22nd September 2019, 18:23 | #922 | Link |
I just found out that in StaxRip there is
Apps->Media Info->Ingest HDR. When I use it, I see these added in MediaInfo HDR format : SMPTE ST 2086, HDR10 compatible Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0100 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 1000 Maximum Frame-Average Light Level : 300 Is this enough and correct? It will always add the same value? |
22nd September 2019, 18:28 | #923 | Link |
QfG Group Germany
It's still for personality usage and in beta status. Too many bugs, for an official release. Also it works only with a graphics card from Nvidea, GeForce GTX 1050 or higher.
HDR format : SMPTE ST 2086, HDR10 compatible Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0100 cd/m2, max: 1000 cd/m2 Maximum Content Light Level : 1000 Maximum Frame-Average Light Level : 300 Code:
--hdr --output-depth 10 --hdr-opt --max-cll "1000,300" --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,100)" Maximum Content Light Level : 1000 Maximum Frame-Average Light Level : 300 = --max-cll "1000,300" Mastering display color primaries : Display P3 = --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450) Mastering display luminance : min: 0.0100 cd/m2, max: 1000 cd/m2 = L(10000000,100) Examples: Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 = L(10000000,1) Mastering display luminance : min: 0.0010 cd/m2, max: 1000 cd/m2 = L(10000000,10)
23rd September 2019, 05:46 | #924 | Link | |
Because generally speaking, VC-1 HW decoding is working for all his transcoders (Intel, AMD, nVidia) He needs the specific file that doesn't work with QSVEnc HW decoder. Cheers.
23rd September 2019, 07:42 | #925 | Link | ||
I did some tests at the weekend with ffmpeg and the options Intel and dxva2. My results were similar to yours, whether I used mine, wolfberry's or the official build. Only dxva2 in conjunction with nvidia works with a decent load on the GPU. I found a statement that dxva2 native is used in ffmpeg. This is peculiar. Quote:
23rd September 2019, 07:56 | #926 | Link | ||
Hello,
sorry for the late reply. I was a little busy. Quote:
indeed, it seems to happen to dts sources I will try to copy eac3to from the old version to the new one. Here is the eac3to part from the Logfile: Code:
--------------- Error Audio encoding 1 using eac3to 3.34 --------------- Audio encoding 1 using eac3to 3.34 failed with exit code: -1073741515 (0xC0000135) The exit code might be a system error code: The program can't start because hs is missing from your computer. Try reinstalling the program to fix this problem. ------------------ Audio encoding 1 using eac3to 3.34 ------------------ C:\StaxRip-x64-2.0.4.0-stable\Apps\Audio\eac3to\eac3to.exe "N:\ShareTest\Source\test_temp\test ID1 German.dtshd" "N:\ShareTest\Source\test_temp\test ID1 German_a1.m4a" -quality=0.8 -progressnumbers ------------------ Audio encoding 1 using eac3to 3.34 ------------------ C:\StaxRip-x64-2.0.4.0-stable\Apps\Audio\eac3to\eac3to.exe "N:\ShareTest\Source\test_temp\test ID1 German.dtshd" "N:\ShareTest\Source\test_temp\test ID1 German_a1.m4a" -quality=0.8 -progressnumbers Start: 08:41:37 End: 08:41:37 Duration: 00:00:00 |
23rd September 2019, 07:57 | #927 | Link | |
The results show that they are not using a direct, native mode of DXVA2 but some form of copy-back. I don't know if you have access to other documentation or ffmpeg developers in order to find out what's happening. That's good, I hope rigaya to see the update in ticket.
23rd September 2019, 09:12 | #928 | Link | |
with the eac3to version from 2.0.2.0 it is working. May be the eac3to version in 2.0.4.0 is not ok. Can you check this? |
23rd September 2019, 10:51 | #929 | Link |
@Z'Hadum
DTSMA and DTSX input works here on Win 10 1903, I don't have a DTSHR sample, please post MediaIinfo for the input file. According to Dependency Walker libdcadec.dll depends on VCRUNTIME140.DLL, that is Visual C++ 2017.
24th September 2019, 12:16 | #930 | Link | |
All Files where I tried to convert the Audio to AAC eac3to crashed with the new version. Most of the time I do this with DTS-HD Sources. As a workaround, I copied the old eac3to from Staxrip 2.0.2.0 to 2.0.4.0. This works for me. I think I am missing some kind of dll. If it is not VC++2017 is there any other that only eac3to uses? Or should I try to reinstall VC++2017? Code:
General Format : Matroska Format version : Version 2 File size : 11.2 GiB Duration : 1 h 18 min Overall bit rate mode : Variable Overall bit rate : 20.4 Mb/s Movie name : Test Writing application : MakeMKV v1.14.5 win(x64-release) Writing library : libmakemkv v1.14.5 (1.3.5/1.4.7) win(x64-release) Video ID : 1 ID in the original source medium : 4113 (0x1011) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 4 frames Format settings, GOP : M=3, N=18 Codec ID : V_MPEG4/ISO/AVC Duration : 1 h 18 min Bit rate mode : Variable Bit rate : 18.0 Mb/s Maximum bit rate : 28.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 24.000 FPS Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.362 Stream size : 9.85 GiB (88%) Language : English Default : No Forced : No Color range : Limited Color primaries : BT.709 Transfer characteristics : BT.709 Matrix coefficients : BT.709 Original source medium : Blu-ray Audio ID : 2 ID in the original source medium : 4352 (0x1100) Format : DTS XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Codec ID : A_DTS Duration : 1 h 18 min Bit rate mode : Variable Bit rate : 2 407 kb/s Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 16 bits Compression mode : Lossless Stream size : 1.32 GiB (12%) Title : Surround 5.1 Language : German Default : Yes Forced : No Original source medium : Blu-ray Text #1 ID : 3 ID in the original source medium : 4608 (0x1200) Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 10 s 813 ms Bit rate : 50.4 kb/s Count of elements : 4 Stream size : 66.5 KiB (0%) Language : German Default : No Forced : No Original source medium : Blu-ray Text #2 ID : 5 ID in the original source medium : 4609 (0x1201) Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 1 h 13 min Bit rate : 38.8 kb/s Count of elements : 1545 Stream size : 20.4 MiB (0%) Language : German Default : No Forced : No Original source medium : Blu-ray Menu 00:00:00.000 : en:Chapter 01 00:05:26.708 : en:Chapter 02 00:11:05.291 : en:Chapter 03 00:15:13.083 : en:Chapter 04 00:19:27.916 : en:Chapter 05 00:25:51.875 : en:Chapter 06 00:29:00.958 : en:Chapter 07 00:36:10.291 : en:Chapter 08 00:45:43.875 : en:Chapter 09 00:51:26.250 : en:Chapter 10 00:59:47.166 : en:Chapter 11 01:08:55.375 : en:Chapter 12 01:13:27.083 : en:Chapter 13 |
24th September 2019, 14:29 | #931 | Link |
@Z'Hadum
Thanks for the log. At least you should keep in mind there could be something broken on your system, or there is something wrong with the library. I have tried to google it but found nothing specific apart from that the problem occurred most often about 5 years ago, so I assume it's Win 7 specific. It would be helpful if other Win 7 users confirm that it's not a general issue. If more people report it I'll just revert the library, it was updated due to a user requests, I think I had compiled it myself.
25th September 2019, 07:26 | #933 | Link | |
I also think, that I'm missing some kind of dll. But the Question is which one |
26th September 2019, 02:11 | #937 | Link |
H.265/HEVC isn't supported by the graphics card. (I have a 1080 TI)
PC Specs: I7 77OOK | CORSAIR 32 GB | MSI GTX 1080TI 11GB GAMING X. Nvidia Drivers: 436.15 STANDARD - Game Ready. Version of the program: StaxRip-x64-**x64-2.0.4.4-beta NVEnc Version: 4.50_x64 I only have this problem when use a version of NVEnc above of 4.48 x64, with 4.48 everything works fine: Full Log: https://pastebin.com/0pip7jqi |
26th September 2019, 04:40 | #938 | Link | |
App Digger
Thanks for your advice. After more study, I've come to the conclusion that this "bug" arises from MediaInfo, not from MP4Box. Look at this mp4 file which was encoded in late June. MediaInfo 19.09 shows this 'Title' metadata on the video stream, which didn't appear in previous versions. OTOH, MediaInfoXP 2.35, another MediaInfo GUI based on MediaInfo 19.07, does not show this. Well, is this a "bug"? Or have they decided that displaying 'Title' metadata on the video stream is more appropiate than not? If the latter is the case, do I have to set the 'Title' metadata everytime I mux an mp4 file? I have no idea. Last edited by JKyle; 26th September 2019 at 04:52. |
26th September 2019, 14:17 | #939 | Link |
Thank you for the information. I looked at mediainfo's changelog but didn't find metadata information for the (video) title. The default for mp4 files in the next Staxrip build is that this title is tagged as "blank". This results in the title not being displayed. If you want to display the title you have to enter the titel in staxrip.
aac, hdr, hevc, nvenc, staxrip, x264, x265 |
