Old 15th February 2018, 16:39   #22561  |  Link
LAV Filters 0.71
General
- LAV Filters now requires Windows Vista or newer, Windows XP is no longer supported
LAV Splitter
- NEW: Preliminary support for UHD Blu-ray parsing
LAV Video
- NEW: D3D11 hardware accelerated decoding (native mode with madVR, Copy-Back otherwise)
- Fixed: HDR metadata was not properly communicated to madVR in DXVA2-Native mode
- Fixed: Anamorphic WMV9/VC-1 videos were not being played back with the correct aspect ratio in all cases
- Fixed: Changing certain settings while playback was paused could result in a deadlock
- Fixed: Playing severly corrupted HEVC streams with hardware decoding could result in playback failing entirely, instead of skipping over the corruption
LAV Audio
- NEW: Basic support for AAC 960 streams (common in DVB radio streams)
Download: Installer (both x86/x64) -- Zips: 32-bit & 64-bit
Its been long overdue to release this, so I can start working on some new things without breaking the release!
D3D11 Decoding
The main motivation behind offering D3D11 decoding is the ability to be able to process the resulting image on the GPU without any loss - something that was not always possible on DXVA2.
To be able to actually leverage this, you'll need a renderer which also supports D3D11 input from a decoder - currently this is only madVR. This allows full performance on-GPU decoding and processing without any quality loss.
D3D11 also offers a Copy-Back mode, however it should probably be quite similar in performance then DXVA2.
Note that the way you select Native/Copy-Back for D3D11 is different than DXVA2. D3D11 will use Native-mode when its set to "Automatic" device choice, and the renderer supports Native mode. If you select a specific device, that forces Copy-Back mode (because for Native to work, the renderer basically selects the device).
There are still a few limitations on using D3D11-Native with madVR, most notably deinterlacing is not supported yet. This is a feature madVR will have to implement in the future.
Old 15th February 2018, 16:52   #22562  |  Link
Schwartz
Thanks for the update!
Native D3D11 caused a 'driver stopped responding' error for me. Using a R9 270X and the 18.2.2 drivers released 2 days ago. I assume this is a driver issue? I also didn't change any settings in madVR or disable deinterlacing.
D3D11 CB mode works fine and the load looks similar to DXVA2.
Schwartz is offline   Reply With Quote
Old 15th February 2018, 18:54   #22563  |  Link
manolito
manolito's Avatar
Can somebody please tell me which is the latest 0.70.2 nightly version which still supports Win XP?
Cheers
manolito
Old 15th February 2018, 19:09   #22564  |  Link
Just as "anchor":
Officially, the last stable release supporting XP was v0.70.2...
There was a link to Aleksoid1978's diff to 0.70.2.1 with experimental CUVID H.265 10-bit decoding.
And clsid published MPC-HC 1.7.13.1 incl. a patched LAV Filters 0.70.2.3.
From there, the thread kept derailing over and over.
Old 15th February 2018, 19:15   #22565  |  Link
lvqcl
I just searched for "WinXP" in this thread and the result is:
Originally Posted by VictorLS View Post
For people who still like WinXP - last working version of subj is LAVFilters-0.70.2-16 [...]
Next installer LAVFilters-0.70.2-29.exe says "This program does not support the version of Windows your computer is running."
Old 15th February 2018, 19:17   #22566  |  Link
Well, knowing the perfect search term matters...
Old 15th February 2018, 21:01   #22567  |  Link
manolito
manolito's Avatar
Thanks guys...
Old 15th February 2018, 21:19   #22568  |  Link
lvqcl
on the other hand...
Originally Posted by Prinz View Post
I have a problem since version: LAVFilters-0.70.2-10
DTS Bitstreaming results in very choppy playback, MadVR says suddenly clock derivation 30 - 50% and it's visibility dropping frames every second. Installing LAVFilters-0.70.2-8 or previous everything works fine
...0.70.2-16 can have some problems.
Old 16th February 2018, 10:10   #22569  |  Link
jaju123
Hi all,
So if I'm using LAV filters with MadVR, would it make more sense to use D3D11 or CUVID mode? I'm struggling to figure out the differences or find any documentation.
Thanks!
jaju123 is offline   Reply With Quote
Old 16th February 2018, 12:17   #22570  |  Link
Short answer D3D11, CUVID is basically dead.
Old 16th February 2018, 19:44   #22571  |  Link
PCU
why when i select d3d11 decoder, hardware deinterlacing is inactive? is deinterlacing is auto in d3d11 mode?
PCU is offline   Reply With Quote
Old 16th February 2018, 19:48   #22572  |  Link
el Filou
el Filou's Avatar
madVR doesn't support D3D11 deinterlacing yet, it's in the release notes.
Old 16th February 2018, 19:51   #22573  |  Link
PCU
i forgot to say: i'm using evr-cp (mpc-hc).
Old 16th February 2018, 20:03   #22574  |  Link
With any other renderer you would get the same deinterlacing as you would with any other decoder. Its not performed by LAV.
Old 16th February 2018, 21:09   #22575  |  Link
strumf666
Same with vega64, probably broken amd drivers.
strumf666 is offline   Reply With Quote
Old 17th February 2018, 13:51   #22576  |  Link
Sebastiii
HTPC : i7 920 6Go Win10(x64) / Nvidia 1050Ti / P6T Deluxe / Harman-Kardon AVR-355.
Sebastiii is offline   Reply With Quote
Old 17th February 2018, 14:54   #22577  |  Link
Zulithe
D3D11 broken in latest nightly? (LAVFilters-0.71.0-5.exe)
*edit* if you select a specific device it works, automatic shows no video for me
Zulithe is offline   Reply With Quote
Old 17th February 2018, 15:01   #22578  |  Link
sneaker_ger
And native D3D11 works if you go back to 0.71.0 (stable)?
Old 17th February 2018, 16:14   #22579  |  Link
I would expect more things to be broken in the current nightly. Unless you have a reason to, one really shouldn't use in-development versions on a daily basis.
Old 17th February 2018, 18:28   #22580  |  Link
DragonQ
Two questions:
1) Is there a reason 0.71 isn't listed in the first post of this thread?
2) Does D3D11 mode support deinterlacing yet?
TV Setup: LG OLED55B7V; Onkyo TX-NR515; ODroid N2+; CoreElec 9.2.7
DragonQ is offline   Reply With Quote
