14th September 2010, 11:09 | #1541 | Link |
AVStoDVD Dev
Ok, thanks again for the report.
Still cannot understand why no subs selection is popping up with latest Alpha. About 23.976->25 speedup, there is no way to do it at runtime with SubtitleCreator, because the option is not avaliable in command line. BTW there is in SubtitleCreator GUI, so you can change framerate of your srt offline and then add the mod srt to AVStoDVD. Or try with PAL speedup off. DGPulldown usually does its jobs quite well. Bye |
14th September 2010, 15:19 | #1542 | Link | |
One thing I thought of concerning automatically detecting audio tracks when adding a plain .m2v file:
Could the dialog to choose between multiple audio streams allow priority changing of the tracks? In the cases I was dealing with the other day, there are three files, Quote:
Is there a way to add a couple of priority buttons to the dialog to move the tracks up or down? That way both could be added at once - in the user's desired order - without having to choose one that might not be automatically selected and then have to use the Add Audio Track function later. |
14th September 2010, 16:56 | #1543 | Link | |
AVStoDVD Dev
What about 2 new options in 'Title'/'Audio Track' -> 'Move up' or 'Move down' to change order after tracks selection? Bye |
14th September 2010, 19:34 | #1545 | Link |
In the newest alpha, my last two conversions
HCenc 0.24 hangs and wavi hangs both when finishing. The same video in 2.3.1, which has hcenc 0.24 also hangs after encoding is finished. All the conversions are fine during playback. |
15th September 2010, 01:11 | #1546 | Link | |
For that matter, having 'Move Up' and 'Move Down' as regular button options on the main window to rearrange Titles after loading would be awesome. Right-clicking - like what's currently possible - would definitely get rather tiring after a while, and not everybody uses keyboard shortcuts or at least not prolifically. Something as vital as track ordering needs buttons, IMO. I didn't even realize there were keyboard shortcuts until a few minutes ago (or an option for it in the right-click menu, but I blame that on not being as observant as I should, or just plain forgetting it was there). Although, for the main window, maybe a total of 5 options would be better - Move Up, Move Down, Move to Top, Move to Bottom, and Move to # (to move the Title to any arbitrary position in the list; for those cases where the Top/Bottom options throw it way too far, and it would be uncomfortable to keep having to click Up/Down to get it into position). I know I'd definitely get use out of that, I pretty regularly author discs with 30 or 40 titles to them - and for one showcase disc, I actually had to deal with 70. That one was actually the first real disc I used AVStoDVD for. I guess the only issue with additional buttons for all of that would be where to fit them in on the main window, in such a way that it's still able to fit the screen (I'm making the basic assumption that the targeted screen size is 1024x768 or similar vertical resolution). Perhaps a single new button to bring up a dialog meant strictly for track ordering, which then has all those Move options available, would be a more suitable choice. Since this is turning into a general suggestion post, there were a few other non-related ones that I'd thought of:
15th September 2010, 06:22 | #1547 | Link | |||
new encode
Encode of video and (predemuxed ) audio went really good.
but no subpicture in vob after encode??? As previous mentioned, don't use PAL speedup was not god. the vid becomes so to say like, the fps is missing 1 frame/sec, stuttering and has always been so for me with this app..therefore i always use pal speed up, gives super result. even better flow then the original... So any suggestions how to is appreciated... Quote:
Mediainfo on vob1 Quote:
but no subpicture in vob after encode??? As previous mentioned don't use PAL speedup was not god. the vid becomes so to say like the fps is missing 1 frame/sec, stuttering and has always been so for me with this app..therefore i always use pal speed up, gives super resolute. even better flow the original... Iron.Man.2.2010.1080p.BluRay.x264.DTS-WiKi.sst Quote:
15th September 2010, 12:59 | #1548 | Link | |||||||
AVStoDVD Dev
It is already in the ToDo list
Take note that rescaling of 405 to 480/576 is only temporary, because final visualized height will be again 405 pixels. Quote:
Thanks for all the improvement suggestions. Very appreciated. Quote:
Bye Last edited by MrC; 15th September 2010 at 13:05. |
15th September 2010, 13:45 | #1549 | Link |
About sonic scene
yes it was a Iron.Man.2.2010.1080p.BluRay.x264.DTS-WiKi.sst and it was choosen from within add subtilestab..( original .srt was 0,121mb and sst is 0,107MB and u have an part of file in post above)
But never mind this.. i dl a app called SubMagic, witch is written in C++ using Microsoft Visual Studio 2008 and this one did the magic on open up .srt and is super easy to use ( for saving back to srt) now i have to do a final encoding after re-edit the srt and saving it to 25fps witch it did like a clock.... Because i have a feeling what the global settings for subs in avstodvd is not working properly i have reduce font to 6pt and arial to see if the output is changed in to a smaller text size on encode... Last edited by harnarn; 15th September 2010 at 13:55. |
15th September 2010, 16:28 | #1551 | Link | |
AVStoDVD Dev
Bye |
16th September 2010, 03:42 | #1552 | Link | ||
Ah, I see now. Took a couple tries to figure out how to use it properly, though.
*depending on the TV/DVD player, of course. Like I said I wasn't sure if any perceived blurriness was a result of whatever goes into generating the menu or the text settings I was using. The text items seemed to appear crisp (albeit a tad thin-lined) on my little 13" CRT set, but on the HDTV in our living room I remember it looking rather blurred (and I do admit this could well be from what the DVD player is doing - I can't remember if I have it set to upscale to 1080p or not). Quote:
What I'm describing is something like this: http://www.kirupa.com/motiongraphics/align.htm |
16th September 2010, 14:43 | #1553 | Link | |
I usually install codecs as needed, when reinstalling my os on one of my computers, I thought I would just install CCCP. Before installing individual codecs this was the pack I used to use, which was a few years ago. I have never had a process hang on me and I use avstodvd on a daily basis. I didnt figure it out until after my initial post. I just removed CCCP and went back to individual codecs and everything is back perfect. I am not sure what the deal was all my settings are the same in ffdshow compared to the control panel ffdshow in CCCP. Keep up the great work ! |
16th September 2010, 19:08 | #1554 | Link |
AVStoDVD Dev
@qyot27
your suggestion to implement a "Photoshop like" aligning feat is surely challenging. I will think about that, but, please, consider that I'm not a programmer (better, I'm not a programmers team), AVStoDVD is just an hobby... so it could take looong time. @larrylumbo thanks for the report. Since AVStoDVD relies a lot on properly configured directshow decoding chains, I always suggest to get rid of codecs pack and install *only* ffdshow stable releases. Bye |
16th September 2010, 19:56 | #1555 | Link |
Subs
I have done several encodes now with your app but 1 thing still eludes me.Sub global settings
In your program folders under subtitlecreator is a couple of .xml sheets witch totally overrules the global settings . After changing these values i can alter the font size, font but not get ride of outline so this scratchy looking subs after encode are nice and clean i like always to have Arial normal caption as result. if you take a look at subcreator gui u can ad a transparent option to outline setting so the outline tearing of subs goes away . Can you make an xml sheet for this so i can use it ?? cheers Last edited by harnarn; 16th September 2010 at 19:59. |
17th September 2010, 10:51 | #1556 | Link |
AVStoDVD Dev
@harnarn
AVStoDVD (re)creates the \SubtitleCreator\Data\Profiles.xml at runtime (for safety), so no way to edit it. Best option would be to have the possibility to customize subs format in the GUI: already in the ToDo list. Current workaround: open your srt file with SubtitleCreator, edit it as you like, save it as sup file. Then load the sup file into AVStoDVD. Let me know Bye |
17th September 2010, 13:05 | #1557 | Link | |
but editing the .xml is possible u must edit both in subcreatorfolder but the only thing i don't knew is parameterset for outline-transparency=true .. cheers |
20th September 2010, 08:40 | #1558 | Link | ||
Greetings fom Germany, same Problem here. After the HCenc 24 is finished (100%) a windows message popup "the mpeg2 encoder wont work anymore" After i close this message the work goes on. The result is a dvd that works perfect, no problems. I think there is only a problem at closing the mpeg2 encoder... Avisynth 2.58 Haalisplitter from 14.08.2010 ffdshow from 19.09.2010 Avs2dvd 2.3.2 Alpha from 10.09.2010 Windows 7 64Bit Any idea? EDIT: Ok,found a solution. it was a problem with HCenc 0.24... Hank did a 0.25beta release that fixes this problem. U can get it here: http://www.videohelp.com/tools/HC Quote:
Ill test it! Last edited by AirZonk!; 20th September 2010 at 08:55. |
