13th May 2020, 10:55 | #2501 | Link | |
13th May 2020, 11:32 | #2502 | Link | |
That's bad because only Microsoft apps can provide that. If I were you, I would try PotPlayer as a final move.
13th May 2020, 13:15 | #2503 | Link | |
LAV filters seems to already use an IMFTransform for other codecs. |
13th May 2020, 15:14 | #2504 | Link |
the driver is buggy.
it reports that it only supports macroblock mode while you have to support raw bitstream mode so a correctly coded DXVA2 implantation will not use it. the problem is raw bitstream mode works totally fine they just flag it wrong mpc-be internal decoder isn't checking or ignoring it and it works fine. and even if it works it still shows up as encoding. AMD doesn't care that's what you should take from this. i can only recommend to avoid AMD they don't deserve any support anymore. i talked directly with AMD about that the answer was "that doesn't sound important". |
13th May 2020, 19:03 | #2505 | Link | |
We can argue all you want but if you say AMD doesn't care I can also say that developers don't seem to care. I'm here to discuss it and find solutions though, not start a flame war. |
13th May 2020, 19:10 | #2506 | Link |
Could you test MPC-BE and PotPlayer and report here about your findings ?
13th May 2020, 19:13 | #2507 | Link |
Try if it works with this LAV build:
vp9_dxva_test |
13th May 2020, 19:30 | #2508 | Link | ||
I will test it now. Last edited by Lumiel; 13th May 2020 at 19:34. |
13th May 2020, 19:43 | #2509 | Link |
MPC-BE works fine, it's using 100% GPU, however it's very heavy for my PC. Almost everything else become unresponsive. This is probably because I'm testing a 60 FPS video while Navi supports 8k@24 fps. I will now test PotPlayer and edit the same post so I don't spam.
edit: PotPlayer works fine as well, a little less heavy than MPC-BE. Some stats from Potplayer. So at least I know there are some players that support my GPU thanks NikosD p.s the smoothest experience is 100% still with Movies & TV though, I can also see about 3% CPU usage along with 100% GPU usage. That's as far my knowledge goes on the issue Last edited by Lumiel; 13th May 2020 at 19:59. |
13th May 2020, 20:33 | #2510 | Link | |
nev was not willing to add this yet. and why does it work with other software like video app it doesn't use DXVA2. you can read more here: https://forum.doom9.org/showthread.p...36#post1899136 |
13th May 2020, 20:58 | #2511 | Link | |
13th May 2020, 20:59 | #2512 | Link | |
"DXVA VP9 specification states that "ConfigBitstreamRaw" should always be 1 for VP8/9" and their driver doesn't comply. Now, using your GPU at 100% can make your GUI - Windows - feel sluggish. I would like you to open Task Manager of Windows 10 and see the GPU video decoder usage during VP9 8K playback with both DS Players (PotPlayer and MPC-BE) and the MFT Player (Movies & TV) In pure DXVA2 native mode or D3D11 native mode, the GPU usage should be real low and the HW video decoder usage should be close to 100% while CPU should be low too. Can you test DXVA Checker in benchmark mode in pure hardware decoding mode renderless (not playback) using MPC-BE filters ? (you have to install them separately as DS filters) Also, I would like you to post some VP9 4K results regarding video performance (FPS, GPU usage) with both DS and MFT decoders.
13th May 2020, 21:29 | #2513 | Link | ||
MPC-BE: HW decoder 100% - GPU D3D Usage 19% - GPU memory controller 4% - GPU memory usage 1500MB - CPU 0% PotPlayer: HW decoder 100% - GPU D3D Usage 19% - GPU memory controller 5% - GPU memory usage 1600MB - CPU 0.8% Movies & TV: HW decoder 100% - GPU D3D Usage 13% - GPU memory controller 25% - GPU memory usage 1992 MB - CPU 1.2% Quote:
13th May 2020, 22:14 | #2514 | Link | |
Then you are pushing your HW decoder to its limit. But, Windows GUI has nothing to do with that and everything should be normal with such low GPU and CPU usage.
14th May 2020, 07:41 | #2516 | Link | |
windwos media foundation does this:
youtube UHD 60 HDR. VP9 profile2 103 122 137 9% CPU 100 % video encode engine. edit: 8k runs at about 40 FPS i didn't finish the run that would take a long time. about the same CPU usages more then 1 thread. the very high CPU usages is very odd: https://abload.de/img/veryhighcpuusageerkpg.png these test are done without loading the radeon control panel or what it'S name is now to avoid issues. Quote:
14th May 2020, 16:01 | #2518 | Link |
I do not advise you to hope so. They will not do anything themselves until you force them. AMD has some kind of problem with flags in the software. An example was the missing BT.2020 flag in their private API - AGS, which did not allow HDR content to be correctly played using madVR. I spent a lot of time to sort out the problem and describe it to them. It took even more time to explain this to them. And if not for the community (thanks to mclingo, aka stoolzo), AMD owners still watched HDR in the BT.709 color space. If you decide to write to them, be sure to let them know what official standards they violate.
R3 3200G / Vega8 / Samsung UE40NU7100 Win11Pro 21H2 / 4K RGB 59Hz / AMD last driver MPC-HC 1.9.17 / madVR 0.92.17 / FSW / SM / 8bit |
14th May 2020, 18:06 | #2519 | Link | |
A good additional place to submit bug reports is in the driver feedback threads on Reddit. A few guys from AMD are active there. |
