3rd March 2018, 17:48 | #41 | Link |
@l33tmeatwad:
Since I couldn't find ffmsindex or d2vwitch I went through all the filters I could think of that are not part of Vapoursynth directly and listed them:
@halls: I have the same effect when using Vapoursynth editor when I used this script: Code:
# Imports import vapoursynth as vs core = vs.get_core() # Loading /Users/selur/Desktop/test.mp4 using FFMS2 clip = core.ffms2.Source(source="/Users/selur/Desktop/test.mp4",format=vs.YUV420P8,alpha=False) # making sure input color matrix is set as 470bg clip = core.resize.Point(clip, matrix_in_s="470bg") # making sure frame rate is set to 30000/1001 clip = core.std.AssumeFPS(clip, fpsnum=30000, fpsden=1001) # Making sure input color range is set to TV (limited) range. clip = core.std.SetFrameProp(clip=clip, prop="_ColorRange", intval=1) # adjusting output color from: YUV420P8 to YUV420P10 for x264Model (i420) clip = core.resize.Bicubic(clip=clip, format=vs.YUV420P10) # Output clip.set_output() Cu Selur |
3rd March 2018, 19:10 | #42 | Link | |
unsigned int
# Loading /Users/selur/Desktop/test.mp4 using FFMS2 clip = core.ffms2.Source(source="/Users/selur/Desktop/test.mp4",format=vs.YUV420P8,alpha=False) clip = core.std.BlankClip(clip)
Buy me a "coffee" and/or hire me to write code! |
3rd March 2018, 19:46 | #44 | Link | |
unsigned int
# Loading /Users/selur/Desktop/test.mp4 using FFMS2 clip = core.ffms2.Source(source="/Users/selur/Desktop/test.mp4",format=vs.YUV420P8,alpha=False) clip = core.std.CropRel(clip, left=128) clip = core.std.AddBorders(clip, left=128) If black, then the problem is in ffms2. If still blue, then it could be the conversion to RGB (for display), or something in vsedit, or in Qt, or...
4th March 2018, 14:04 | #45 | Link |
import vapoursynth as vs core = vs.get_core() from vapoursynth import core c = core.ffms2.Source(source='/Users/selur/Desktop/test.mp4') c = core.std.BlankClip(c) c.set_output()) Code:
import vapoursynth as vs core = vs.get_core() from vapoursynth import core c = core.ffms2.Source(source='/Users/selur/Desktop/公演后感言.mp4') c = core.std.CropRel(c, left=128) c = core.std.AddBorders(c, left=128) c.set_output() Cu Selur |
4th March 2018, 15:42 | #46 | Link | |
unsigned int
5th March 2018, 15:32 | #48 | Link | |
I'll add make sure to add ffmsindex and d2vwitch, as for the others, I'll add when I get the chance. I'm also going to just post my full instructions on how I compile everything for VapourSynth.framework so if anyone else wants to help contribute they can, I just need to clean up my nonsensical notes... Last edited by l33tmeatwad; 5th March 2018 at 17:15. |
5th March 2018, 18:24 | #52 | Link | |
5th March 2018, 21:37 | #53 | Link |
unsigned int
I kind of doubt this patch fixes the problem, but try it anyway:
diff --git a/src/core/vsresize.cpp b/src/core/vsresize.cpp index efd1a73..4f52c5b 100644 --- a/src/core/vsresize.cpp +++ b/src/core/vsresize.cpp @@ -493,7 +493,7 @@ public: allocate(vsformat, format.width, format.height, graph.get_input_buffering(), vsapi, core); if (vsformat->id == pfCompatBGR32) - m_p2p_func = vsp2p::packed_to_planar<vsp2p::packed_argb32_le>::unpack; + m_p2p_func = vsp2p::packed_to_planar<vsp2p::packed_argb32>::unpack; else if (vsformat->id == pfCompatYUY2) m_p2p_func = vsp2p::packed_to_planar<vsp2p::packed_yuy2>::unpack; @@ -533,7 +533,7 @@ public: allocate(vsformat, format.width, format.height, graph.get_output_buffering(), vsapi, core); if (vsformat->id == pfCompatBGR32) - m_p2p_func = vsp2p::planar_to_packed<vsp2p::packed_argb32_le, true>::pack; + m_p2p_func = vsp2p::planar_to_packed<vsp2p::packed_argb32, true>::pack; else if (vsformat->id == pfCompatYUY2) m_p2p_func = vsp2p::planar_to_packed<vsp2p::packed_yuy2, true>::pack;
5th March 2018, 22:49 | #54 | Link | |
6th March 2018, 15:49 | #58 | Link |
unsigned int
Okay then. What version of Qt do you have?
Edit: nevermind. Apparently it's a VapourSynth bug, not Qt.
Buy me a "coffee" and/or hire me to write code! Last edited by jackoneill; 6th March 2018 at 18:04. |
6th March 2018, 15:55 | #59 | Link |
I have and use Qt 5.9 for my personal projects, but for VapourSynth Editor I use 5.6 because if I use anything newer the output is a mostly black with blocky distortion, however 5.6 will properly compile it. I used 5.10 from brew on a fresh system to compile Wobbly.
6th March 2018, 17:14 | #60 | Link |
unsigned int
Please test one more patch, but without applying the previous one:
diff --git a/src/common/p2p.h b/src/common/p2p.h index 60f50e9..0895b93 100644 --- a/src/common/p2p.h +++ b/src/common/p2p.h @@ -26,6 +26,10 @@ #include <climits> #include <type_traits> +#ifdef _WIN32 + #include <stdlib.h> // _byteswap_x +#endif + #ifdef P2P_USER_NAMESPACE #define P2P_NAMESPACE P2P_USER_NAMESPACE #else @@ -34,12 +38,10 @@ #ifdef _WIN32 #define P2P_LITTLE_ENDIAN - #include <stdlib.h> -#else - #include <sys/param.h> - #if __BYTE_ORDER == __BIG_ENDIAN +#elif defined(__BYTE_ORDER__) + #if __BYTE_ORDER__ == __ORDER_BIG_ENDIAN__ #define P2P_BIG_ENDIAN - #elif __BYTE_ORDER == __LITTLE_ENDIAN + #elif __BYTE_ORDER__ == __ORDER_LITTLE_ENDIAN__ #define P2P_LITTLE_ENDIAN #endif #endif
