResampleHQ.
https://gist.github.com/4re/64642122e359c37543fe
Looks like calling the script has been renamed to Resample_HQ now
A Man Eating Duck
AMED is offline
Old 16th July 2019, 20:21   #638  |  Link
Natty
Noob
Natty is offline
Old 16th July 2019, 20:53   #639  |  Link
Trench
I like the new black icon, and would vote to keep that. It did need the white outline that was added. The resampling done to create the lower-resolution versions in the .ico file didn't always maintain the needed amount of white outline, though, as shown in attached screen shot.
The attached .ico file contains updated lower resolutions, which "do better" at this. Its still not perfect nor a hand-tuned version (yet) for those lower resolutions, but might do better as the placeholder until more icon decisions or improvements are made.
For what it's worth.
Trench is offline
Old 16th July 2019, 21:45   #640  |  Link
Santojob
Thank you very much for your advice ChaosKing that I will definitely try. I do not have much knowledge and time to try other things.
videoh Thank you very much for nothing.
Santojob is offline
