Old 6th July 2013, 00:07   #17581  |  Link
houzer
BD-RB freezes
When backing up 'A Good Day To Die Hard' BD-RB freezes near the end of the second file(00801.m2ts) involved in the rebuild. (Movie Only) The files that were copied to hard disk from Bluray play fine and all the way through with out any hiccups. If I play the file in question in Power DVD It begins to play fine until it gets to the 31 second mark, then it jumps to the end. I noticed that PDVD shows the file as 40 seconds. If I play it with the preview option in BD-RB it shows it as 31 seconds and plays through to the end. When processing the files BD-RB handles the first file OK and then begins working through the second file but freezes just near the end. I can't copy the log because BD-RB is locked up. I've re-copied the file several times and it remains the same. Any ideas how to get around this?
houzer is offline   Reply With Quote
Old 6th July 2013, 00:33   #17582  |  Link
gonca
@houzer
Do you get any error messages such as X264.exe has stopped worling?
Old 6th July 2013, 02:00   #17583  |  Link
houzer
@gonca
No, nothing. Just stops. I let it sit for a fair amount of time and it stays the same. Clicking anywhere on the program's screen just causes it to whiteout and adds (Not Responding) to the title bar.
Old 6th July 2013, 02:28   #17584  |  Link
gonca
@houzer
Sounds like something is using up your resources in the background. Use task manager to see what is using up your system.
It is also possible it is your antivirus interfering with BD_RB. I did that movie with no problems.
Old 6th July 2013, 03:49   #17585  |  Link
Originally Posted by RoyGBiv-inRI View Post
I had this problem. Everything was working fine until I installed a program that added some codecs of its own (which I was afraid it might even though in the installation step I told it not to add any additional codecs). Removing that program, and then removing and re installing FFDSHOW solved the problem.
SMK
Yep. Good advice. Adding CODEC packs just creates a mess. Not just for BD-RB, but pretty much everything. They intercept, interfere, redirect and all kinds of nasty stuff -- and most of the time the installer doesn't even have the common courtesy to tell you it is doing all this.
FFDSHOW has about every CODEC needed for almost any reason under the sun. No other CODEC pack is needed.
Old 6th July 2013, 03:51   #17586  |  Link
Sounds like a bad rip... that's a pretty new release. But I want that disc anyway, so I'll pick it up and do some testing.
Old 6th July 2013, 04:51   #17587  |  Link
Capsbackup
My full backup to BD-25 of A Good Day To Die Hard caused BD-RB to stop responding/crash on 01288m2ts, which is a 12.0 KB, MPEG-4 AVC, 1920 x 1080, 16:9, 23.976fps, NTSC Progressive file. (Per MediaInfo)
BD-RB could not get past this file!
Old 6th July 2013, 04:57   #17588  |  Link
A 12.0 KB 1080p file? That's sounds fishy from the start...
Old 6th July 2013, 05:11   #17589  |  Link
Capsbackup
It was a surprise to me too!
My first problem in quite some time.
A late night tonight for you!
Old 6th July 2013, 15:39   #17590  |  Link
ScorpionStingz
I think, this could be a bug.
[07/06/13] BD Rebuilder v0.44.14 (beta)
[09:53:05] Source: THE_GOONIES_00030
- Input BD size: 19.05 GB
- Approximate total content: [01:53:55.328]
- Windows Version: 6.1 [7601]
- Mode: iPod MP4, 640x480/360, 128Kbs AAC
[09:53:05] PHASE ONE, Encoding
- [09:53:05] Processing: VID_00112 (1 of 1)
- [09:53:05] Extracting A/V streams [VID_00112]
- [10:27:27] Reencoding video [VID_00112]
- Rate/Length: 23.976fps, 163,884 frames
- [10:27:27] Reencoding: VID_00112, Pass 1 of 1
- Encode failed. Aborting.
- BD-Rebuilder v0.44.14 (beta)
- FFDSHOW: 4422, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- WAVI: Ok
- TSMUXER: Ok
[10:27:33] - Failed video encode, aborted
Last edited by ScorpionStingz; 6th July 2013 at 15:52. Reason: SORRY, I FOUND OUT I DID NOT DECRYPT FIRST. PLEASE DISREGARD THIS ERROR POST.
ScorpionStingz is offline   Reply With Quote
Old 6th July 2013, 16:19   #17591  |  Link
houzer
I ripped that file several times and the result is always the same. Is there a setting in BD-RB to force it through an error/"bad spot" like this and move on to the next file in the queue?
Old 6th July 2013, 17:10   #17592  |  Link
Racer
Is it actually possible to use QuickSync instead of DGDecNV for frameserving. I think my GT520 is limiting very soon if I replace my CPU by a i7 4770; I think QuickSync is faster than a VP5.
There is already a ffdshow version supporting QuickSync, can this one also be used for BD Rebuilder. Thanks!
Racer is offline   Reply With Quote
Old 6th July 2013, 17:24   #17593  |  Link
What I'm saying is the sometimes when a new protection mechanism is released, you have to wait a bit for the ripping software to compensate. So ripping it over-and-over won't do a thing until that happens. I don't know yet, though, that it even IS a ripping issue.
I picked that disc up today -- and will run it to see what I find. But if it is a new protection, I'd have to leave it to the AnyDVD folks to address it.
Old 6th July 2013, 17:27   #17594  |  Link
You probably can use it... but since I haven't tested it I can't accept bug reports if it is used.
I'll see if I can find it and test it myself also.
Old 6th July 2013, 17:43   #17595  |  Link
dfsooner
Mr
I have had problems with that title too. In fact, I have ripped it from two different discs with similar results. My problem has not been with BDRB - it finishes ok. However, even when playing the ripped version, it stalls after the initial MGM logo and you have to select skip to next chapter to get it to continue.
I think there is either an authoring problem or a problem with AnyDVDHD.
dfsooner is offline   Reply With Quote
Old 6th July 2013, 18:49   #17596  |  Link
setarip_old
setarip_old's Avatar
@jdobbs, @Capsbackup
Just a note to let you know that on 6/09, I used v.44.09 to perform a full backup to BD-25 of "A Good Day To Die Hard". The resultant disc was processed properly by BD-RB, INCLUDING 01288m2ts, which is a 12.0 KB (and remained as part of the fial backup)...
Old 6th July 2013, 19:22   #17597  |  Link
I just went through my notes... and I see nothing that could affect that. Almost everything in the 0.44.13 release is applicable only to ALTERNATE output and importing.
I'll be running it later today.
[Edit] I just opened the disc for input for a full backup. That file (01288.m2ts) isn't even on the list of files to be processed. It is just copied intact from source to destination. So the only way it could have any impact at is if someone is playing with the hidden settings and has set the minimum M2TS size to something ridiculously small.
I'd recommend that anyone having an issue first try renaming their INI file and reopening BD-RB so it can do the backup with it defaults.
[Edit] Ughhh.. 99 streams to encode. This is taking forever...
Old 6th July 2013, 21:34   #17598  |  Link
AmigaFuture
AmigaFuture's Avatar
....PLEASE DISREGARD THIS ERROR POST.
If you edit the message...a delete option will be there. If you like.
Old 7th July 2013, 01:54   #17599  |  Link
Capsbackup
I did have "MIN_M2TS_SIZE=0", for blanking purposes of fbi warnings, etc... Not sure how else to get them to be available to blank.
(I guess I could just try and go back to multiAVCHD for blanking the warnings after BD-RB completes)
Old 7th July 2013, 02:56   #17600  |  Link
I just finished a Full Backup of "A Good Day to Die Hard" with no issues using BD-RB with default settings.
I'll set MIN_M2TS_SIZE=0 and look at what is happening. But I would highly recommend that you not use it for standard backups. There's just nothing to be accomplished by deciding to reencode 16KB files other than making things harder. This disc has almost no startups to blank.
[Edit] 337 files to process??? Double uggh... I'll have to run this one overnight
