29th November 2018, 19:11 | #101 | Link |
I suggest deleting the Settings and starting Fresh.
1.7 & 1.8+ Settings File are not compatible with one another. Since they use two completely different names. FYI, Don't use the site attachment. It needs approval before it shows up which take a long time. Last edited by Revan654; 29th November 2018 at 19:16. |
30th November 2018, 21:08 | #103 | Link | |
Same issues on my end. I tried to modify the default setting which gave me better contrast but madvr still output WAY better picture (colors, contrast, highlight details). Unless I'm doing something wrong, I'm highly disappointed by the HABLE or Reinhard curve. i get better result with this setting but still no good: DGHable(1.2, 0.15, 0.42, 0.10, 0.20, 0.02, 0.30, 11.2) To me, it looks like hable and reinhard are trying to make it look like the 1080p SDR BD while madvr is trying to reproduce the 4k HDR BD. so if anyone know settings that could get closer result to madvr, i would like to know as well . thanks |
30th November 2018, 23:21 | #105 | Link | |
Useful n00b
1st December 2018, 00:45 | #106 | Link | |
I will not going to be building any filters, Filters are built outside of StaxRip Code and uses VS or AVS FrameWork. There already more then you will ever use, In Context and off Context. |
1st December 2018, 18:35 | #109 | Link |
*One Small Update* Due to latest Update to VS 2017, It's very buggy which is creating Freezing and such. Going have to wait until there a fix before I add more code, Since I keep losing the work I have done. It might be a little bit longer until the next release due to MS buggy release.
Already Re-installed VS 2017 twice, Both times it was the same results. I really hate these forced updates. 15.9.2 was working great now 15.9.3 is a mess. |
1st December 2018, 23:14 | #111 | Link |
VSFilterMod.dll and msharpen.dll loading problems
On version. 2.0 now
First Problem: I'm having problems with MSharpen in ver. 1.8.2, 1.9.0 and 2.0. I get this error: Cannot load file '******/msharpen.dll' Platform returned code 126 The specified module could not be found. I did not have this problem on ver. before 1.8 Second Problem: The same thing is happening with VSFilterMod.dll Cannot load file '******/VSFilterMod.dll' Platform returned code 126 The specified module could not be found. Thanks for any help that you can give me on this. |
2nd December 2018, 07:20 | #112 | Link | ||
Don't Forget all dll must be run in 64bit. Same goes for VSFilterMod. Many of these filters are AVX based. Quote:
Not sure if the C++ runtimes will help or not See: http://avisynth.nl/index.php/MSharpen |
2nd December 2018, 22:24 | #113 | Link | |
VSFilterMod not working
I had no problem with MSharpen or VSFilterMod on Staxrip 1.8.0.0 OS is Win 10 Pro 64bit, same hardware and software when I had ver 1.8.0.0 running. On the website about MSharpen I did not have Microsoft Visual C++ 2012 Redistributable Package 86/64 installed. Installed both 86/64 and MSharpen is now working. Do not know why I had Microsoft Visual 2012 installed during Staxrip 1.8.0.0 but not on my computer when I went to 2.0.0.0 VSFilterMod ver 1.1.9.0 is still not working. Thanks for any help that you can give me on this. |
2nd December 2018, 22:35 | #115 | Link | |
Check the App Manager and check under runtimes(ignore Python) but make sure you have all the other runtimes installed. Under Apps -> FFTW Make sure you have this installed in your System Directory. VSFilterMod Build Date: 2016, it's untouched. You could try the new Forked version of VSFilter: https://github.com/sorayuki/VSFilterMod/releases I have no idea what specs they require. |
2nd December 2018, 22:50 | #116 | Link | |
Did a google search and I do have sorayuki VSFilterMod now but not replaced the old one. Sorayuki VSFilterMod is ver 1.1.92 size 3879 KB. Will give it a try, thanks for all the help |
3rd December 2018, 10:56 | #117 | Link | |
3rd December 2018, 14:03 | #118 | Link | |
3rd December 2018, 19:20 | #119 | Link | |
Maybe that's why I had problems with QSVEnc but I have no time to fix the problems. But I see none of the problems mentioned at various sites from the beginning of this release, while on previous version of April 2018 update, the Chrome hadn't worked fine for me ever. The frozen screen issue using Chrome on April 2018 update was never solved at least for me. October 2018 update works just fine.
5th December 2018, 03:00 | #120 | Link |
Hey guys. I'm fairly new to using x265 and NVEnc encoding. I noticed when trying to convert a 4K HDR video, that it shows Chroma 4.2.0 (type 2). But the encoded file does not have that same tag. Is there a way to get type2 to the encoded video? Also, @Revan654, you mentioned that HDR would not work with NVEnc encoding, but I have used it before and it seemed to display correctly on my TV. Must be something I didn't understand. Can you clarify a bit? Thanks.
aac, hdr, hevc, nvenc, staxrip, x264, x265 |
