24th April 2020, 17:45 | #1721 | Link |
That mean, DGIndex is the one and olny alternate for mpg vob etc. is it not in package, but i must download it for staxrip. Staxrip has the app not include, but with a frsh install, it ask me every time for the place from DGindex.
24th April 2020, 19:36 | #1723 | Link |
@Mister XY
Sometimes I remove a tool because of different reasons, most recently dgindex and xvid, but it's relatively easy to still use these tools: StaxRip tries to find tools, often it can find the location of a tool. If it cannot be found staxrip asks for the location. An external custom path can be defined for all tools and this path is stored in the settings, keep your settings and staxrip will not ask a second time. There is an excellent tool called voidtools everything which staxrip (and mpv.net) integrates to find things, it's probably a must-have for every power user.
24th April 2020, 19:49 | #1724 | Link | |
Useful n00b
25th April 2020, 06:58 | #1725 | Link |
an already encoded HEVC video i try to re-encode using x265 always renders a green screen on the re-encoded version. i just re-encode to shrink the file, but i test it out in placebo preset with the same results using avisynth! changed to vapoursynth and the green screen disappear! any ideas? only happens with already HEVC encoded videos.
25th April 2020, 09:54 | #1726 | Link |
You can use pastebin to post the log file.
27th April 2020, 12:22 | #1729 | Link | |
The Apps dialog and the docs are searchable: https://staxrip.readthedocs.io/generated/tools.html You can of course use filters that are not included, more or less everything that is possible with avisynth or vapoursynth is supported by staxrip using customizations.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 27th April 2020 at 12:27. |
28th April 2020, 21:32 | #1732 | Link |
is possible to create an autocrop AVS filter and add it to the filters menu to create a template? i already know how to add filters to the menu, but can't find how to add the AutoCrop function. thanks in advance for your answers!
2nd May 2020, 04:26 | #1734 | Link |
I've tried several times to encode a season. I keep getting the error
"x264 [error]: 2nd pass has more frames than 1st pass (40556 vs 32444)" Here is the log https://pastebin.com/229NL5Sf I have tried manually setting the FPS as StaxRip was specifying the wrong FPS. However, that didn't seem to help. Any help would be appreciated! Last edited by jlw_4049; 2nd May 2020 at 06:23. |
2nd May 2020, 09:51 | #1736 | Link | |
have you tested 2-pass encoding without loading all plugins and scripts? During porting the informations, something goes wrong. Your source file has a frame rate of 29.97 fps, in your log file i saw Code:
---------------------- Source Script Information ---------------------- Width : 720 Height : 480 Frames : 32444 Time : 22:33.185 Framerate : 23.976023 (24000/1001) Format : YUV420P8 ---------------------- Target Script Information ---------------------- Width : 640 Height : 480 Frames : 40556 Time : 22:33.219 Framerate : 29.970029 (30000/1001) Format : YUV420P8 |
2nd May 2020, 17:18 | #1737 | Link | |
When I use the default full repair setting (QTGMC(preset="Very Slow", InputType=3, sourceMatch=3, sharpness=0.2, tr2=2, ediThreads=8) The issue is there with the above code^ If I just edit the code and input (QTGMC(preset="Very Slow") it works perfectly. So, one of the commands, I haven't done much testing, and I probably will just end up using stock settings, is causing the issue. -------------------------------------- Now on to the framerate. Staxrip in the log is wrong on the target framerate. The framerate of DVD I'm attempting to encode is 23.976 fps (24000/1001), or so mediainfo says. Obviously I'm new to DVD encoding, so learning everything, so this might be correct anyways. This is probably irrelevant since it was the QTGMC filter preset causing the issue. Firing up the full encode again with just 'Very Slow' set. EDIT: just using the default QTGMC command did not work. ------------------------------------------ UPDATE: The issue only occurs when I do a batch encode based off of a template and manually have the source set to MPEG2. If I leave the source as "Automatic" with all the rest of my settings the same, it works fully so far. It still uses MPEG2source, so I am not sure what the difference is. Last edited by jlw_4049; 2nd May 2020 at 22:19. |
3rd May 2020, 08:16 | #1740 | Link | |
aac, hdr, hevc, nvenc, staxrip, x264, x265 |
