3rd May 2018, 00:24 | #50581 | Link | |
Keep your GPU utilization down to whatever load level doesn't create frame drops and if that's under 90% load then so be it. Max load percentage is not a target. |
3rd May 2018, 00:30 | #50583 | Link |
I have Windows 10 Pro for Workstations (1803) and I do have that option. I am not sure how much it changes though, I think it is only for minor latency improvements. Like disabling C1E in BIOS and similar tweaks. I don't notice anything compared to High Performance for HTPC.
madVR options explained Last edited by Asmodian; 3rd May 2018 at 00:35. |
3rd May 2018, 00:34 | #50584 | Link |
It really makes no difference outside of pathological edge cases.
More importantly for everyone having issues on 1803, make sure that the Game Bar is turned off, otherwise it'll inject itself in any 3D rendering.
3rd May 2018, 02:12 | #50586 | Link | |
3rd May 2018, 02:35 | #50590 | Link | |
EDIT: Previous drivers didn't help, previous madvr didn't help, BUT FSE fixes the queue problem for me for the 720p60 videos. Can anyone explain? Can people who are having low queues and dropped frames try FSE? Last edited by Crimson Wolf; 3rd May 2018 at 07:40. |
3rd May 2018, 08:10 | #50594 | Link |
Is this for real?
I guess FSE means the fullscreen exclusive mode? Well I haven't used that for years, so that is not what is causing my queue problems. Regarding Game Bar, I disable most of what I consider bloat in Windows 10 after any reinstall or big update, like the new 1803. I like to tweak my systems, but I don't go overboard and disable lots of services like in the Black Viper guide I used in the past.
It's is not unreasonable to think that some of Microsofts tweaks to DirectX can cause problems for MadVr is it? I hope Madshi looks in to this when he comes back. Until that time I will use an older version of MadVr with NNEDI3 128 settings. I miss NGU Sharp already
My HTPC : i9 10900K | nVidia RTX 4070 Super | TV : Samsung 75Q9FN QLED |
3rd May 2018, 08:16 | #50595 | Link |
Is this for real?
I haven't tried all of them, but NGU Anti-alias has the same issue. I believe the problem lies with NGU and how what works, but I have no clue. I will use NNEDI3 128 for the time being.
3rd May 2018, 11:00 | #50596 | Link |
Fortunately no bigger problems for me with the Win10-1803-update !! The only thing that seem to be necessary for me now too is changing RGB settings.
Before the update I had RGB full everywhere but now the images are rendered way to dark. But setting RGB to '16-235' within MadVR the images are to bright. So I am using 8 for blacks in MadVr RGB custom settings right now but have to test/compare more with other movies. |
3rd May 2018, 12:03 | #50598 | Link |
I suspect this is a system problem. I'm using 1803, latest madVR, latest Nvidia drivers (GTX 1080), and am seeing none of these issues. Maybe the 1803 version is making heavier use of GPU resources than the previous version, leaving less for madVR.
3rd May 2018, 12:05 | #50599 | Link |
It looks good , but you need to notice the different when enabling windows HDR it's not using 10 bit YcbCr 4:2:2 anymore . it is using 8 bit + Dithering and that's the different with the spring now.
I will do it next time sure. |
