25th June 2016, 11:46 | #2241 | Link |
I'm trying to fast-forward a video but i get this error.
"Input audio sample format to TimeStretch must be float" Audio input is PCM in24 (Apple ProRes video). I had no trouble before with AAC. Does it have something to do with the audio indexing? Can it be fixed? |
25th June 2016, 12:11 | #2242 | Link |
Please show us the exact command in your AviSynth script you want to use to "fast-forward".
You should know that a nummerical value of e.g. 3 is of type integer, but 3.0 is of type float, and if a function requires a float parameter, you may have to provide it with a decimal (if the parameter is a variable with an integer value, multiply it with 1.0). But well, who knows if the reason for this error message is at a completely different position ... |
25th June 2016, 12:19 | #2243 | Link | |
契約者
25th June 2016, 17:44 | #2244 | Link |
It's the decoding sample format being passed from FFMS2 to TimeStretch. libavcodec decodes AAC to float (read: outputs pcm_f32le), but it won't do anything to PCM that's already in an integer format.
Put ConvertAudioToFloat() between FFMS2 and TimeStretch. |
7th July 2016, 12:21 | #2247 | Link |
Probably "L-SMASH Works" (LSMASHSource.dll: LSMASHVideoSource for ISO Media containers like MP4/MOV/3GPP, LwLibavVideoSource in general).
7th July 2016, 13:24 | #2248 | Link |
brontosaurusrex
@LigH: thanks, but getting only some green stuff in vdub window (LSMASHVideoSource and LwLibavVideoSource).
I've tested prores and cineform. Ideas? (win 7) Last edited by smok3; 7th July 2016 at 13:27. |
7th July 2016, 13:44 | #2250 | Link |
Yes, you may have to specify the desired color subsampling and depth explicitly, such deepcolor formats might get decoded into wrongly interpreted pixels when you don't specify a pixel format. Please do some research on your own, I know it has been discussed before...
7th July 2016, 14:18 | #2252 | Link | |
It does both vfw decoding (ffmpeg select..) and ffmpeg decoding (ffmpeg all..)
VirtualDub2 |
7th July 2016, 14:41 | #2253 | Link |
brontosaurusrex
@shekh, Thanks, bookmarked, installed, tested. (Actually I was trying to review some of my old x264 encoding scripts, but after looking at that bat mess, mission aborted).
25th July 2016, 19:40 | #2254 | Link |
I'm Siri
is it possible to get the QP value of each frame for lossily compressed videos and tag that as some frame property (in vaporsynth)?
I want it cuz I want denoisers to have a self adaptive denoising strength on each individual frame |
25th July 2016, 22:34 | #2255 | Link |
Great thinking, feisty2; it reminds me on my failed attempt to convince Donald Graft to implement Deblock() into his DG*Decode plugins. I lacked of technical details to explain it convincingly enough.
I remember some AviSynth plugins do use auxiliary "hint" channels to share a few details (e.g. TFM with TIVTC, or MPEG2Source(info=3) with ColorMatrix). But I have no idea how useful that is compared with the VapourSynth design; and they seem to be rather per-clip than per-frame, at least in these examples. |
26th July 2016, 00:13 | #2256 | Link |
If they (frame properties) could accessed in advance, could be written to RT_Stats DBase (or Array) and accessed via Avisynth ScriptClip (or similar, and presumably VapourSynth), for use on frame by frame basis. Depends upon whether or not there is some tool to extract the data in the first place.
26th July 2016, 00:15 | #2257 | Link |
Professional Code Monkey
I will check to see if this information is still exposed in ffmpeg. I know they've done a lot of cleanups so it may or may not still be available.
17th August 2016, 02:03 | #2258 | Link |
@qyot27
Don't know if this is the appropriate thread for my question, but you are probably the one who can answer it... Using the current FFmpeg version 3.1.2 (rogerdpack build for WinXP) I get a crash immediately if the input is an AVS script. The culprit is autoloading C-Plugins from the AviSynth\plugin folder. For a long time I have autoladed C-Plugins like your ffms2 or Yadif by using an AVSI which loads the C-Plugin (your ffms2.avsi does this). This has always worked flawlessly until I tried to use FFmpeg v 3.1.2. The previous version by rogerdpack from July 2016 has no problems. My AviSynth version is the plain vanilla 2.60 which can hardly be considered outdated. What did the FFMpeg devs change to cause this problem? Do I have to use AviSynth+ now to get FFMpeg to work? Cheers manolito |
17th August 2016, 03:16 | #2259 | Link | |
Correspondingly, if I add the folder that ffms2.dll / FFMS2.avsi / ffmsindex.exe reside in to the PATH, the issue goes away. I'd actually had a nasty registry corruption issue on my WinXP machine not too long ago, so my plugins folder had disappeared from the PATH and I was hitting the problem. When I tried to use ffmsindex and it told me it couldn't see it, I pretty much realized what was going on. Added the plugins folder to the PATH, tried again, no problems with either 2.6 or Plus. Last edited by qyot27; 17th August 2016 at 03:18. |
17th August 2016, 15:21 | #2260 | Link |
Thanks qyot27 for the quick reply.
Unfortunately including the "AviSynth\plugins" folder in my path does not make a difference. FFMpeg still crashes (called by AVStoDVD) with a message that Yadif cannot be loaded. If I remove Yadif from the plugins folder, I get the same message about ffms2. I can live without Yadif, but ffms2 is essential for my workflows. And since the scripts are automatically created by AVStoDVD I do need ffms2 to be autoloaded. Thanks and cheers manolito |
