13th October 2010, 20:07 | #261 | Link |
But if avisynth would deinterlace the entire video before proceeding to the next step, it too would need to store all the deinterlaced frames somewhere. What you're trying to do is theoretically impossible.
13th October 2010, 20:26 | #262 | Link |
And what about storing like 10 or 20 frames only? Deshaker needs to 'know' multiple frames of course in order to smooth the stabilization factor among the frames I guess. But can Deshaker also do this on the fly, so without needing all frames but just 10 or 20 instead? So in other words: how many frames does Deshaker take into account when it is smoothing the displacement corrections for every frame?
13th October 2010, 20:45 | #264 | Link | |
13th October 2010, 21:10 | #265 | Link |
Yes, I understand. I won't ask you to rewrite Deshaker .
I think the firstpass is not part of the 'Filter graph' (see here: http://avisynth.org/mediawiki/The_sc...e_filter_graph , thanks Gavino). That's why it is skipped I guess. It's no option for me to deinterlace the video twice, so I think it's best to render the deinterlaced video and store it phyisically. Then open it in VirtualDub and execute the Deshaker plugin there. Some disadvantages: I have to store the big deinterlaced video and I have one more intermediated video file. I guess I have to live with that . |
25th May 2011, 04:16 | #266 | Link |
Hi Guth, and everyone here, it's been awhile, I've gotten another shot which I wanted to stabilize but like my previous attempt and going with your suggestions, I cannot get it to deshake. The footage itself isnt that shaky but I want to as smooth as possible. I am ware that the footage may be abit dark and soft, but it is in 1080p50, I have brighten and sharpened it in the hopes that it might improve but no joy
The footage is here itself: http://www.megaupload.com/?d=N6WPMO6L abit large but everything should be there (quality wise). I hope I can get this to be deshaked and I would really appreciate it if anyone can. Look forward hearing back guys |
26th May 2011, 20:53 | #269 | Link |
Yes, I was able to download it now.
That clip has a few problems:
Here are some settings that work ok. They can probably be finetuned a bit, but I can't do *all* the work for you. |
3rd July 2011, 14:56 | #270 | Link |
Pig on the wing
Is it possible to determine the frame with the largest borders by checking the log file? I.e. is it always the frame with the largest detected horizontal or vertical pan? This also brings up a feature request: ability to limit the correction by amount of pixels needed for borders
3rd July 2011, 22:33 | #271 | Link | |
The max. correction limit settings limit the max. correction (= border size) coming from x-pan, y-pan, rotation and zoom, respectively. If you want to limit the resulting *total* max. border size instead, you can use an edge compensation setting that results in no borders, and then zoom out a little using the extra zoom factor setting. With a little math or experimentation, you can convert your max. border pixels to a zoom factor. |
5th July 2011, 20:37 | #272 | Link | |
Pig on the wing
I meant that I'm willing to sacrifice "n" pixels of each side throughout the whole long clip so if I could tell Deshaker to do a maximum correction of worth "n" pixels of borders, I could crop off that many pixels from each side and have no borders in the final video.
6th July 2011, 09:20 | #273 | Link | |
The max. correction limit settings affect how much zoom will be added do avoid the borders. About the resampling, Deshaker will resample once no matter what settings you use. It can't stabilize without doing a resampling. But it will never ever do two resamplings. Using the extra zoom factor setting, for example, or using edge compensation zooming, won't cause another resampling. Last edited by guth; 6th July 2011 at 09:26. |
6th July 2011, 10:29 | #274 | Link |
Pig on the wing
Then I'm mistaken as I thought that without edge compensation Deshaker only shifts the image (and does not do any kind of resizing) to stabilize the video. So basically what I'm after is to limit this shift to be max n pixels in one frame horizontally or vertically. Kind of like what DePanStabilize in Avisynth has in parameters dxmax and dymax.
6th July 2011, 11:04 | #275 | Link | |
You are right that Deshaker doesn't resize the image when you don't use any edge compensation (and also disable zoom stabilization and extra zoom factor and use same destination video size as the source). But "resize" and "resample" aren't the same thing. Last edited by guth; 6th July 2011 at 11:25. |
19th July 2011, 21:52 | #276 | Link |
Deshaker works well for me, but how do I increase it's amount dramatically—so almost all camera motion is removed?
In the video I'm trying to sabilize all motion is not wanted and I target a not moving element in a static scene. |
20th July 2011, 07:51 | #277 | Link |
You control the smoothness with the motion smoothness parameters. You can even set them to -1 to remove camera motion completely (i.e. let the position be fixed at the position of the first frame). If the video still moves after that it's not because of camera motion, but because Deshaker has problems in the matching process during pass 1.
I'm not sure why you just target a single non moving element. Normally, you get much more reliable output if you target the whole background. Otherwise, especially zoom and rotation probably won't be reliably detected, so you might want to turn off the settings "detect zoom" and "detect rotation" if you must target a single element. Also, you might want to decrease the value of "discard motion of blocks that move > X pixels in wrong direction", to really ignore everything that moves just a tiny bit. |
31st July 2011, 16:26 | #278 | Link | |
And if you don't want to degrade the quality of the frames at all, you can set the resampling method to "Nearest neighbor". Then, it will pan in whole pixels. I'm not saying it's a good idea, though. |
1st September 2011, 08:26 | #280 | Link |
Deshaker Version 3.0 review
A review of Deshaker 3.0 with some tips and tricks is now available at http://deshaker.blogspot.com.
