Old 18th January 2011, 01:00   #11021  |  Link
Capsbackup
Just as a note, I'm including SmoothDeinterlacer() as an option for deinterlacing in the next release. I've found that on some sources it can make a considerable difference. I've also added a deinterlacing option that leaves the source alone -- but adds "fake-interlaced" to the command line for sources that are actually progressive but are marked as interlaced to meet the standard.
I will be on the lookout for some of my Blu-ray sources to try this feature out on for this next release.
Still having fun too!
Old 18th January 2011, 02:26   #11022  |  Link
larrsz
Bitter Old Geek
larrsz's Avatar
Ongoing issue.."tsmuxer.exe has stopped working"...
I have had this happen several times. The latest today. Any suggestions?
Current beta (Jan. 16), Win Vista 64, movie only, 1080 to 720p.
larrsz is offline   Reply With Quote
Old 18th January 2011, 02:53   #11023  |  Link
Capsbackup
Try either removing the subtitles or not resizing to 720. Does it work then?
Old 18th January 2011, 04:46   #11024  |  Link
larrsz
Bitter Old Geek
larrsz's Avatar
will try...
Old 18th January 2011, 13:33   #11025  |  Link
colinhunt
Very nice x 2.
Old 18th January 2011, 14:28   #11026  |  Link
larrsz
Bitter Old Geek
larrsz's Avatar
OK, changing to 1080p makes it run all the way through. Is this a known issue?
Thanks for the advice.
Old 18th January 2011, 15:01   #11027  |  Link
Crocluvr92
Iron Man 2 can't seem to encode for me, any suggestions?
[08:58:52] BD Rebuilder v0.37.01 (beta)
- Source: IRON_MAN_2_D1_AC
- Input BD size: 39.10 GB
- Approximate total content: [02:48:55.615]
- Target BD size: 22.95 GB
- Windows Version: 6.1 [7600]
[08:58:58] PHASE ONE, Encoding
- [08:58:58] Extracting A/V streams [VID_00394]
- [08:58:58] Reencoding: VID_00394 (1 of 49)
- [08:58:58] Collecting video information
- Rate/Length: 23.976fps, 6 frames
- [08:58:58] Reencoding: VID_00394, Pass 1 of 1
- [08:59:00] Video Encode complete
- [08:59:00] Reencoding audio tracks (if req'd)
- [08:59:00] Multiplexing M2TS
- [08:59:00] Extracting A/V streams [VID_00813]
- [08:59:02] Reencoding: VID_00813 (2 of 49)
- [08:59:02] Reencoding secondary video [TRK_02]
- [08:59:03] Collecting video information
- Rate/Length: 23.976fps, 163 frames
- Bitrate: 17,038 Kbs
- [08:59:03] Reencoding: VID_00813, Pass 1 of 1
- Encode failed. Retrying.
- Reached retry limit. Aborting.
- BD-Rebuilder v0.37.01 (beta)
- HAALI Splitter: Ok
- FFDSHOW: 3326, Ok
- FFDSHOW MPEG2 set to "libmpeg2": Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[08:59:03] - Failed video encode, aborted
Crocluvr92 is offline   Reply With Quote
Old 18th January 2011, 15:39   #11028  |  Link
Capsbackup
I think it's the subtitles, or at least I remember reading something regarding subtitles and resizing to 720P.
You could try to resize to 720P but remove the subtitles from the backup and see if it works.
Old 18th January 2011, 15:47   #11029  |  Link
Capsbackup
As with almost all errors of this nature, uninstalling Avisynth, ffdshow and haali, delete the program folder for haali, reboot and reinstall those three apps from page one of this thread.
If you have any other codec packs installed, either uninstall them or invite problems like this again.
Old 18th January 2011, 16:16   #11030  |  Link
Yes. There are some subtitles that simply won't resize and TSMUXER fails. Don't know why.
jdobbs.softworks@gmail.com
Old 19th January 2011, 01:06   #11031  |  Link
By-Tor
I'm sorry to mention this................. but I am trying to back up the pacific series which has ( I know) secondry audio dts
which i know you are working on....................... all be it the back burner
i just wish i could get to do it but i can't
i've tried sorry to mention dvdfab but its worked on the first three disc's
but disc 4 and disc 5 have poor pixelation on the start up screen.............I know i'm being picky. but i know that the quality of BDRE is far better
I was hoping you could upscale your work on dts 2 audio please
By-Tor is offline   Reply With Quote
Old 19th January 2011, 01:34   #11032  |  Link
larrsz
Bitter Old Geek
larrsz's Avatar
yep, removing subtitles also fixes it.
Old 19th January 2011, 03:36   #11033  |  Link
Well, your definition of "works" might be different than mine. If it runs but looks awful -- that's not "works" for me. The reason I watch blu-ray is for the quality.
An experimental version of the secondary DTS-Express code will be in the next release. You will be able to enable the function with a hidden option.
Old 19th January 2011, 03:44   #11034  |  Link
Capsbackup
I couldn't agree more!
Excellent, very exciting!
Will this release also include IGS menu support?
Old 19th January 2011, 03:48   #11035  |  Link
Yes, it's actually the same code that supports both. Remember, though, it'll still be experimental (interpret that as "use a BD-RE").
Old 19th January 2011, 03:57   #11036  |  Link
Capsbackup
Will do!
I have 4 BD-RE's and several Blu-rays with DTS Express secondary audio, so I will be running many tests and will let you know my results.
Old 19th January 2011, 06:27   #11037  |  Link
Originally Posted by Voyeurism View Post
I originally noticed the sync while watching a burned copy of the rebuilt BD5, played back on my PS3. Since I noticed it, I have been using VLC after the rebuild to play the m2ts file that BD-RB outputs so that I can check the audio before burning to disc.
Since first noticing the sync problem I've done about 4-5 rebuilds of other discs using exactly the same settings (I assume - I never touch any of them) which have worked without any sync problems. "New Moon" and "The Curious Case of Benjamin Button" are the only discs I've experienced it with so far.
I copied your settings into my INI file and ran "New Moon" -- the sync is perfect.
Old 19th January 2011, 08:04   #11038  |  Link
Voyeurism
I assume that you checked the sync throught the movie - on my rebuild it seems to get more out of sync towards the end?
If so I guess it must be something to do with my setup - any suggestions on where to start looking?
Voyeurism is offline   Reply With Quote
Old 19th January 2011, 12:58   #11039  |  Link
By-Tor
Hi jdobbs, my definition of "works", appears to be the same as yours as i prefer to use "bd reb' "as the quality of back-up is excellent, it's just i wanted all the features on the disc's which includes the dts-express secondry audio, so it is great news that you will put out an experimental version in the next release.
great work keep it up
Old 19th January 2011, 14:39   #11040  |  Link
I did. It syncs all the way through.
