#1 | Link |
StaxRip Audio Desync
Hello! I've been having an issue with StaxRip.
I have been ripping my DVDs recently with MakeMKV, and sending them to StaxRip for cleaning the video up. This has been working well for the most part, but for some reason I am having trouble with a DVD set in particular. I bought a SpongeBob SquarePants (Season 1) DVD set, and for some reason when I play/encode it in StaxRip it ends up desyncing the audio, but it doesn't do it on my other DVDs (so far). The only thing I can think of currently is that the source seems to be interlaced. Also, I made sure to disable all filters except for the source filter (just so there are no false results). Heres the log file: title_t00_new_staxrip.txt |
#2 | Link |
Also, here is the MediaInfo log for one of the episodes I am testing.Mediainfo.txt
#3 | Link | ||||
![]() Join Date: Feb 2005
Moved from AviSynth Usage subforum.
The AviSynth part seems work fine, maybe the problem is how use AviSynth StaxRip. The source title_t00.mkv: Quote:
[EDIT]For instance, if your video of 5197 frames have a intro of 148 frames than must be played at 29.97 fps (and the rest at 23.976) the average fps is 24.114 The first 148 fr. at 29.97 have a duration of 4.95 sec., but played at 24.114 the duration is 6.15 sec. You have an async of 1.2 seconds with the audio.[EDIT] I recommend add to the script: Quote:
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 17th November 2020 at 12:26. Reason: Add info |
#4 | Link | |
staxrip |
