26th August 2020, 14:23 | #29921 | Link |
@meadrocks
Have you tried multipart sources other than those two? I don't have either of those discs. But I just did another test of a multipart source output to MKV and it worked fine. It was AVC... but I'll try redoing it in HEVC to see if it changes (I can't imagine why it would since that shouldn't affect a PGS stream). [Edit] Completed the HEVC encode -- no issue with the subtitles. I'll try MP4 output next. [Edit] Yes, the MP4 worked as well. Last edited by jdobbs; 26th August 2020 at 20:58. |
26th August 2020, 15:14 | #29922 | Link |
IIRC I have an European version of Watchmen DC. Let me find it and do some testing.
[Edit] Unfortunately it's not DC. It's the 165 min version and it's not multi part. ggtop Last edited by ggtop; 27th August 2020 at 16:49. |
30th August 2020, 04:03 | #29923 | Link | |
Elit Amans
When doing an ordinary bluray encode my Bitdefender acted up on bdrb.exe halfway into the encode claiming it to be ransomware and that it had infected two files. One nvidia file(don't remember wich one) and lastcmd.txt. Bitdefender autorestored them and I had to exclude bdrb.exe to be able to continue. //LD |
30th August 2020, 23:51 | #29924 | Link | |
BD-RB definitely modifies LASTCMD.TXT -- it always updates it with the last encode command (for debugging). It's silly to think that a text file could be "infected", though. It makes no changes to any NVIDIA files, not sure what that is about. |
31st August 2020, 00:50 | #29925 | Link | |
Elit Amans
//LD |
31st August 2020, 23:01 | #29926 | Link |
malware bytes flagged up version 09( i know were on 13 but i was having a problem creating a bd struture from a mkv import so wanted to see if and earlier version worked) as a threat
Malwarebytes -Log Details- Protection Event Date: 31/08/2020 Protection Event Time: 10:32 Log File: e7d454dc-eb6c-11ea-b3eb-0c9d9279b63b.json -Software Information- Version: 4.2.0.82 Components Version: 1.0.1025 Update Package Version: 1.0.29253 Licence: Trial -System Information- OS: Windows 10 (Build 19041.450) CPU: x64 File System: NTFS User: System -Blocked Malware Details- File: 1 MachineLearning/Anomalous.100%, C:\Users\xxxx\Desktop\BD_Rebuilder09\BDRB.exe, Quarantined, 0, 392687, 1.0.29253, , shuriken, , 447C0F9C095C02880FE9B16AB91499AD, 4865F0F4278C7D6775CA460B67EB320810F00AA07583541D5B8B2859AD8EB3C4 (end) Last edited by Mike-uk; 31st August 2020 at 23:05. |
1st September 2020, 19:24 | #29930 | Link | |
Special SeeD
Output video created by BD-RB with nvEnc gets reported as 3840x2176 by TsMuxerGUI and eac3to. Is that right?
1st September 2020, 22:19 | #29931 | Link | |
But, they do not give OS requirements. If the driver does not work under Win7-64, then I will have to look at something that does. |
2nd September 2020, 00:23 | #29932 | Link | |
Elit Amans
Longer technical answer: nVidia Developer Forums //LD |
2nd September 2020, 01:58 | #29933 | Link | |
I want to be just like Ch3vr0n when I grow up! |
2nd September 2020, 23:52 | #29938 | Link |
ddr5 and pcie 5 in 2021 for intel, looks like intel are making a good decision to almost skip pcie 4 since it was serverly delayed and jump straight to 5 in 2021
3rd September 2020, 18:37 | #29940 | Link |
Actually intel just anounced the 11th gen mobile CPU's. Native pcie gen 4 support, "more in 2021" and by more they probably mean 11th gen desktop CPU's. current announced cpu models won't support DDR5, but future ones will.
