20th October 2018, 20:42 | #3201 | Link | |
----------- You fix one thing any dozen more things break. Vapoursynth path is completely broken now. I really wish MS would stop messing with my python files and stop install python 3.6. |
20th October 2018, 20:45 | #3202 | Link | |
Already reported this to MediaInfo and it seems they have no interest in fixing it right now. There been zero replies since my last comment about the issue. |
20th October 2018, 21:59 | #3203 | Link |
QfG Group Germany
Ok Revan654 no problem. Any chance to use the "old" MediaInfo from 1.8 in 1.9 ? In last time, MediaInfo sucks. If i use it for MKV files, DTS-MA is now DTS-XXL
20th October 2018, 23:40 | #3204 | Link | |
Maybe one day, I'll switch over the code to something else like ffprobe. |
21st October 2018, 19:45 | #3208 | Link | |
Any filter that's included and not part of the context menu can be added manually by simply just type out the function in the text menu. If you want TFM you would just type TFM() Add any args inside the () if needed. All the list filter functions are listed in the App Menu. |
21st October 2018, 20:07 | #3209 | Link | |
You are likely going to run into bottle necking issues as well for such a size. You would increase the cache size Code: - max_cache_size Example: core.max_cache_size = 32768 It's better just to leave the cache_size alone and allow the OS & python code to do it's job naturally. the other options I would have to look, I'm not sure off the top of my head. I know there parallel process and number of cores you can set py script to. I would have to scan non VS python modules to see if there is a way to sex the memory. If one exists, I have no idea if VS will the code and allow the full usage of it. FYI, Make sure that server is Windows based, StaxRip will not run under Linux even with programs like Mono or Wine. |
23rd October 2018, 06:18 | #3210 | Link |
Freeze at "Muxing video to Matroska"
I am trying to convert bluray iso files to MKV using the HEVC encoder to reduce size. I tried to get help in the EAC3TO forum, but didn't get help with this issue and was directed to MakeMKV which is not exactly what I am searching for.
I am using EAC3TO 3.34 with a GUI and using Staxrip 1.9 with version 3.34. I am using a bluray ISO file which I have ripped and want to encode to a smaller MKV file. If I use either software, I am able to choose the playlist I want to perform work on and then I select only the video portion, no audio and no subtitle (have tried both ways) and the process stops after a few seconds. There is no log file generated. The size or playlist or bluray file do not matter. This same process works on one 2015 Macbook Pro and one 2010 custom desktop, but not on newer 2017 Macbook Pro and 2017 iMac. All these computers are running Windows 10 natively via bootcamp. If I change the output from MKV to h264, the process completes, but not vice versa. What are the advantages of going to h264 on the way to h265? Copy of status window is below and last line is the last status print out at 1% with no further progress even after hours. Can anyone advise how to extract a bluray playlist to MKV given this issue? I have tried every version of EAC3TO over the last 1 year with the same results. |
23rd October 2018, 12:21 | #3212 | Link | |
23rd October 2018, 16:32 | #3213 | Link | |
Starfish
Hi Revan,
me again. I am trying to to use StaxRip 1.9.0.0 with Vapoursynth. But StaxRip crashes everytime no matter which source filter I choose. Quote:
I am sure it must be my setup otherwise people would have complaint, but I cannot pin down the problem or a find a starting point. |
23rd October 2018, 17:40 | #3214 | Link |
@FreaQ:
Just tested different video samples (avi, mp4, mkv, etc.) on different source filters with Vapoursynth r44. Python 3.65 64bit and exchanged mediainfo, as mentioned a few pages back in this thread. Everythings doing fine..... |
23rd October 2018, 20:27 | #3215 | Link | |
QfG Group Germany
You have a 1080p BluRay ISO and u will encode with x265 to HEVC and MakeMKV muxed not correctly your BluRay into a MKV Container? Are u sure, that you have disabled/killed all Copy Protections, if u copied the BD to HDD Iso? I use DVDFab for this. Or use MakeMKV directly with the BD Disk, thats the best, when u own the disk. For demuxing a MKV File, i use StaxRip, too. |
23rd October 2018, 23:32 | #3217 | Link | |
24th October 2018, 03:02 | #3218 | Link | |
24th October 2018, 07:11 | #3219 | Link | ||
Starfish
I did not manage to get it working in my original StaxRip config. But a clean portable instance of StaxRip did the trick. |
