Old 21st September 2015, 22:44   #13901  |  Link
hoju3508
@soneca, thanks for the feedback. It must be something going on with my setup.
@Atak, I didn't see "info.txt" in the dir.
There's a mkvinfo.txt and other *.avs files. What other file(s) would you like to see?
File 'C:\Temp\RipBot264temp\job1\video.mkv': container: Matroska [duration:1381046375000 segment_uid:6d0511f6bc06e68385e4dd211046d09a container_type:17 is_providing_timecodes:1]
Track ID 0: video (MPEG-4p10/AVC/h.264) [number:1 uid:1 codec_id:V_MPEG4/ISO/AVC codec_private_length:91 codec_private_data:01000000ffe1001367640029ac1b1a501e0089f97ff0001000100801003d68ea8f394747610e2315152088cc47366884a3a3b087118a8a904466239b34425d34baf37d7ebfafd7d7aeb5542242909c9e4fafc9fd7e4faf2726a4c0 language:und pixel_dimensions:1920x1080 display_dimensions:1920x1080 default_track:0 forced_track:0 enabled_track:1 packetizer:mpeg4_p10_video default_duration:41708333]
Let me clean up the dir and rerun.
-Hoju
http://valid.canardpc.com/cache/banner/1756465.png
Old 26th September 2015, 11:50   #13902  |  Link
BlockABoots
Me again, have noticed when doing batch encoding the first file that has finished encoding always has [error] at the start of the file name in the list once its finished encoding, the file seems to play fine however and no other files after the 1st one have this [error] placed at the start of the file......
any ideas?
BlockABoots is offline   Reply With Quote
Old 26th September 2015, 14:10   #13903  |  Link
What happens if you remove all those extra dots in file name?
Old 26th September 2015, 18:29   #13904  |  Link
BlockABoots
havent tried, but the other files (with similar amount of dots) encode without errors, it just always seems to be the first file to be encoded
Old 26th September 2015, 19:00   #13905  |  Link
Yeah I know but at least you can try with some oldschool names with only one dot Nevertheless I will try to reproduce this odd behaviour.
Old 30th September 2015, 20:47   #13906  |  Link
BlockABoots
Atak, do you know of any reason why i might be getting audio sync issues when encoding a mp4 file that has been edited in AvsPmod (avisynth)?? I have started to use OBS to capture my gameplays and OBS seems to output a .mp4 file format, now when i watch the raw file back there is no audio sync issues at all, but after i have edited the file with AvsPmod and then RipBot to encode it i seem to have sync issues on the outputted file from Ripbot!.
The audio sync issue seems to alter through the duration of the video as well, it will start off synced and then full out of sync and then get back into sync later on. Any ideas?
Old 1st October 2015, 09:13   #13907  |  Link
dirk362
Been using RB for couple of years now - great tool. Simple yet flexible, with good 2-pass file size accuracy. Just works.
I do have a 'feature request' - could you please add option via ini, or change mux cmd file, so that when working with mkv files the "--disable-track-statistics-tags" parameter is used.
Normally this is resolvable using environment variable MKVMERGE_OPTIONS, but that doesn't work with RB due to how this affects mkvinfo process at start.
If you have MKVMERGE_OPTIONS set then you get no audio in RB when creating the job, and the mkvinfo.txt file has an error of
Error: '--identify-verbose' can only be used with a file name. No further options are allowed if this option is used.
I appreciate it's not a bug nor indeed high priority. And you could argue it relates more to mkvtoolnix as feature rather than RB. But then in RB I can't automate things unless I remember to edit the mux cmd files after setup and before encode.
It's just one of those preference things, which is to keep the mkv file clean such that tools like mediainfo present information relevant to the encode..
dirk362 is offline   Reply With Quote
Old 1st October 2015, 14:05   #13908  |  Link
The problem is that AvsPMod uses DirectShowSource() for mp4.
DirectShowSource() is not frame accurate therefore you have a/v sync issues after editing (Trim function). If You intend to edit files you must use something else what guarantees frame accurate seeking.
Example with ffms
Old 1st October 2015, 15:35   #13909  |  Link
rc71
I'm getting a strange errors. First I can't use any custom profiles. I get a unrecognized tune. I use either the two default HEVC profiles, it works fine. I looked at the profile and it looks fine.
"--profile main10 --output-depth 10 --preset slow --tune animation "
FYI, I just installed 1.19.1 on a work domain computer. I am an admin.
rc71 is offline   Reply With Quote
Old 1st October 2015, 15:38   #13910  |  Link
rc71
The other problem I have is I can't batch file. The batch file works, but the files all have the same video as the first video encoded. I moved the program and the temp drive off C: in case it was some permission issue, but it seems that "video.265" does NOT get overridden.
Any suggestions.
Old 1st October 2015, 15:59   #13911  |  Link
gabbett1
Ripbot264 v1.19.1 error
So I've been trying to convert my Bluray Insurgent to an MP4 and the old version of Ripbot I had been using wouldn't find any audio tracks other than 2.0 versions. I decided to upgrade to this newest version, also updating all the components needed (AviSynth , Haali Media Spliter , ffdshow). I'm running windows 7 btw. So anyhow, now I can't demux my streams. I keep getting a demuxing error:
eac3to v3.29
command line: "J:\Blue Ray Ripping\Tools\eac3to\eac3to.exe" "J:\Rip\INSURGENT\" 1) 2: "J:\Temp\RipBot264temp\job1\video.mkv" -seekToIFrames 3: "J:\Temp\RipBot264temp\job1\audio_1_English.thd.w64" -down16 -down6 8: "J:\Temp\RipBot264temp\job1\8_subtitles_English_1080.sup" 9: "J:\Temp\RipBot264temp\job1\9_subtitles_English_1080.sup" 10: "J:\Temp\RipBot264temp\job1\10_subtitles_Spanish_1080.sup" 1: "J:\Temp\RipBot264temp\job1\chapters.txt" -progressnumbers -log="J:\Temp\RipBot264temp\job1\demuxlog.txt"
M2TS, 1 video track, 5 audio tracks, 3 subtitle tracks, 2:00:00, 24p /1.001
1: Chapters, 16 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: TrueHD (Atmos), English, 7.1 channels, 48kHz
4: AC3 Surround, English, 2.0 channels, 224kbps, 48kHz
5: AC3 Surround, English, 2.0 channels, 224kbps, 48kHz
6: AC3, Spanish, 5.1 channels, 640kbps, 48kHz
7: AC3 Surround, English, 2.0 channels, 224kbps, 48kHz
8: Subtitle (PGS), English
9: Subtitle (PGS), English
10: Subtitle (PGS), Spanish
[a03] thd, 48000, 7.1
Creating file "J:\Temp\RipBot264temp\job1\chapters.txt"...
[s10] Extracting subtitle track number 10...
[a03] Extracting audio track number 3...
[s08] Extracting subtitle track number 8...
[s09] Extracting subtitle track number 9...
[v02] Extracting video track number 2...
[a03] Decoding with libav/ffmpeg...
[a03] Mixing surround channels...
[a03] Reducing depth from 24 to 16 bits...
[a03] Writing W64...
[a03] The libav decoder reported error -1094995529 while decoding. <ERROR>
Aborted at file position 1048576. <ERROR>
I need help resolving this issue.
gabbett1 is offline   Reply With Quote
Old 1st October 2015, 16:09   #13912  |  Link
tune animation is still not implemented in x265. Do not use this option.
Any suggestions.
see what is happening in log.
@gabbett1
Try in eac3to thread
http://forum.doom9.org/showthread.ph...11#post1741111
You can also try DEMUX option in ripbot264
Old 1st October 2015, 16:24   #13913  |  Link
gabbett1
@gabbett1
I tried looking for a log but cannot find one. I use ripbot264 for the entire process. Found the demux option. I'll give that a try.
Old 1st October 2015, 16:30   #13914  |  Link
rc71
Thanks. Got the tune. As for the log, there are no errors. It just keeps using the same video.265. The audio is correct for each file, but the is the same for every file.
For now, I have to just do one at a time and remove the previous job. If I don't remove the job, it uses the same video.
Old 1st October 2015, 17:03   #13915  |  Link
gabbett1
@gabbett1
Tried using Demux and it just sits there saying
"Please wait... Analyzing selected streams..."
It's been saying that for over an hour now.
Old 1st October 2015, 17:46   #13916  |  Link
@RC71
Do you also see the same problem while encoding with x264?
Old 1st October 2015, 17:50   #13917  |  Link
rc71
batch
@RC71
I was just testing that thought.
I just had a SUCCESSFUL batch encode. I renamed the files to something very simple. The settings were reduced from 1080 to 480p to make it quick. I'm going to try again with files without so many . . . . and I'll update.
Old 1st October 2015, 21:26   #13918  |  Link
rc71
----------- UPdate --------------
I have no clue what happened, but it worked this time. I did rename all the files without any extra " . .. ." in it and used only the 10bit x265 profile.
Old 1st October 2015, 23:50   #13919  |  Link
soneca
Atak, in temp files on this screen should not indicate the drive for temporary files?
I'm using disk E.
Old 2nd October 2015, 04:28   #13920  |  Link
burt123
burt123's Avatar
Hi Atak, I have just noticed that in Batch Mode, I cannot import *.m2ts files, however, in "single" mode, you can.
In the drop down list of supported files Decrypted Blu-ray (*.m2ts *.mts), isn't available in Batch Mode.
Is there something that can be done about this ??? Please
burt123 is offline   Reply With Quote
