6th May 2011, 11:41 | #2581 | Link | |
6th May 2011, 11:55 | #2583 | Link |
Hi.
I am not sure if this is LAVF splitter issue... If i try to render "http://www.luckymedia.nl/luckytv/wp-content/uploads/luckytv_video/2011_05_05_4dc2e404d86b5.mp4" file using "File Source (URL)", it will popop -2147221163 - in Hex is 80040155 which seems to be the error code for: "Interface not Registered". This happend in Media Portal OnlineVideos plugin. Using official LAV.24 If i use Haali splitter, it is working. Ideas?
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
6th May 2011, 12:20 | #2584 | Link | |
ffmpeg supports using a 3rd party decoding library, opencore-amr, for amr decoding. I can try to add it to my ffmpeg build, for better format coverage.
6th May 2011, 12:32 | #2585 | Link | |
Yes, at least if it's muxed correctly. |
6th May 2011, 12:39 | #2587 | Link |
I have all those sample files. I will test them again, but i have not seen any ffmpeg crash for a long time, looks more like media portal is screwing up again, or your system is somehow faulty.
Most of these errors look like heap corruption errors, which would not necessarily have to happen at the point when it crashes, it could just crash when the corrupted heap is accessed the next time. Try with MPC-HC, and if you cannot make it crash, i blame MediaPortal.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 6th May 2011 at 12:46. |
6th May 2011, 12:41 | #2588 | Link | |
PID: 256/4113 ($1b), "HDMV", descriptor $28, h264/AVC PID: 256/4352 ($84), "AC-3", AC3 M2TS, 1 video track, 1 audio track, 0:01:34, 60i /1.001 1: h264/AVC, 1080i60 /1.001 (16:9) 2: AC3, English, 5.1 channels, 640kbps, 48kHz Quote:
6th May 2011, 13:08 | #2589 | Link |
jmone didn't believe me when I said I couldn't get eac3to to extract the eac3 from certain discs, either. It would convert it to AC3 in my case.
6th May 2011, 13:15 | #2590 | Link |
When I extract as .ac3 though, mkvmerge sees it as a h.264 elementary video track, so I get 2 video tracks and no audio. Weird.
Anyway, I uploaded the m2ts here if anyone wants to give it a go: http://www.megaupload.com/?d=A18UUKPN |
6th May 2011, 13:25 | #2591 | Link | |
6th May 2011, 13:38 | #2592 | Link | |
When a crash happens, it is for most users not directly obvious what part of the playback chain was faulty. A custom error dialog could allow you to clarify which filter crashed and at the same time ask the user to report the problem with a sample file.
MPC-HC 2.2.1 |
6th May 2011, 13:39 | #2593 | Link |
That could work, i guess.
6th May 2011, 14:19 | #2597 | Link |
As promised before here I am with 2 PowerPoint issues.
Nev, maybe you can figure out what is happening here (if you are bored and find some time to look at it). It's a bit of work to set up the testing environment, but I hope that you don't mind: PowerPoint versions <= 2007 by default use MCI to playback videos. I tweaked the MCI settings in the registry to use DirectShow instead of vfw. Also, PowerPoint 2007 tries to use wmp.dll to handle videos - hardly with success. I therefore always de-register the 32 bit version of the wmp.dll. http://www.mediafire.com/?lfro1w3nd3bidib (registry tweaks for MCI) The first one is for PowerPoint 2003/2007: http://www.mediafire.com/?7wwy27kaftaaffw (flv file) This exemplary flv file somehow starts to "play" (there is definitely some activity) but it seems that the screen is just not being updated. This only happens with LAVSplitter. MPC-FLV-Splitter and another one I tried do not suffer from this issue. (Btw, decoder is current ffdShow 3840) The second problem is with the hardware accelerated native mode of PowerPoint 2010. I know that you don't have version 2010, but the standalone viewer should show the same behaviour. It is only the following mpeg file (found so far) which cannot be played back at all with LAVSplitter in PowerPoint 2010. I tried the elecard mpeg demuxer instead and it works fine. (Tried ffdShow and MS DTV-DVD as decoders but no difference) http://www.mediafire.com/?l8gep9jwcvozi09 (MPEG2 file) http://www.mediafire.com/?48847maioldq250 (PowerPoint file for testing) http://www.microsoft.com/downloads/d...1-294eeb832823 (free PowerPoint Viewer for Version 2010) As far as I know, in native 2010 mode PowerPoint at first tries to use DXVA to playback videos. Could the underlying problem be a colorspace issue? Last edited by Sven75; 7th May 2011 at 08:40. |
