16th September 2014, 15:44 | #41 | Link |
Life's clearer in 4K UHD
Try doing what I did and 'cheat' MuxMan into thinking the DTS stream is compliant...
All you have to do is chop-off and save a few milliseconds from the beginning of a compliant (2013 bytes/frame) elementary DTS stream. And add it to the beginning of your 'non compliant' elementary DTS stream
16th September 2014, 16:40 | #42 | Link | |
AVStoDVD Dev
'samples per frame' = 512 or is that a constant for DTS? Bye |
16th September 2014, 16:54 | #43 | Link |
DTS can in theory go up to 4096 samples per frame, although 512 seems to be the most common at 48kHz.
16th September 2014, 16:59 | #44 | Link |
SuperVirus
AFAIK, all DCA encoders available (and they are not many ) use 512 samples per audio frame.
Also, I presume/hope that eac3to, LeeAudBi and MediaInfo take the time to measure the frame size, instead of assuming it always = 512 samples. Last edited by filler56789; 16th September 2014 at 17:16. Reason: better wording |
17th September 2014, 08:53 | #45 | Link |
512 is the standard value but is not mandatory.
From http://www.etsi.org/deliver/etsi_ts/...14v010301p.pdf NBLKS (Number of PCM Sample Blocks) This field indicates that there are (NBLKS+1) blocks (a block = 32 PCM core samples per channel, corresponding to the number of PCM samples that are fed to the core filter bank to generate one subband sample for each subband) in the current frame (see note). The actual core encoding window size is 32 × (NBLKS+1) PCM samples per channel. Valid range for NBLKS: 5 to 127. Invalid range for NBLKS: 0 to 4. For normal frames, this indicates a window size of either 4 096, 2 048, 1 024, 512, or 256 samples per channel. EDIT: To know the Actual Bitrate you need the fields from DTS header: NBLKS (Number of PCM Sample Blocks) FSIZE (Primary Frame Byte Size) (FSIZE+1) is the total byte size of the current frame including primary audio data as well as any extension audio data. Valid range for FSIZE: 95 to 16 383. Invalid range for FSIZE: 0 to 94. SFREQ (Core Audio Sampling Frequency) This field specifies the sampling frequency of audio samples in the core encoder, based on Table 5-5: Code:
Table 5-5: Core audio sampling (valid) frequencies 0b0001 8 kHz 0b0010 16 kHz 0b0011 32 kHz 0b0110 11,025 kHz 0b0111 22,05 kHz 0b1000 44,1 kHz 0b1011 12 kHz 0b1100 24 kHz 0b1101 48 kHz 8 x (FSIZE + 1) x Sampling-rate / (32 x (NBLKS + 1)) Examples: 8 x (2012 + 1) x 48 / (32 x (15 + 1)) = 1509,75 Kb/s 8 x (2011 + 1) x 48 / (32 x (15 + 1)) = 1509 Kb/s 8 x (1005 + 1) x 48 / (32 x (15 + 1)) = 754,5 Kb/s Seems MediaInfo 0.7.70 (in Advanced mode) can detect the exact FSIZE for NBLKS 15 (standard value). For the 3 samples before: Overall bit rate : 1509750 Overall bit rate : 1 510 Kbps Overall bit rate : 1509000 Overall bit rate : 1 509 Kbps Overall bit rate : 754500 Overall bit rate : 755 Kbps EDIT 2: I found dts's from surround Audio CD's with 1024 samples/frame: Code:
Number of PCM Sample Blocks .: 31 ( 1024 samples/frame) Primary Frame Byte Size .....: 3583 ( 3584 bytes/frame) Audio Channel Arrangement ...: 9 (5 C + L + R + SL + SR) Core Audio Samp. Frequency ..: 8 (44,1 kHz) Transmission Bit Rate .......: 22 (1411,2 Kb/s) MediaInfo show ok: Bit rate : 1234800 Bit rate : 1 235 Kbps BTW, ffdcaenc with -b 1411.2 for 44.1 KHz make: Code:
Number of PCM Sample Blocks .: 15 ( 512 samples/frame) Primary Frame Byte Size .....: 2047 ( 2048 bytes/frame) Audio Channel Arrangement ...: 9 (5 C + L + R + SL + SR) Core Audio Samp. Frequency ..: 8 (44,1 kHz) Transmission Bit Rate .......: 22 (1411,2 Kb/s)
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 17th September 2014 at 12:07. Reason: Add info |
17th September 2014, 15:24 | #46 | Link | |
SuperVirus
Thanks for the complete info, tebasuna51
BTW, and according to the file 4_dts-cae-4_cad-4_encode-decode.pdf, there exist two more "DVD-compliant" bitrates (for 2.0 and 2.1 only), 503.25kbps and 377.25kbps And yes, the «1-byte granularity» strikes again EDIT: Wow, ffdcaenc already supports them too Code:
File ........: D:\DVD-18\mlpdir\48tunntest.dts Size ........: 4844620 bytes ----------------------------------------- First Frame Info CRC present .................: 0 (Not) Number of PCM Sample Blocks .: 15 ( 512 samples/frame) Primary Frame Byte Size .....: 670 ( 671 bytes/frame) Audio Channel Arrangement ...: 2 (2 L + R stereo) Core Audio Samp. Frequency ..: 13 (48 kHz) Transmission Bit Rate .......: 12 (512 Kb/s) Embedded Down Mix Enabled ...: 0 (Not) Embedded Dynamic Range Flag .: 0 (Not) Embedded Time Stamp Flag ....: 0 (Not) Auxiliary Data Flag .........: 0 (Not) Mastered in HDCD format .....: 0 (Not) Extension Audio Descr. Flag .: 0 (Channel Extension XCh) Extended Coding Flag ........: 0 (Not) Audio Sync Word Insert. Flag : 0 (Sub-frame) Low Frequency Effects Flag ..: 0 (Not present) Predictor History Flag Switch: 1 (Yes) Multirate Interpolator Switch: 0 (Non-perfect Reconstruction) Encoder Software Revision ...: 7 (Current) Copy History ................: 0 (Definition deliberately omitted) Source PCM Resolution .......: 6 (24 bits) Front Sum/Difference Flag ...: 0 (Not) Surrounds Sum/Difference Flag: 0 (Not) Dialog Normalization Param. .: - 0 dB --------------------------------------------- Revised Info Total Frames ......: 7220 Duration ..........: 77.013 seconds. ( 0 h. 1 m. 17.013 s.) ------------------------------------------------- End Info Last edited by filler56789; 17th September 2014 at 15:33. |
17th September 2014, 15:47 | #47 | Link | |
9th December 2014, 03:44 | #48 | Link |
I tried ffdcaenc.exe-213_GCC.7z but stdin didnt work.
Input: - Output: G:\001.dts Bitrate: 1509 kbps Encoding... 0:00 [100.0%] Done.
Behappy BePack.v3.3BeHappy,BeSweet,BeLight,BeSplit,BeSliced,BdAC) with last plugin, encoder and extensions. Avisynth Movie Screenshot, thumbnails creator Last edited by siella; 9th December 2014 at 03:48. |
9th December 2014, 04:35 | #49 | Link | |
SuperVirus
I will TRY to fix the problem, since I'm not a programmer --- --- therefore, no guarantees... Last edited by filler56789; 9th December 2014 at 10:39. Reason: update |
9th December 2014, 11:18 | #50 | Link |
SuperVirus
FIXED - or at least I think so
637 #if defined(_WIN32) || defined(_WIN64) 638 639 #include <Windows.h> 640 #include <io.h> 641 #include <fcntl.h> 642 643 int32_t main( int32_t argc, char **argv ) 644 { 645 _setmode(_fileno(stdin), _O_BINARY); 646 _setmode(_fileno(stdout), _O_BINARY); 647 return dcaenc_main(argc, argv); 648 } 649 650 #else 651 652 int32_t main( int32_t argc, char **argv ) 653 { 654 return dcaenc_main(argc, argv); 655 } 656 657 #endif Last edited by filler56789; 9th December 2014 at 12:41. Reason: add code |
9th December 2014, 14:31 | #51 | Link |
Swallowed in the Sea
The following lines should be better...
637 #if defined(_WIN32) || defined(_WIN64) 638 639 #include <Windows.h> 640 #include <io.h> 641 #include <fcntl.h> 642 #endif 643 int32_t main( int32_t argc, char **argv ) 644 { 645 #if defined(_WIN32) || defined(_WIN64) 645 _setmode(_fileno(stdin), _O_BINARY); 646 _setmode(_fileno(stdout), _O_BINARY); 647 #endif 648 return dcaenc_main(argc, argv); 649 } 650 |
9th December 2014, 15:53 | #52 | Link | |
SuperVirus
10th December 2014, 04:04 | #53 | Link |
Many thanks, it is working without any problem now
Behappy BePack.v3.3BeHappy,BeSweet,BeLight,BeSplit,BeSliced,BdAC) with last plugin, encoder and extensions. Avisynth Movie Screenshot, thumbnails creator |
15th February 2016, 15:57 | #54 | Link | |
SuperVirus
https://raw.githubusercontent.com/fi...ING_ISSUES.TXT |
6th June 2016, 05:58 | #55 | Link |
SuperVirus
Better late than jamais... I added a configure file to the source-code, so that the users don't need to mess around with autoreconf anymore...
https://github.com/filler56789/ffdcaenc-2/releases |
30th June 2018, 12:44 | #57 | Link |
Much as I'd like to see 6.1 or 7.1 DTS encoding, as far as I know we still don't have 5.1 DTS encodes working correctly in hardware playback devices...
30th June 2018, 19:12 | #58 | Link |
Unavailable
Not with the code written by Patrakov && improved by Alexei Andropov, at least.
The following speaker layout is for the "extended surround" thing (6.0 and 6.1): Code:
13: FC, BC, FL, FR, BL, BR Code:
14: CL, FC, CR, FL, FR, BL, BR |
1st July 2018, 09:49 | #59 | Link | |
ffdcaenc.exe -i input_5.1.wav -o 768.dts -l -b 754.5 ffdcaenc.exe -i input_5.1.wav -o 1536.dts -l -b 1509.75 BTW 7.1 is only allowed in DTS HD (MA or HR) ffdcaenc only encode to standard DTS, also DTS-ES (6.1) is not supported: Error: Unsupported number of channels (only 1, 2, 3, 4, 5 and 6)!
1st July 2018, 11:47 | #60 | Link | |
But when I play the DTS.mkv and DTS.m2ts muxes in my OPPO, all I hear is a garbled mess and it crashes the player. EDIT: Perhaps I could try your samples?
