11th October 2017, 01:24 | #2661 | Link |
Stax
Windows 10 RS3 "Fall Update" is out. Do you see any incompatibilities?
11th October 2017, 04:08 | #2662 | Link |
AC3 with delay > AAC to MKV or MP4 issue
Hi, if I use staxrip 1.7.0.0 stable to encode a mkv with AC3 audio that has a delay to a mkv with AAC audio, the audio is wildly out of sync and the resulting output file has the audio listed as being 1 second shorter (and a slightly smaller delay value).
Source from mediainfo before encoding: Code:
Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Format settings, Endianness : Big Codec ID : A_AC3 Duration : 21 min 59 s Bit rate mode : Constant Bit rate : 384 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Delay relative to video : -126 ms Stream size : 60.4 MiB (7%) Service kind : Complete Main Default : Yes Forced : No Code:
Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : A_AAC-2 Duration : 21 min 58 s Bit rate : 211 kb/s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 SPF) Compression mode : Lossy Delay relative to video : -117 ms Stream size : 33.2 MiB (4%) Language : English Default : No Forced : No Code:
Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : A_AAC-2 Duration : 21 min 59 s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 SPF) Compression mode : Lossy Delay relative to video : -126 ms Title : Stereo Default : Yes Forced : No |
12th October 2017, 23:22 | #2663 | Link |
Stax
Just installed RS3 so far the the only problem that I encountered is "Shutdown" doesn't work after encoding
15th October 2017, 00:33 | #2666 | Link | |
@Lupissimo
@Sxc Please post the full log file, I tried to reproduce it but couldn't find a problem. @Zetti Thanks, I've updated both. Quote:
@mparade That don't contain the info I need, please upload a sample.
15th October 2017, 02:08 | #2667 | Link |
hi stax76 - unfortunately I have this recurring error with stable 1.7.0.0 with any file I try to encode (I upgraded NVencc 3.2.2 to 3.2.3):
Error Video encoding using NVEnc 3.22 (1.7.0.0) Video encoding using NVEnc 3.22 failed with exit code: 1 (0x1) The exit code might be a system error code: STATUS_WAIT_1 The exit code might be a system error code: Incorrect function. ------------------- Video encoding using NVEnc 3.22 ------------------- C:\GPU\StaxRip-x64-1.7\Apps\NVEnc\NVEncC64.exe --cqp 18:20:22 --codec h265 --preset quality --output-depth 10 --weightp --lookahead 16 --transfer auto -i H:\NEW\testfile_temp\testfile.avs -o H:\NEW\testfile_temp\testfile_out.h265 NVEncC (x64) 3.23 (r667) by rigaya, Sep 26 2017 20:51:36 (VC 1900/Win/avx2) OS Version Windows 7 x64 (7601) CPU Intel Core i5-2500K @ 3.30GHz (4C/4T) GPU #0: GeForce GTX 1060 6GB (10 EU) @ 1708 MHz (387.92) NVENC / CUDA NVENC API 8.0, CUDA 9.1, schedule mode: auto Input Buffers CUDA, 36 frames Input Info Avisynth 2.60(yv12)->p010 [AVX], 1280x720, 24000/1001 fps Vpp Filters copyHtoD Output Info H.265/HEVC main10 @ Level auto 1280x720p 1:1 23.976fps (24000/1001fps) Encoder Preset quality Rate Control CQP I:18 P:20 B:22 Lookahead on, 16 frames, Adaptive I, B Insert GOP length 240 frames B frames 0 frames Ref frames 3 frames, LTR: off AQ off CU max / min auto / auto Others mv:auto Error cudaEventSynchronize: 4 (cudaErrorLaunchFailure). StaxRip.ErrorAbortException: Video encoding using NVEnc 3.22 failed with exit code: 1 (0x1) The exit code might be a system error code: STATUS_WAIT_1 The exit code might be a system error code: Incorrect function. ------------------- Video encoding using NVEnc 3.22 ------------------- C:\GPU\StaxRip-x64-1.7\Apps\NVEnc\NVEncC64.exe --cqp 18:20:22 --codec h265 --preset quality --output-depth 10 --weightp --lookahead 16 --transfer auto -i H:\NEW\testfile_temp\testfile.avs -o H:\NEW\testfile_temp\testfile_out.h265 NVEncC (x64) 3.23 (r667) by rigaya, Sep 26 2017 20:51:36 (VC 1900/Win/avx2) OS Version Windows 7 x64 (7601) CPU Intel Core i5-2500K @ 3.30GHz (4C/4T) GPU #0: GeForce GTX 1060 6GB (10 EU) @ 1708 MHz (387.92) NVENC / CUDA NVENC API 8.0, CUDA 9.1, schedule mode: auto Input Buffers CUDA, 36 frames Input Info Avisynth 2.60(yv12)->p010 [AVX], 1280x720, 24000/1001 fps Vpp Filters copyHtoD Output Info H.265/HEVC main10 @ Level auto 1280x720p 1:1 23.976fps (24000/1001fps) Encoder Preset quality Rate Control CQP I:18 P:20 B:22 Lookahead on, 16 frames, Adaptive I, B Insert GOP length 240 frames B frames 0 frames Ref frames 3 frames, LTR: off AQ off CU max / min auto / auto Others mv:auto Error cudaEventSynchronize: 4 (cudaErrorLaunchFailure). at StaxRip.Proc.Start() in D:\Projekte\VS\VB\StaxRip\General\Proc.vb:line 338 at StaxRip.NVEnc.Encode() in D:\Projekte\VS\VB\StaxRip\Encoding\NVEnc.vb:line 82 at StaxRip.GlobalClass.ProcessVideo() in D:\Projekte\VS\VB\StaxRip\General\GlobalClass.vb:line 225 at System.Threading.Tasks.Parallel.<>c__DisplayClass4_0.<Invoke>b__0() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at StaxRip.GlobalClass.ProcessJob(String jobPath) in D:\Projekte\VS\VB\StaxRip\General\GlobalClass.vb:line 137 the complete log file : -------------------------- System Environment -------------------------- StaxRip : 1.7.0.0 Windows : Windows 7 Home Premium Language : English (Australia) CPU : Intel(R) Core(TM) i5-2500K CPU @ 3.30GHz GPU : NVIDIA GeForce GTX 1060 6GB Resolution : 1920 x 1080 DPI : 96 ------------------------ MediaInfo Source File ------------------------ H:\NEW\testfile.mkv General Complete name : H:\NEW\testfile.mkv Format : Matroska Format version : Version 4 / Version 2 File size : 2.18 GiB Duration : 56 min 53 s Overall bit rate mode : Variable Overall bit rate : 5 479 kb/s Encoded date : UTC 2017-08-21 21:21:11 Writing application : mkvmerge v8.3.0 ('Over the Horizon') 64bit Writing library : libebml v1.3.1 + libmatroska v1.4.2 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 5 Ref Frames Format, CABAC : Yes Format, RefFrames : 5 frames Codec ID : V_MPEG4/ISO/AVC Duration : 56 min 53 s Bit rate : 4 773 kb/s Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.216 Stream size : 1.89 GiB (87%) Writing library : x264 core 152 r2851 ba24899 Language : English Default : Yes Forced : No Audio ID : 2 Format : FLAC Format/Info : Free Lossless Audio Codec Codec ID : A_FLAC Duration : 56 min 53 s Bit rate mode : Variable Bit rate : 720 kb/s Channel(s) : 1 channel Channel positions : Front: C Sampling rate : 48.0 kHz Frame rate : 11.719 FPS (4096 SPF) Bit depth : 24 bits Stream size : 293 MiB (13%) Writing library : libFLAC 1.2.1 (UTC 2007-09-17) Language : English Default : Yes Forced : No Menu 00 : 00:00.000 : en:00:00:00.000 00 : 07:07.552 : en:00:07:07.552 00 : 11:30.023 : en:00:11:30.023 00 : 23:31.076 : en:00:23:31.076 00 : 29:10.207 : en:00:29:10.207 00 : 36:12.712 : en:00:36:12.712 00 : 45:33.314 : en:00:45:33.314 ------------------ Demux MKV using mkvextract 15.0.0 ------------------ C:\GPU\StaxRip-x64-1.7\Apps\MKVToolNix\mkvextract.exe tracks H:\NEW\testfile.mkv 1:"H:\NEW\testfile_temp\testfile ID1 English.flac" --ui-language en Extracting track 1 with the CodecID 'A_FLAC' to the file 'H:\NEW\testfile_temp\testfile ID1 English.flac'. Container format: raw data Start: 11:58:46 AM End: 11:58:58 AM Duration: 00:00:12 General Complete name : H:\NEW\testfile_temp\testfile ID1 English.flac Format : FLAC Format/Info : Free Lossless Audio Codec File size : 293 MiB Duration : 56 min 53 s Overall bit rate mode : Variable Overall bit rate : 720 kb/s Audio Format : FLAC Format/Info : Free Lossless Audio Codec Duration : 56 min 53 s Bit rate mode : Variable Bit rate : 720 kb/s Channel(s) : 1 channel Channel positions : Front: C Sampling rate : 48.0 kHz Bit depth : 24 bits Stream size : 293 MiB (100%) Writing library : libFLAC 1.2.1 (UTC 2007-09-17) -------------- Demux xml chapters using mkvextract 15.0.0 -------------- C:\GPU\StaxRip-x64-1.7\Apps\MKVToolNix\mkvextract.exe chapters H:\NEW\testfile.mkv --redirect-output H:\NEW\testfile_temp\testfile_chapters.xml File 'H:\NEW\testfile.mkv': container: Matroska Track ID 0: video (MPEG-4p10/AVC/h.264) Track ID 1: audio (FLAC) Chapters: 7 entries Start: 11:58:58 AM End: 11:58:59 AM Duration: 00:00:00 -------------- Demux ogg chapters using mkvextract 15.0.0 -------------- C:\GPU\StaxRip-x64-1.7\Apps\MKVToolNix\mkvextract.exe chapters H:\NEW\testfile.mkv --redirect-output H:\NEW\testfile_temp\testfile_chapters.txt --simple File 'H:\NEW\testfile.mkv': container: Matroska Track ID 0: video (MPEG-4p10/AVC/h.264) Track ID 1: audio (FLAC) Chapters: 7 entries Start: 11:58:59 AM End: 11:58:59 AM Duration: 00:00:00 ----------------------- Indexing using ffmsindex ----------------------- C:\GPU\StaxRip-x64-1.7\Apps\Plugins\both\ffms2\ffmsindex.exe H:\NEW\testfile.mkv H:\NEW\testfile_temp\testfile.ffindex Writing index... done. Start: 11:58:59 AM End: 11:59:03 AM Duration: 00:00:04 --------------------------- AviSynth Script --------------------------- LoadPlugin("C:\GPU\StaxRip-x64-1.7\Apps\Plugins\both\ffms2\ffms2.dll") FFVideoSource("H:\NEW\testfile.mkv", colorspace = "YV12", \ cachefile = "H:\NEW\testfile_temp\testfile.ffindex") -------------------------- Script Properties -------------------------- Source Frame Count : 81838 Source Frame Rate : 23.976024 Source Duration : 00:56:53.3270000 Target Frame Count : 81838 Target Frame Rate : 23.976024 Target Duration : 00:56:53.3270000 ----------------------- MediaInfo Audio Source 1 ----------------------- General Complete name : H:\NEW\testfile_temp\testfile ID1 English.flac Format : FLAC Format/Info : Free Lossless Audio Codec File size : 293 MiB Duration : 56 min 53 s Overall bit rate mode : Variable Overall bit rate : 720 kb/s Audio Format : FLAC Format/Info : Free Lossless Audio Codec Duration : 56 min 53 s Bit rate mode : Variable Bit rate : 720 kb/s Channel(s) : 1 channel Channel positions : Front: C Sampling rate : 48.0 kHz Bit depth : 24 bits Stream size : 293 MiB (100%) Writing library : libFLAC 1.2.1 (UTC 2007-09-17) ---------------- Error Video encoding using NVEnc 3.22 ---------------- Video encoding using NVEnc 3.22 failed with exit code: 1 (0x1) The exit code might be a system error code: STATUS_WAIT_1 The exit code might be a system error code: Incorrect function. ------------------- Video encoding using NVEnc 3.22 ------------------- C:\GPU\StaxRip-x64-1.7\Apps\NVEnc\NVEncC64.exe --cqp 18:20:22 --codec h265 --preset quality --output-depth 10 --weightp --lookahead 16 --transfer auto -i H:\NEW\testfile_temp\testfile.avs -o H:\NEW\testfile_temp\testfile_out.h265 NVEncC (x64) 3.23 (r667) by rigaya, Sep 26 2017 20:51:36 (VC 1900/Win/avx2) OS Version Windows 7 x64 (7601) CPU Intel Core i5-2500K @ 3.30GHz (4C/4T) GPU #0: GeForce GTX 1060 6GB (10 EU) @ 1708 MHz (387.92) NVENC / CUDA NVENC API 8.0, CUDA 9.1, schedule mode: auto Input Buffers CUDA, 36 frames Input Info Avisynth 2.60(yv12)->p010 [AVX], 1280x720, 24000/1001 fps Vpp Filters copyHtoD Output Info H.265/HEVC main10 @ Level auto 1280x720p 1:1 23.976fps (24000/1001fps) Encoder Preset quality Rate Control CQP I:18 P:20 B:22 Lookahead on, 16 frames, Adaptive I, B Insert GOP length 240 frames B frames 0 frames Ref frames 3 frames, LTR: off AQ off CU max / min auto / auto Others mv:auto Error cudaEventSynchronize: 4 (cudaErrorLaunchFailure). ------------------- Video encoding using NVEnc 3.22 ------------------- C:\GPU\StaxRip-x64-1.7\Apps\NVEnc\NVEncC64.exe --cqp 18:20:22 --codec h265 --preset quality --output-depth 10 --weightp --lookahead 16 --transfer auto -i H:\NEW\testfile_temp\testfile.avs -o H:\NEW\testfile_temp\testfile_out.h265 NVEncC (x64) 3.23 (r667) by rigaya, Sep 26 2017 20:51:36 (VC 1900/Win/avx2) OS Version Windows 7 x64 (7601) CPU Intel Core i5-2500K @ 3.30GHz (4C/4T) GPU #0: GeForce GTX 1060 6GB (10 EU) @ 1708 MHz (387.92) NVENC / CUDA NVENC API 8.0, CUDA 9.1, schedule mode: auto Input Buffers CUDA, 36 frames Input Info Avisynth 2.60(yv12)->p010 [AVX], 1280x720, 24000/1001 fps Vpp Filters copyHtoD Output Info H.265/HEVC main10 @ Level auto 1280x720p 1:1 23.976fps (24000/1001fps) Encoder Preset quality Rate Control CQP I:18 P:20 B:22 Lookahead on, 16 frames, Adaptive I, B Insert GOP length 240 frames B frames 0 frames Ref frames 3 frames, LTR: off AQ off CU max / min auto / auto Others mv:auto Error cudaEventSynchronize: 4 (cudaErrorLaunchFailure). Start: 11:59:30 AM End: 12:01:01 PM Duration: 00:01:30 hope this helps, any further information I can give please let me know. Please note that the issue does ALSO occur with stable 1.6.0.0 - so it might be video driver related - I updated my Nvidia GPU drivers to v387.92 two days ago. Thank you. |
15th October 2017, 02:11 | #2668 | Link |
15th October 2017, 02:25 | #2669 | Link | |
thank you. EDIT: tried a quick test by disabling the weightp option and it works but video size is hardly compressed at all. Last edited by craigpro; 15th October 2017 at 02:38. |
15th October 2017, 05:07 | #2670 | Link |
what's the correct way to encode x265 2160p HDR video?? I tried a test vid however after encoding(x265) the HDR metadata was no longer picked up and the encode was washed out, thought the metadata would automatically pass through to the encode??? using staxrip 1.7.0.0
15th October 2017, 07:52 | #2671 | Link |
I also need a proper way to convert HDR to SDR. I think we need a guide for HDR -> HDR, HDR -> SDR, SDR -> HDR.
I think they talked about it before on the forum but it's needed to be gathered from many posts here as we don't have any complete guide about this. |
17th October 2017, 07:42 | #2674 | Link |
I have done one test encode using NVEnc and my Quadro K4200.
I have set output bitdepth to 10bit. The output became only 8bit. Does NVEnc support 10bit h264 encoding with any other Nvidia card at all (my card is from the 1st (Kepler) generation)? I haven't found anything about it in the NVEnc docs. On top of it, all I have found some artifacts in the output as well Please help. |
17th October 2017, 09:19 | #2675 | Link |
Stax released a new test version yesterday 1.7.0.4 : https://github.com/stax76/staxrip/bl...r/changelog.md
There is a new option for the HDR metadata and one thing related to nvenc --transfer flags , not using those myself but maybe previous posts related to HDR or nvenc issues can give it a try and find this one more helpful. |
20th October 2017, 07:19 | #2676 | Link | ||
@stax76
But in this case we need to feed the encoder (NVEncC) with the correct HDR metadata as well. Is it currently possible? The player is going to use such metadata when the source is HDR10: - "SMPTE 2086 mastering display information (gamut, min + max luminance), MaxCLL and MaxFALL. Stuff like the video's color primaries, matrix, transfer etc are usually "assumed" and not transported;" So, if they lack of such metadata, I do not really know if they will be handled properly at all by the display/player. Thank you very much for the info. Last edited by mparade; 20th October 2017 at 07:37. |
21st October 2017, 07:22 | #2677 | Link | |
It allow mvc mkv passthrough simultaneously trim the movie output is same like make mkv or you can generate small 3d blue ray from SBS clip for testing using Sony Vegas |
21st October 2017, 10:33 | #2678 | Link | |
http://s1.toldacuccot.hu/letoltes?si...t1_inmux3D.zip Please let me know if it contains the info you need. Thank you very much for your amazing software. Last edited by mparade; 21st October 2017 at 10:36. |
21st October 2017, 11:29 | #2679 | Link | |
2nd sample is uploaded here as an ISO file (SSIF structure): http://s1.toldacuccot.hu/letoltes?si...t2_SSIF_3D.zip |
