8th November 2022, 12:46 | #42 | Link |
DEE ddp Downmix
7.1 -> 5.1 Something like: FL' = 0.54*FL FR' = 0.57*FR FC' = 0.64*FC LF' = 1.00*LF SL' = 0.4*SL + 0.4*BL SR' = 0.4*SR + 0.4*BR 7.1 -> 2.0 Something like: FL' = 0.54*FL + 0.45*FC + 0.34*SL + 0.33*BL [1.66 clip risk] FR' = 0.48*FR + 0.45*FC + 0.30*SR + 0.34*BR [1.57 clip risk] 5.1 -> 2.0 Something like: FL' = 0.54*FL + 0.38*FC + 0.47*SL [1.39 clip risk] FR' = 0.48*FR + 0.38*FC + 0.46*SR [1.32 clip risk]
30th November 2022, 21:34 | #43 | Link |
This triggered my curiosity - isn't feasible to use SOFA filter https://ffmpeg.org/ffmpeg-filters.html#sofalizer to downmix 7.1 (up to 9 channels) to 2 channel? Of course some synthetic SOFA file can be used if HRTF is unwanted.
4th February 2023, 17:28 | #45 | Link | |
Use a ffmpeg v4.4 until the regression was solved.
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 5th February 2023 at 21:14. |
11th February 2023, 16:10 | #47 | Link | ||
21st February 2023, 12:39 | #50 | Link |
I test the Latest Auto-Build (2023-02-20 12:35) in https://github.com/BtbN/FFmpeg-Builds/releases
Seems work correctly now: 1) 7.1 -> 5.1 downmix with the compand selected (see precedent posts): -filter_complex "asplit [f][s]; [f] pan=3.1|c0=c0|c1=c1|c2=c2|c3=c3 [r]; [s] pan=stereo|c0=0.5*c4+0.5*c6|c1=0.5*c5+0.5*c7, compand=attacks=0:decays=0:points=-90/-84|-8/-2|-6/-1|-0/-0.1, aformat=channel_layouts=stereo [d]; [r][d] amerge [a]" -map "[a]" There are two 'green messages': [Parsed_pan_1 @ 000001fc795c1d80] Pure channel mapping detected: 0 1 2 3 It always appears no matter what I use: pan=3.1|c0=c0|c1=c1|c2=c2|c3=c3 until pan=FL+FR+FC+LFE|FL=FL|FR=FR|FC=FC|LFE=LFE And [Parsed_amerge_5 @ 000002ac9b81ce00] Input channel layouts overlap: output layout will be determined by the number of distinct input channels But any attempt to specify the correct channel layout for the surround channels, instead 'stereo', like: pan=SL+SR...,compand... or aformat=channel_layouts=SL+SR abort the process. 2) I suggest use for 6.1 -> 5.1 downmix: -filter_complex "asplit [f][s]; [f] pan=3.1|c0=c0|c1=c1|c2=c2|c3=c3 [r]; [s] pan=stereo|c0=0.412*c4+0.588*c5|c1=0.412*c4+0.588*c6, compand=attacks=0:decays=0:points=-90/-85.4|-8/-3.4|-5/-1|-0/-0.1, aformat=channel_layouts=stereo [d]; [r][d] amerge [z]" -map "[z]"
22nd February 2023, 13:53 | #51 | Link |
What do you suggest should happen with Back Centre channel? We do not support mixing that into back channels.
https://trac.ffmpeg.org/ticket/10207#comment:4 |
22nd February 2023, 15:50 | #52 | Link | |
qaac can't decode it: ERROR: Not available input file format NeroAacDec decode it in wrong (I suposse) channel order (maybe FL FC FR SL BC SR) without channel mask. faad seems decode it without channel mask with the order FL FR FC BC SL SR ffmpeg decode it like 5.1 but with channel mask 0 in the same order than faad. To convert that 6.0 to 5.1 I suggest try: -filter_complex "asplit [f][s]; [f] pan=3.1|c0=c0|c1=c1|c2=c2|c3=0.0*c3 [r]; [s] pan=stereo|c0=0.412*c3+0.588*c4|c1=0.412*c3+0.588*c5, compand=attacks=0:decays=0:points=-90/-85.4|-8/-3.4|-5/-1|-0/-0.1, aformat=channel_layouts=stereo [d]; [r][d] amerge [z]" -map "[z]"
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 22nd February 2023 at 16:00. |
23rd February 2023, 14:07 | #53 | Link |
channel layout L R C Cb Lb Rb, yep, where Cb is back center. Wav does support that channel. https://learn.microsoft.com/en-us/wi...rmatextensible
So your command puts back center where? Last edited by Balling; 23rd February 2023 at 14:25. |
downmix, phase shift |
