28th October 2004, 22:54 | #61 | Link | ||
The 1.777 version appeared to be the correct one. Though, I will refer you to this thread. From all I read on this wonderful subject, if the DVD was well mastered, you should follow the ITU standard and use a PAR of 1.823. If the DVD wasn't well done, use a PAR of 1.777. Geez... if you read the thread, you will notice even len0x seems to change is mind about following the ITU standard as often as he changes underwear. So, that being said, I guess it all boils down to a case by case affair. Do a preview @ 1.777, then @ 1.823, find something which should be round and decide what seems correct.
PiXuS |
28th October 2004, 23:23 | #62 | Link |
Life's clearer in 4K UHD
Okay play the files in a software player that supports AR signalling detection by default, such as VLC media player or Nero's ShowTime player.
Why did you feel the need no mux my Mpeg4 streams into the MKV container and alter their AR... this is just asking for trouble! And by the way, if you want your anamorphic Mpeg4 streams to play back at the correct AR in either AVI or MKV container, replace your XviD.ax file with this one. Cheers
29th October 2004, 14:04 | #63 | Link | ||
I use MPC and MPC doesn't care about the PAR signalling in the stream so I needed to use MKV so that the PAR signal in the container could be detected and used. Quote:
All that being said, I think XiOUS has enough pointers now to forge is own opinion on the subject. And.. btw... if you are afraid you make a mistake in your encode vis-à-vis a given PAR (say 1.777 or 1.823), just make an anamorphic encode. You then will always be able to change the PAR as you wish (even to some weird values). So you can't f*** up your encode for ever..
PiXuS |
29th October 2004, 14:19 | #64 | Link |
Does it really matter?
really the mkv container shouldn't be used unless your dealing with multiple audio/subs. using it purely for the aspect ratio configuration serves no point. getting the aspect ratio to work fully in avi is probably in the long run going to be better. I support mkv for it's capabilities but it should be used for this purpose as a last resort.
29th October 2004, 14:59 | #65 | Link |
PiXuS,
Unfortunately, it seems pretty obvious that you don't require any help in this matter! This is strange because you asked why your anamorphic encodes don't come out properly... I've given you the answer and provided some anamorphic encodes for you to try! I also find it strange how you expect to view anamorphic encodes correctly without installing the "all important" and "necessary" Mpeg4 direct-show decoder filter - which I also provided a link to! Personally, I don't have any problems generating or playing back anamorphic encodes (via software or hardware players). Neither do many other forum members... Can you say the same? Cheers
29th October 2004, 16:03 | #66 | Link | ||
You say: This is strange because you asked why your anamorphic encodes don't come out properly.... Huh... are you confusing XiOUS with PiXuS? I never really asked for your help... Anyway... this is too weird. Me afraid, shudering and running away !!
PiXuS |
29th October 2004, 16:31 | #67 | Link |
Can one of you re-name yourself to say... Stan
30th October 2004, 17:41 | #68 | Link |
Just wanted to post some filesizes from my encodes of The Princess Bride (the softest, noisiest DVD I've ever seen):
@ 720x416 HR - 974,926,523 LR - 815,469,405 ULR - 773,913,937 ULR - 762,522,443 (using Deen then LimitedSharpen) The first three have no processing except IVTC, Lanczos4 and UnDot. The last one I added Deen and LimitedSharpen before the resize. The problem with this movie is that since it is so noisy, scenes that show the sky, or some other constant-color background, it seems that the brightness of that area fluctuates, and there is some blocking. The blocking is not so obvious in the HR matrix and very evident in the ULR matrix, as it averages more. To correct the problem i just used UnFilter, Resize to 640 and Undot. Deen was making the already soft image just look like a VHS transfer anyway. Anyway, that ULR matrix is pretty good! I even made a 1CD encode of The Truman Show at 640 with the full AC3 that looked great! Thanks! |
30th October 2004, 17:51 | #69 | Link | |
Cheers
30th October 2004, 18:57 | #70 | Link |
Mr. Sandman
@LoKi128: EQM V3ULR produces blocks when compressibility is really too low. Helping compressibility and removing noise with filters like UnFilter(x,x), UnDot() or RemoveGrain(mode=2) will produce a great looking 1CD backups.
Temporal denoisers like Convolution3d or TemporalCleaner will help a lot with extremely noisy sources. Keep in mind most DVDs have added noise too and and low-bitrate matrices tends to quantize noise (high-frequencies) with higher coefficients (less details). That may result in fluctuating blocks in flat or gradient coloured areas. If you want to remove blocks just use a high bitrate matrix (and 2 CDs or more CDs...) or remove as much noise as you can (with filters) but trying to keep the details. Anyways dont confuse the noise with the film grain...
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 30th October 2004 at 19:48. |
30th October 2004, 22:29 | #71 | Link | |
Lately, I've come across the aiming "kill the noise, keep the grain" several times. But I still wait for an answer, from any of the proposers, to this question: 1. What's the difference, from a filter's or an encoder's point of view, between "noise" and "grain", so that either one shall be able to distinct between them two? 1a. What's the actual benefit of the distinction, which most likely will be very unsure anyways? From my limited experience, impressing the audience with details on terminology helps the filter very little, and the encoder even less. Try encoding Alien² with "kill the noise, keep the grain". I give an ensurance on having BIG fun
- We´re at the beginning of the end of mankind´s childhood - My little flickr gallery. (Yes indeed, I do have hobbies other than digital video!) |
30th October 2004, 23:22 | #72 | Link |
Moderator, Ex(viD)-Mascot
From the encoder's side there isn't really a difference, granted. It is more the viewer's impression that determines which is which. Still, the subjective difference can be quite staggering. A certain amount of 'grain' will usually create the (false) impression of a higher level of detail, while just a bit more 'grain' will seem annoying and hence be called 'noise'. I strongly feel that everything below the personal, subjective 'grain'-threshold should be kept, even if it means using a higher bitrate. My personal threshold of what I perceive as 'pleasant' grain is very low, of course. When I denoise I would not denoise to a perfectly clean picture (I guess you could summ that up as 'kill the noise, keep the grain').
Sure, I could add the noise on playback via ffdshow but it seems nonsensical to me to first remove information from the video by filtering out the noise in order to 'recreate' or better 'invent' a clean picture that wasn't really there in the first place, and afterwards try to attain a 'natural' (as I perceive it) look to it again. Even if this would safe me quite a lot of diskspace/bitrate. Still, I've got to say I understand fully that others perceive this completely different - people I really respect, like -h for example, preferred to denoise video as much as possible. Excuse this late-night rant. Good night.
It's a man's life in Doom9's 52nd MPEG division. "The cat sat on the mat." ATM I'm thoroughly enjoying the Banshee - a fantastic music player/ripper for Linux. Give it a whirl! |
31st October 2004, 14:13 | #73 | Link |
Mr. Sandman
IMHO noise and film grain are 2 different things.
They're distingushable coz the "dot" diameter is different: grain is "larger" while noise is much "smaller" (but sometimes not too much) and keeps randomly moving every frame. My ideal filtering is exactly "kill the noise, keep the grain".
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! |
8th November 2004, 14:38 | #74 | Link |
Mr. Sandman
IMPORTANT NOTE:
There's a recently discovered bug in Xvid that affects all 1.xx versions with Trellis Quantization. Some matrices trigger an overflow in trellis causing visible blocking at certain quants. One of them is EQM V3HR (but other matrices were reported as well). There are 2 workarounds (at least i found those 2 only): disable Trellis Quantization OR limit the MinQ and MaxQ to 2-31 respectively.
MPEG-4 ASP Custom Matrices: EQM V1(old), EQM AutoGK Sharpmatrix (aka EQM V2), EQM V3HR (updated 01/10/2004), EQM V3LR, EQM V3ULR (updated 04/02/2005), EQM V3UHR (updated 17/12/2004) and EQM V3EHR (updated 05/10/2004) Info about my ASP matrices. MPEG-4 AVC Custom Matrices: EQM AVC-HR Info about my AVC matrices My x264 builds. Mooo!!! Last edited by Sharktooth; 9th December 2004 at 14:20. |
10th November 2004, 14:03 | #76 | Link |
Mr. Sandman
Thanks for your feedback pwh04
18th November 2004, 16:20 | #77 | Link |
Mr. Sandman
I have updated EQM V3ULR. Any feedback will be appreciated.
18th November 2004, 16:26 | #78 | Link | |
I'm afraid we've to stop
Gordian Knot Family: Gordian Knot: website, download Auto Gordian Knot: Website and download, tutorial, FAQ |
18th November 2004, 16:39 | #79 | Link |
Mr. Sandman
Better I-Frame quantization. Ark provided me a clip where I-Frames were blocky, and those blocks were compromising also the next P and B frames.
I think i have fixed it, but some feedback will be appreciated.
