20th June 2020, 23:09 | #7661 | Link | |
There's a lot of other good stuff added between 3.0 and 3.4, though! https://x265.readthedocs.io/en/defau...easenotes.html |
25th June 2020, 15:08 | #7665 | Link |
New upload: x265 3.4+7-g38774073d
Fixed the normalization formula to ouput 0 to 1 and considered max chroma histogram SAD in histogram based scene cut detection |
27th June 2020, 17:19 | #7667 | Link | |
28th June 2020, 09:47 | #7668 | Link |
HolyWy Thank you i am test me Threadripper 2990wx 32 core
test 1080p 3min : http://prntscr.com/t7tvjc
28th June 2020, 09:56 | #7669 | Link | |
If you set them to the same values the reuse function should work like before. Last edited by Greenhorn; 28th June 2020 at 10:18. |
28th June 2020, 17:36 | #7670 | Link | |
QfG Group Germany
30th June 2020, 15:22 | #7672 | Link |
new FFMPEG 4.3 : https://www.videohelp.com/software/ffmpeg
1st July 2020, 01:05 | #7673 | Link |
So x265 3.4+9, they "fixed" --hist-threshold to avoid false positives. However it seems to do much worse than before (as well as 3.4+7, where they fixed the false positives).
I'm getting less I frames with --hist-threshold 0.005 (default 0.03) than the default scenecut algorithm.. Maybe my sample clip is not colorful enough.. Last edited by quietvoid; 1st July 2020 at 01:07. |
1st July 2020, 08:22 | #7674 | Link |
New upload: x265 3.4+9-g1fb7c7960
Improvements to hist-based scenecut algorithm. Add support for RADL pictures at IDR scenecuts |
1st July 2020, 12:05 | #7675 | Link | |
1st July 2020, 17:57 | #7676 | Link | |
Fewer I frames isn't problem in itself. The question is if it is not flagging edits and such as IDR. Beyond that, IDR and I should only be used when it improves compression efficiency, or as needed based on --keyint. |
1st July 2020, 18:26 | #7677 | Link | |
From what I understand, detected scene cuts should start with an I frame, as it is how adaptive keyframe placement works. |
2nd July 2020, 04:49 | #7678 | Link |
Does analysis-save always write such huge files at values above 1? I tried a 128MB sample file and it created a multi-gigabyte save file (writing at 60mb/s which significantly slowed down the encode).
Also, it only seems to work with ref=1 in the second pass if you are using --no-slow-firstpass , otherwise I get: Error reading analysis data. Incompatible option : <ref> This is with x265 3.3+5-g4a0cef17d+32 and 3.4+9-g1fb7c7960 |
3rd July 2020, 14:39 | #7680 | Link |
x265 v3.4+10-g7a640a2c1 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 10.1.0)
https://bitbucket.org/multicoreware/x265_git/commits/branch/master |
