#9102 | Link |
I'm having a performance issue with MeGui and a new computer build that is 7 times slower for AC3 encoding than my 10y old computer.
I'm drag n' dropping an mkv file with audio/video into the "Audio input" field, selected FFmpeg AC3 with these settings (nothing fancy) and that's about it. ![]() With my new AMD 3900XT, B550, 64GB 3200MHz DDR4, SSD nvme, Win10 it takes about 8 minutes to process. ![]() With my 10y old i7 2600K, P8P67, 16GB of RAM @ 1600MHz and 7200rpm HDD, Win7, it takes about 50 seconds: ![]() I ran several performance benchmarks (Cinebench R20, Prime95, OCCT, memtest and userbenchmark) and it seems like everything is working like it should. Yet, it's 8 times slower with MeGui AC3 encoding. Is the issue with MeGui or my computer? Can it be an Intel vs AMD thing? Last edited by Pringles; 24th December 2020 at 12:11. |
#9103 | Link | |
Sent from my SM-G986U1 using Tapatalk |
#9104 | Link | |
![]() EDIT: tried the same encoding several times, it yields the same results -> 8 minutes EDIT2: Tried your program and it's way faster so my understanding is that the issue comes from MeGui. ![]() Last edited by Pringles; 24th December 2020 at 14:10. |
#9105 | Link | |
Im curious, could you potentially send me the file in question so I can mess with it later? Sent from my SM-G986U1 using Tapatalk |
#9106 | Link |
Sorry I got mixed up with all the AC3 files I produced with MeGui and mixed up one MeGui aborted project with the result of your software which is working 100% fine and is way faster (about 30 seconds for this file).
#9107 | Link | |
#9108 | Link |
Development Update Server is reporting FFMS uodate not available on server. Been a few days now.
--[Error] [21/01/2021 8:28:44 AM] Failed to download package FFMS: File cannot be found on the server. --[Information] [21/01/2021 8:28:46 AM] Connected to server: http://megui.tmebi.de/test/ |
#9109 | Link |
Swallowed in the Sea
Update the update.xml file in update_cache subfolder as
<ffms type="file" requiredbuild="2624" build="64"> <filepath date="2021-01-17" version="20201123">ffms2-20201123-64.7z</filepath> </ffms> |
#9111 | Link |
Hello, I used to encode videos to x264 with One Click Encoder, Constant Quality, in x264 config page, of around 22.0, and this 30 minute tv recording used to come out to around 900+ kbps and 200-250 MB. I encode the same exact show and now the end result is 600 kbps video and 70-80 MB and the video looks super bad.
Was there a recent change to the profiles or something? I ask because I recently upgraded MeGUI from 2828 to 2913. First time I upgraded it in like 2+ years I think. I am wondering if this related. |
#9112 | Link | |
#9113 | Link | |
https://forum.videohelp.com/threads/...rent-filesizes Maybe the bundled x264 is broken, or whatever MeGUI uses to pipe the script output to the encoder these days (ffmpeg?). I'm still on XP and for 32 bit windows there's no middle man. The script output is piped directly to the encoder. I'm using MeGUI 2913 though, and the file sizes are fine (although I think I rolled x264 back to the previous version as the bundled one no longer runs on XP). I'd suggest rolling x264 back to the previous version and if that doesn't fix it, try rolling back ffmpeg or whatever MeGUI uses these days, assuming you're running a 64 bit version of Windows. 32 bit MeGUI encodes with 64 bit x264 on 64 bit Windows, and I think it uses ffmpeg to pipe the video to the encoder. I've no idea if the same applies to the 64 bit version of MeGUI. Last edited by hello_hello; 1st February 2021 at 16:44. |
#9114 | Link |
1) I want to re-encode a lot of video files (FROM mpeg2-mkv TO avc-mkv). The only requirement is: output bitrate should be half of original (i.e. twice smaller). All original files has different bitrate, so output bitrate should be calculated somehow. But how? 2) How to preserve tags (Movie name, Released date, Comment, DIRECTOR, Url, WRITTEN_BY) from original mkv-files? New encoded files doesn't contain these tags. Thank you in advance! |
#9115 | Link |
Go,
This don't comply with your requirements, but as no-one else replied I thought might be something to play with. Maybe you can make some use of it. Go.Bat [see REM's ie REMarks] Code:
REM We DO NOT LIKE SPACES IN FILE NAMES (REM == REMark ie comment) REM We DO NOT LIKE ACCENTS IN FILE NAMES. setlocal REM Where to Find ffmpeg set FFMPEG="C:\BIN\ffmpeg.exe" REM Where to get INPUT files, No terminating Backslash, "." = current directory (ie same as dir .bat file) set INDIR="." REM Where to place OUTPUT files, No terminating Backslash. "." would be same as .bat file, ".\OUTPUT" = OUTPUT folder in same directory as bat file. set OUTDIR=".\OUTPUT" REM OUTPUT:- Video: codec=x264, Preset=Slow, CRF=23, Audio: aac 96Kb/s, Output in mkv container SET VCODEC=libx264 SET PRESET=slow SET CRF=23 SET ABITRATE=96K SET CONTAINER=MKV REM Below, can add INPUT extensions as eg *.avi (SPACE separated, Batch Processes all INPUT type files in INDIR) FOR %%A IN (*.mpg *.mpeg *.mkv *.mp4) DO ( %FFMPEG% -i "%INDIR%\%%A" -vcodec %VCODEC% -preset %PRESET% -crf %CRF% -acodec aac -b:a %ABITRATE% "%OUTDIR%\%%~nxA.%CONTAINER%" ) Pause
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 8th February 2021 at 23:04. |
megui |
