9th May 2016, 11:15 | #1241 | Link | |
11th May 2016, 18:59 | #1243 | Link |
Im having an isssue when encoding some extras from a blue ray. 2 of the 24 extras are having issues. for the first couple of minutes everything its ok, then halfway audio is faster than the video. How can that be fixed? thanks
14th May 2016, 21:19 | #1246 | Link |
Hey Stax,
Could you please tell when the next program update will be available? There was a great development as to x265 codec with the introduction of --no-recursion-skip option. It would be great if you include this switch to the settings of x265. Thanks! |
14th May 2016, 22:22 | #1250 | Link |
Hi everyone
Just wondered if you can help me with this one, 1st time I've actually had this problem. I'm trying to convert a dvd but I keep seeing this It won't even let me use justmux when I do it throws this error at me Code:
Error Demux audio using ffmpeg 2016-03-10 x64 Demux audio using ffmpeg 2016-03-10 x64 failed with exit code: 1 (0x1) The exit code might be a system error code: STATUS_WAIT_1 The exit code might be a system error code: Incorrect function. Input #0, mpeg, from 'C:\xxxxxxxxxx\New folder.mpeg': Duration: 01:11:10.18, start: 0.280633, bitrate: 5944 kb/s Stream #0:0[0x1bf]: Data: dvd_nav_packet Stream #0:1[0x1e0]: Video: mpeg2video (Main), yuv420p(tv, smpte170m), 720x480 [SAR 8:9 DAR 4:3], max. 7000 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc Stream #0:2[0x80]: Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s Stream #0:3[0x81]: Audio: ac3, 48000 Hz, stereo, fltp, 224 kb/s Stream #0:4[0x82]: Audio: ac3, 48000 Hz, stereo, fltp, 224 kb/s Data stream encoding not supported yet (only streamcopy) StaxRip.ErrorAbortException: Demux audio using ffmpeg 2016-03-10 x64 failed with exit code: 1 (0x1) The exit code might be a system error code: STATUS_WAIT_1 The exit code might be a system error code: Incorrect function. Input #0, mpeg, from 'C:\xxxxxxxxx\New folder.mpeg': Duration: 01:11:10.18, start: 0.280633, bitrate: 5944 kb/s Stream #0:0[0x1bf]: Data: dvd_nav_packet Stream #0:1[0x1e0]: Video: mpeg2video (Main), yuv420p(tv, smpte170m), 720x480 [SAR 8:9 DAR 4:3], max. 7000 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc Stream #0:2[0x80]: Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s Stream #0:3[0x81]: Audio: ac3, 48000 Hz, stereo, fltp, 224 kb/s Stream #0:4[0x82]: Audio: ac3, 48000 Hz, stereo, fltp, 224 kb/s Data stream encoding not supported yet (only streamcopy) at StaxRip.Proc.Start() in D:\Projekte\GitHub\staxrip\General\Proc.vb:line 234 at StaxRip.Audio.Demuxffmpeg(String sourcefile, AudioStream stream, AudioProfile ap) in D:\Projekte\GitHub\staxrip\General\Audio.vb:line 100 at StaxRip.Audio.Process(AudioProfile ap) in D:\Projekte\GitHub\staxrip\General\Audio.vb:line 40 at StaxRip.MainForm.Encode() in D:\Projekte\GitHub\staxrip\Forms\MainForm.vb:line 2187 at StaxRip.MainForm.RunJobRecursive() in D:\Projekte\GitHub\staxrip\Forms\MainForm.vb:line 3463 edit...PS now I have just gone back to version StaxRip_1.2_Technical_Preview and it's letting me convert no problem at all!!! Last edited by lordalibaski; 14th May 2016 at 22:30. |
15th May 2016, 06:47 | #1251 | Link |
Request
Hi Stax, I want to know if its possible to display/show what current video pass is encoding next to the ETA/fps. If that's not possible its not a big deal since I can check the current encoding commands that shows what pass is encoding, just that it takes some time to find it.
15th May 2016, 19:08 | #1254 | Link | |
Anyway, it works fine on all my pcs, no reason it shoudn't work on yours, so please recheck if you set "no audio" to your second audio stream |
15th May 2016, 23:35 | #1255 | Link |
Yes it does m8 but when I changed it to no audio for the bottom one that's when it threw the error up.
This option usually works fine on my PC too but this option on this DVD didn't work. Like I said I got it working straight away in the older version. Something isn't right out of 100's of DVD's I have converted I haven't had these problems at all. Got another DVD here which I converted yesterday I used these settings below but the final output put the audio bitrate @ 448 Code:
General Unique ID : 201953902291118512059016503738686752010 (0x97EEE822C9E1B5C18FDE97205BEFC50A) Complete name : D:\05 - CONVERTED DVD\Rap Mania Side A.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 1.87 GiB Duration : 1h 44mn Overall bit rate : 2 571 Kbps Encoded date : UTC 2016-05-14 16:56:01 Writing application : mkvmerge v7.5.0 ('Glass Culture') 32bit built on Jan 4 2015 16:37:25 Writing library : libebml v1.3.1 + libmatroska v1.4.2 DURATION : 01:44:06.112000000 NUMBER_OF_FRAMES : 195191 NUMBER_OF_BYTES : 349782272 _STATISTICS_WRITING_APP : mkvmerge v7.5.0 ('Glass Culture') 32bit built on Jan 4 2015 16:37:25 _STATISTICS_WRITING_DATE_UTC : 2016-05-14 16:56:01 _STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L3@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 1h 44mn Bit rate : 2 072 Kbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 29.970 fps Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.200 Stream size : 1.51 GiB (81%) Writing library : x265 1.4+209-6ba7be7b1697:[Windows][GCC 4.6.3][64 bit] 16bpp Encoding settings : wpp / ctu=64 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / no-fast-cbf / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / interlace=0 / keyint=250 / min-keyint=25 / scenecut=40 / rc-lookahead=20 / bframes=4 / bframe-bias=0 / b-adapt=2 / ref=3 / weightp / no-weightb / aq-mode=1 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=3 / psy-rd=0.00 / psy-rdoq=0.00 / signhide / lft / sao / no-sao-non-deblock / b-pyramid / cutree / rc=crf / crf=22.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / ipratio=1.40 / pbratio=1.30 Default : Yes Forced : No Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : A_AC3 Duration : 1h 44mn Bit rate mode : Constant Bit rate : 448 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 334 MiB (17%) Language : English Default : Yes Forced : No |
17th May 2016, 17:55 | #1256 | Link |
I've just split 2 segments out of the dvd's I'm having problems with if anyone want's ago at trying to get the audio bitrate down to 192 because no matter what I try I can't get it below 448.
Rap Mania Side A Test 1 https://www.sendspace.com/file/8pk3gg Beef-03 Test 2 https://www.sendspace.com/file/zlv1mm It will probably be something so simple that I've missed. Thanks for any help. |
