3rd December 2010, 10:46 | #10362 | Link |
I made a full backup of Toy Story 3 from original region A BD to BD-25 using BD-Rebuilder default settings.
Everything seems fine, but the movie freezes every time that there's a specific language scene and plays back again seconds after. Did anybody went through this ? Is it a BD-Rebuilder bug ? Sorry if I insist with this question, but it's making me mad... |
3rd December 2010, 13:51 | #10363 | Link |
cnote
Error?
Overall progress reaches 100% but I run into a snag shortly after. Can anybody help me? Thank you in advance. This recently started. I am a newb, but have successfully backed up over 100 without a real issue. Thank you much! Oh and the only change that has been made to my machine has been attaching a new external hd. I highly doubt that has anything to do with this but you never know.
----------------------- [00:16:51] BD Rebuilder v0.36.04 (beta) - Source: PACIFIC_DISC1 - Input BD size: 14.07 GB - Approximate total content: [00:52:04.830] - Target BD size: 7.84 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Quality: High Quality (Default), Two Pass - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [00:16:51] PHASE ONE, Encoding - [00:16:51] Extracting A/V streams [VID_00001] - [00:25:06] Reencoding: VID_00001 (1 of 1) - [00:25:07] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 74,921 frames - Bitrate: 15,000 Kbs - [00:25:07] Reencoding: VID_00001, Pass 1 of 2 - [01:27:44] Reencoding: VID_00001, Pass 2 of 2 - [04:37:57] Video Encode complete - [04:38:00] PredictAndEncode() 00075 2809 [07:27:25] - Aborted by user request ----------------------- [07:28:07] BD Rebuilder v0.36.04 (beta) - Source: PACIFIC_DISC1 - Input BD size: 14.07 GB - Approximate total content: [00:52:04.830] - Target BD size: 7.84 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Quality: High Quality (Default), Two Pass - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 - Resuming from previously started job. [07:28:09] PHASE ONE, Encoding - [07:28:09] Reencoding audio tracks (if req'd) - [07:31:30] Multiplexing M2TS - Error in attempt to multiplex: MUX_00001.meta - Can't open file: C:\USERS\BOSS\DESKTOP\WORKFILES\VID_00001.AVS.264 [07:31:30] - Failed to build structure, aborted ----------------------- [07:41:12] BD Rebuilder v0.36.04 (beta) - Source: PACIFIC_DISC1 - Input BD size: 14.07 GB - Approximate total content: [00:52:04.830] - Target BD size: 7.84 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Quality: High Quality (Default), Two Pass - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 - Resuming from previously started job. [07:41:14] PHASE ONE, Encoding - [07:41:14] Multiplexing M2TS - Error in attempt to multiplex: MUX_00001.meta - Can't open file: C:\USERS\BOSS\DESKTOP\WORKFILES\VID_00001.AVS.264 [07:41:15] - Failed to build structure, aborted ----------------------- [07:41:24] BD Rebuilder v0.36.04 (beta) - Source: PACIFIC_DISC1 - Input BD size: 14.07 GB - Approximate total content: [00:52:04.830] - Target BD size: 7.84 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Quality: High Quality (Default), Two Pass - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 - Resuming from previously started job. [07:41:25] PHASE ONE, Encoding - [07:41:25] Multiplexing M2TS - Error in attempt to multiplex: MUX_00001.meta - Can't open file: C:\USERS\BOSS\DESKTOP\WORKFILES\VID_00001.AVS.264 [07:41:25] - Failed to build structure, aborted ----------------------- [07:41:42] BD Rebuilder v0.36.04 (beta) - Source: PACIFIC_DISC1 - Input BD size: 14.07 GB - Approximate total content: [00:52:04.830] - Target BD size: 7.84 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Quality: High Quality (Default), Two Pass - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 - Resuming from previously started job. [07:41:43] PHASE ONE, Encoding - [07:41:43] Multiplexing M2TS - Error in attempt to multiplex: MUX_00001.meta - Can't open file: C:\USERS\BOSS\DESKTOP\WORKFILES\VID_00001.AVS.264 [07:41:43] - Failed to build structure, aborted Last edited by jdobbs; 3rd December 2010 at 15:37. |
3rd December 2010, 15:32 | #10364 | Link | |
I've done the U.S. version of "Toy Story 3" in both full and movie-only backups and it works correctly. |
3rd December 2010, 15:42 | #10365 | Link | |
3rd December 2010, 20:58 | #10366 | Link |
I had the same problem with the expendables. The commentaries are all mixed in with the movie files and I couldn't find a way to eliminate the commentary files. These stream files with the commentaries are numbered from 00420 to 00431 but if they are deleted from the recording then part of the movie is deleted also. I could not find any one file that contained the movie only---somebody said that files 0004 and 0006 contain the 2 versions of the movie only, but if that is the case, neither of those 2 files will open and they do not contain much data either. anybody have any ideas?
3rd December 2010, 21:11 | #10367 | Link | |
Did U.S. version have foreign language scenes ?? |
3rd December 2010, 23:54 | #10369 | Link | |
4th December 2010, 13:11 | #10370 | Link |
instabil videopicture in joined multipart-m2ts videostream!
hi there,
iīm using the latest version of bd-rebuilder to encode a multipart bd-movie (movie-only). everything worked fine (win7 x64, LAVF Decoding active, "degrainmedian" as avs-filter), but while i was watching the rebuildet AVCHD-Disc on my bd-player "philips bdp7500s2" the picture seemed to be instabil when one m2ts-part goes over to the next m2ts-part of the joined movie-stream. older bd-rb releases didnīt had this problem, i gues. i have tryed two differend movietitels with multipart-m2ts video... no change! could it be that the LAVF decoding feature causes this problem? sorry for my english, but iīm a little bit out of practice. thatīs all, thanks for comments! PS: the source video-codec was once avc/h264 and second vc-1 Last edited by pididdi; 4th December 2010 at 14:01. Reason: additional description |
4th December 2010, 14:46 | #10371 | Link | |
4th December 2010, 15:44 | #10372 | Link | |
To counter this problem, BD-RB always uses LAVF for multi-part sources (no matter how you have it set) -- unless, of course, you have forced it to use AVS by choosing a filter or resizing. Bottom line: get rid of the filter and the problem will go away. |
4th December 2010, 16:02 | #10373 | Link |
Banned
same Problem again with Cop Out Bluray. Main Movie has some m2ts Files, and some m2ts files from the main movie are 1pass encoded, because of "quicker encode for extras" is enabled. The part of the movie is very pixelated and unwatchable. I think i should encode every Bluray with main movie in more than 1 m2ts file with "quicker encode for extras" disabled. |
4th December 2010, 16:21 | #10374 | Link | |
Please send me the INI file that was used when you encountered a problem in "Cop Out". Also send me the INF file that resulted from the encode. Also note that "Quick Encode" isn't the only time one-pass is used. It can be (correctly) selected as a result of "Automatic" settings, and applied to all parts of a multipart source. So the picture you provided doesn't mean anything to me. One-pass could very possibly be the correct method for that source. But, as we all know, it's always possible there is something I'm missing... and if there is, I'll fix it. Last edited by jdobbs; 4th December 2010 at 16:38. |
4th December 2010, 20:15 | #10375 | Link |
Banned
Hey jdobbs it's me again ^^
Edit: Get it to work if i select "Use X264's internal LAVF for encoding" But maybe usefull for you?! New problem! Bluray: VACANCY/Motel Settings: Code:
[Options] VERSION=0.36.0.4 AUDIO_TO_KEEP=deu; SUBS_TO_KEEP=deu; MODE=0 ENCODE_QUALITY=0 ONEPASS_ENCODING=2 AUTO_QUALITY=1 TARGET_SIZE=23500 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 DEINTERLACE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=1 REMOVE_WORKFILES=1 MOVIE_ONLY_LOOP=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=1 USE_LAVF=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23450 QUICK_EXTRAS=1 [Paths] SOURCE_PATH=F:\ WORKING_PATH=E:\BLURAY\MOTEL BD 25\ Code:
[Status] LABEL=VACANCY VERSION=v0.36.04 (beta) SOURCE_SIZE=30316958574 SOURCE_VIDEO_SIZE=30253953024 TARGET_SIZE=24641536000 REDUCTION=.812407239163167 RESIZE_1080=0 AUDIO_TO_KEEP=deu; SUBS_TO_KEEP=deu; BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=0 QUICK=1 ENCODE_STEP=1 [00081] AUDIO= PGS= M2TS_TARGET=96040106 Code:
----------------------- [20:11:30] BD Rebuilder v0.36.04 (beta) - Source: VACANCY - Input BD size: 28,23 GB - Approximate total content: [02:01:25.236] - Target BD size: 22,95 GB - Windows Version: 6.1 [7600] - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [20:11:30] PHASE ONE, Encoding - [20:11:30] Extracting A/V streams [VID_00081] - [20:11:34] Reencoding: VID_00081 (1 of 11) - [20:11:34] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.440 frames - [20:11:34] Reencoding: VID_00081, Pass 1 of 1 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - BD-Rebuilder v0.36.04 (beta) - Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [20:11:39] - Failed video encode, aborted Last edited by KeVe1983; 4th December 2010 at 20:20. |
4th December 2010, 20:29 | #10376 | Link | |
Can you post the file: "VID_00081.AVS"? If it runs with LAVF, it would make sense that it was something in the AVS file.
Also... do you have MPEG-2 decoding enabled in your FFDSHOW settings? That's the most likely problem. Quote:
4th December 2010, 21:31 | #10379 | Link | ||
5th December 2010, 15:02 | #10380 | Link |
Banned
i've deleted the Disk and the Encode after encoding, so i cant show you the inf, or ini. Sry! My Setting: Full Backup Quicker Encode for Extras BD 25 High Quality (default) - 2pass No reencode for Audio LAV was disabled The Encode runs fine, but the result was not good. A part of the end of the movie was 1pass encoded. It was very pixelated. I get the Disc again today and tell you which m2zs file it was. I had the same problems with Harry Potter 1 and 2. The Extended ones. So the extended parts of the movie where pixelated. |
