21st December 2019, 03:40 | #7281 | Link |
I tested an older version of ffmpeg/x265 and it worked fine. Unfortunately the latest ffmpeg build still has x265 3.2+15. I think I will have to use external x265. How could I pipe ffmpeg to external x265 for 2-pass please? |
21st December 2019, 05:44 | #7282 | Link |
I don't really know shell syntax, but what I'd normally do for standalone x265 would be convert my input files to decompressed .y4m with ffmpeg (ffmpeg -i example_input.file example_output.y4m), then convert the y4m using x265. (x265 example_output.y4m --my_settings -o example_output.hevc) You'll need enough free disk space for the whole .y4m to be stored, and the output will be a raw HEVC stream that needs to be muxed with ffmpeg again-- although that shouldn't pose any problems, unless you've got two buggy libraries in one ffmpeg at once.
21st December 2019, 10:37 | #7283 | Link | |
Angel of Night
ffmpeg -i example_input.file -f yuv4mpegpipe -strict -2 - | x265 - -o example_output.hevc |
23rd December 2019, 04:48 | #7285 | Link | |
ffmpeg -i example_input.file -f yuv4mpegpipe -strict -2 - Code:
x265 - -o example_output.hevc The | (pipe) connects stdout to stdin. |
23rd December 2019, 20:07 | #7287 | Link |
Pig on the wing
The presets were changed at one point. The old "veryslow" became "slower" etc.
24th December 2019, 20:48 | #7288 | Link | |
How to correctly signal HLG with x265?
So far I'm using following command line Code:
--colorprim bt2020 --transfer bt2020-10 --colormatrix bt2020nc --atc-sei 18 Quote:
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 24th December 2019 at 20:58. |
25th December 2019, 13:13 | #7290 | Link | |
--transfer bt2020-10 Code:
Transfer characteristics : HLG / BT.2020 (10-bit) Code:
Transfer characteristics : HLG / HLG
26th December 2019, 18:39 | #7291 | Link |
Broadcast Encoder
This is the command line of an HLG encode I've done recently:
--colorprim bt2020 --transfer arib-std-b67 --colormatrix bt2020nc --atc-sei 18 But... Atak_Snajpera made it popping back up in my mind by asking about it, so... should I include --pic-struct 0 as well? |
26th December 2019, 23:39 | #7292 | Link | |
Lost my old account :(
27th December 2019, 02:54 | #7293 | Link | ||
hello, may I have question?
What is right scrip for zones I tried this and i alaways get an error Quote:
27th December 2019, 06:39 | #7294 | Link |
Pig on the wing
I don't think x265 supports setting CRF in zones, you need to define q instead.
27th December 2019, 08:23 | #7295 | Link | |
The 'b' stands for bitrate multiplier so 1.3 will increase the bitrate of the frames designated within zones by a factor of x1.3 (or +30%). |
29th December 2019, 01:47 | #7296 | Link |
Guys,
When encoding do you use ssim-rdo? Do you see any difference? When is the best time to use this? During 2pass perhaps? or CRF? It takes longer when this is enabled.
