2nd January 2008, 18:35 | #401 | Link | |
2nd January 2008, 18:48 | #402 | Link | |
2nd January 2008, 19:16 | #403 | Link |
I have an 5.5G Ipod and cannot import from itunes to ipod a file with level 3.0 (I used the IPOD 1.3 profile and edited the level number )
I can import the same file with the IPOD1.3 profile but my res is limited to 320x240). I can do it with Videora (level 3.0 and res of 640x480 ) and wanted to know if it was related to http://www.redkawa.com/blog/post.php?t=3820 Videora is using FFmpeg with x264. I cannot import also successfully with megui. Thx. Last edited by mikenadia; 2nd January 2008 at 19:27. |
2nd January 2008, 19:36 | #405 | Link | |
mikenadia
Did you try floola instead of iTunes? http://www.floola.com/ Quote:
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 2nd January 2008 at 19:39. |
2nd January 2008, 19:46 | #406 | Link | |
Your program is the only program that I've found that converts HD .mkv files without a hitch! |
2nd January 2008, 20:06 | #408 | Link |
Once RipBot finishes task try to find ripbot264tmp directory.
Inside Jobx directory you should see four .cmd files. Open jobx_MuxFiles.cmd in notepad and add pause. Save. Before executing jobx_MuxFiles.cmd make sure that video.264 and audio.aac is present in RipBot264tmp directory. I need to know what mkvmerge says. (make a sreenshot)
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 2nd January 2008 at 20:09. |
2nd January 2008, 20:40 | #409 | Link | |
3rd January 2008, 01:21 | #410 | Link |
Do I need to have a surround sound receiver in order to test if a file I converted with '5.1 CT AAC-LC 320kbps[cbr]' will work on the 360 or PS3? The 360 doesn't play the file and the PS3 tells me that the audio cannot be read, but video plays fine.
3rd January 2008, 01:32 | #411 | Link |
Unfortunately you need new receiver with AAC support otherwise PS3 (v2.10) will downmix to stereo (if you unchecked AAC in Audio Settings)
5.1 AAC is not even downmixed on XBOX360
3rd January 2008, 01:54 | #413 | Link | |
3rd January 2008, 02:07 | #414 | Link | |
3rd January 2008, 11:54 | #418 | Link |
@Atak_Snajpera
i'm trying to convert a movie using CQF. I try 22 and 18.. each time I obtain a movie of 1.8 gigs. THe source is 4 gigs. any idea why ? D:\DVD-convertion\encode\temp>"D:\DVD-tools\tools\AutoMKV093_NORIP\exe\encoder\x 264.exe" movie.avs --crf 18 --level 4.1 --filter 0,0 --aq-strength 0.5 --aq-sen sitivity 5 --ref 3 --mixed-refs --bframes 3 --b-pyramid --b-rdo --bime - -weightb --direct auto --subme 6 --trellis 1 --analyse p8x8,b8x8,i4x4,i8x8 --8x 8dct --me dia --threads auto --thread-input --progress --no-psnr --no-ssim --au d --nal-hrd --sar 1:1 --vbv-bufsize 14745 --vbv-maxrate 16000 --output movie_rip bot.264 avis [info]: 1280x720 @ 23.98 fps (109920 frames) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX MMXEXT SSE SSE2 3DNow! x264 [info]: slice I:1496 Avg QP:12.53 size: 94007a 0:00:00 x264 [info]: slice P:82354 Avg QP:14.45 size: 21911 x264 [info]: slice B:26070 Avg QP:17.02 size: 7155 x264 [info]: mb I I16..4: 30.2% 22.1% 47.7% x264 [info]: mb P I16..4: 7.0% 4.5% 3.7% P16..4: 39.2% 4.6% 3.5% 0.0% 0 .0% skip:37.6% x264 [info]: mb B I16..4: 0.8% 0.6% 0.7% B16..8: 19.9% 1.0% 2.0% direct: 2.1% skip:72.9% x264 [info]: 8x8 transform intra:28.7% inter:39.4% x264 [info]: direct mvs spatial:98.8% temporal:1.2% x264 [info]: ref P 85.6% 9.1% 5.3% x264 [info]: ref B 84.1% 10.2% 5.7% x264 [info]: kb/s:3719.6 encoded 109920 frames, 5.38 fps, 3723.62 kb/s |
3rd January 2008, 12:33 | #419 | Link | |||
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 3rd January 2008 at 13:03. |
